Recommendations to shoot / determine a grade on proposed road
   / Recommendations to shoot / determine a grade on proposed road #21
That is not correct GPS does figure elevations. It is the weak part of consumer grade GPS. Survey grade GPS does excellent with elevations but costs big bucks.
Yes it is correct...do some research and you will find that a "GPS" device can give elevations but the data (elevation) is NOT coming from anything to do with the satellites or the positioning system...once a location is defined the device uses the location and interfaces with a "digital elevation model" (basically a database)...which is a third party and is not really part of a Global Positioning System...
What you are referring to that costs "big bucks" is just more exact software that interpolates to more precise calculations between exact positions and known elevations...
   / Recommendations to shoot / determine a grade on proposed road #22
I think there is a misconception of how a GPS device/app determines elevations...
All a GPS can do is determine geographical location...for elevations it must use third party data (nothing to do with GPS) i.e, data from topographical mapping that is correlated and interpolated...That is...once a location is determined it (device/app etc.) then relates that position to known elevations.
Not quite accurate. GPS calculates your 3D position in space, think (x,y,z) coordinates. From there, the data is reconciled to a simple model of the earth, a simplification known as an ellipsoid. By default, GPS uses the WGS-84 datum that covers the whole earth. When GPS gives position and altitude, it is the latitude and longitude of the base point, as well as altitude off the elipsoid. It doesn't know anything about terrain or topography, only the ellipsoid. You can certainly transfer the simple position over to another datum (different ellipsoid, some are localized to better approximate local regions) or work it relative to a terrain model, but you don't have to. GPS is able to give position and altitude relative to the WGS-84 datum all by itself, with no knowledge of the terrain.
   / Recommendations to shoot / determine a grade on proposed road #23
At this point you have a surveyor (dodge man) and GPS software developer (me) telling you that you're wrong. As I said before, GPS gives 3D position in space, and that involved three coordinates. It does all that with satellites. Anything involving an elevation model is a separate follow on mode of post-processing, but is not required.
   / Recommendations to shoot / determine a grade on proposed road #24
Only to a degree...the elevations derived from digital elevation models are much more accurate....this the reason that GPS altimeter watches etc. have large margins of error...often in the hundreds of feet...!
   / Recommendations to shoot / determine a grade on proposed road #25
There is something called a geoid model that is used to calculate the elevation of the ground based on the ellipsoid height. So in that sense Pine is correct
the gps is using data to calculate the ground elevation. It is not using topo maps or any other kind database to figure elevations. The argument is kind of pointless since there is all kind of number crunching going on to figure a 3D position based on various data and models, wgs84 being another part of a model.
To the op. If you had a distance of 540 feet a 10% grade would be an elevation change of 54 feet, so you should be ok if your numbers are good.
   / Recommendations to shoot / determine a grade on proposed road #26
FWIW...
A Digital Elevation Model (DEM) is a digital representation of ground surface topography or terrain with different accuracies for different application fields. DEM have been applied to a wide range of civil engineering and military planning tasks. DEM is obtained using a number of techniques such as photogrammetry, digitizing, laser scanning, radar interferometry, classical survey and GPS techniques. This paper presents an assessment study of DEM using GPS (Stop&Go) and kinematic techniques comparing with classical survey. The results show that a DEM generated from (Stop&Go) GPS technique has the highest accuracy with a RMS error of 9.70 cm. The RMS error of DEM derived by kinematic GPS is 12.00 cm.
Assessing digital elevation model uncertainty using GPS survey data
— Penn State
   / Recommendations to shoot / determine a grade on proposed road #27
You guys are arguing with yourselves. Did you read his last post? He knows very well what he's dealing with. Sounds like it's doable.
Thanks to the OP for the update. Looking forward to the final result. :cool:
   / Recommendations to shoot / determine a grade on proposed road #28
Yeah, not sure where you dug that up but it really has nothing to do with modern gps surveying. They are talking about the accuracy of a DEM and the accuracy of the results, such photogrammetry, stop and go gps, etc. The DEM is the results of surveying. The stuff they are talking about with gps is outdated, such as stop and go (I have heard it called PPK) and is not a technique any modern surveyor uses these days.
GPS surveying and results is a very complicated subject, one that I have only a vague understanding of. The theory is pretty simple but obtaining results is complicated. There is a lot that is going on with the software and computing that is pretty complex, does not matter if we are talking about a cell phone, handheld gps or survey grade equipment.
In my day to day use of gps there was never any data being used other than geoid model to calculate elevations. The elevations are calculated using the gps data and getting correctionS from a base or bases that are set on points of known elevation. The geoid model is not even needed, it just increases accuracy of the results.
Sorry to get off subject for the OP.
   / Recommendations to shoot / determine a grade on proposed road #29
Actually, GPS give a 4D position -- 3D plus time.
   / Recommendations to shoot / determine a grade on proposed road #30
I am a recently retired land surveyor and the weak part of cheap hand held gps is the elevations. If the area is wide open, no trees you might get decent results but I would not count on it.
They make cheap hand held levels, like a small telescope, about 10 long. Usually no magnification. I would put lath in every so often, say 25 feet measured in, and start at the bottom and work your way up the hill. You will need to know how high your eye is and make a mark on the lath ahead of you with a helper and measure how high the mark is.
For example, your eye is exactly 6 feet high, you make a mark on the lath 25 feet away 1 foot above the ground. That means the ground is 5 feet higher in 25 feet which equals a 20% grade. Keep in mind you can not measure higher than you stand, so if the ground in 25 feet is 7 feet higher you will have to set lath shorter than 25 feet. Keep in mind it shoots level, not up or down hill. This method is not great but is very cheap. They also make hand levels that will shoot up hill and show a grade on a scale on the side but are hard to find these days.
Some counties and states have free topo maps available. You probably need a way to print them out to scale them though. The quality of there software varies also on if you can just get the measurements on your computer or need to print it out.
Of course a surveying or engineering company could survey and design something but not cheap.
A hand held clinometer can be found on Amazon for about $40, Abney levels are a bit more. Used both in my forestry days to spot road grades.
   / Recommendations to shoot / determine a grade on proposed road #31
Fifty foot rise in just over 500 feet should make an overall grade of a little more than ten %. ( rough number just sitting here and knowing the 540 feet is a little more than the horizontal distance. )
   / Recommendations to shoot / determine a grade on proposed road #32
I have built all my heavy haul roads here just using string, a line level, and a 100 foot tape measure, and they have met Federal Funding guidelines.
To do this by yourself, you need to get a stake or rod to pound into the ground with a hammer, then tie your string on, run it out, and then measure it level with the line level pulling the string very tight. You then measure the height of the level string, and that will tell your grade. As you go down the hill, record your findings on paper and this will map out your road via grade changes.
I like to do my sections in 25 foot increments...
I also use string to set the centerline of my roads, and to establish finish grade.
Similar method was used in the stone age!:laughing:
   / Recommendations to shoot / determine a grade on proposed road #34
To op, how is the power company getting there? Old road, new road, or straight line. This may make a difference. I know they like to go straight with overhead and setting the least number of poles. Went thru the trees across the highway from me, straight thru the planted pine trees, cutting a wide path. The road is about 40 feet to one side with a little curve in it. Under ground is great but expensive.
   / Recommendations to shoot / determine a grade on proposed road #35
I had a discussion with the power Co. at my Summer cottage in Canada.
They agreed to zig zag across the driveway to keep the forest cut width down.
It cost me more; for a guy wire on each pole, and one or two more poles (9 total).
The cut width was 40' total though, with the driveway through the center.
The poles were not an ugly sight.
mred2, there is a power pole on the hill about 250 feet from new home site and 90 degrees off of that is an absolute straight line right to the new home. At least one large tree will have to be removed. We will have 1, or maybe 2 poles branch off of that (depending on how far they will allow between poles) and then go underground to the new home. Underground will be costly - the local propane company is the least expensive trenching service, and I can run the underground conduit and cable from the last pole to the home - have done that before - all inspected. A concern is that this hill top is very rocky - so trenching may not be an easy go.
A few years ago I changed from overhead to underground lines to the house and they allowed a certain distance as I recall. In that circumstance since I installed a new pole and then installed the conduit underground from that pole to the house, they did not charge me anything (I was surprised). I think it was because the length of the existing overhead wires from the transformer to the house were the same length of the new overhead wires from the transformer to the new pole from which I went underground - even though they put in entirely new overhead wire.
We, and power company, can get to the hill top two ways - one a bit steep and short and a sharp angle tho doable - and another the much longer existing road to the top. They are very fire conscious (California!) and every year send a crew up to check trees all along the course of the wires. I try to tell them where I see potential issues.
Next issue though is the well. County Fire requires 2500 gal storage tank (we will go bigger) and booster pumps from the tank for home fire protection sprinkler system. And County requires a well test to show sufficient water. We should hit enough water (the lower main house well gets 21 gpm -down 420 feet). The well guy suggests we go a minimum of 300 feet and that with an appropriately storage sized tank we may only need to hit about 2 gpm - though we expect more. Now they also (in addition to the steel casings for the first 70 feet) put in a 4" PVC sleeve with holes all the way down to protect the pipe, wire and well from rocks breaking away and jamming things up. He said without that if rocks break away and jams the pump up they may not be able to get it out.
Wow, I see I have rambled on a bit. Anyway, thanks for the heads up.
   / Recommendations to shoot / determine a grade on proposed road #37
Down here a ways South of you, the fire folks also require a fire fitting on storage tank separate from the other piping so they can use the water supply. A friend of mine put in a new home a couple of years ago and they also required a minimum 5,000 gal. tank. This is out where it is at least 2 miles to the nearest hydrant. Fire is a real big deal out here and anyone who has lived in this state for any length of time knows it and you will see very little, if any, argument about fire regulations.
Same here. I have talked to staff at County Fire and they advised about a number of things - absolute minimum tank size is 2500 gallons - larger perhaps if your water production is very, very low. And said it has to be fitted with a 4 1/2 inch special outlet for connection to a fire hose, and fire trucks need to be able to get very near to it. Staff there was very helpful - willing to spend time explaining it all and making recommendations re sizes, best plumbing options etc.. We are planning on going with a 4000 to 5000 gallon tank.
There are no hydrants anywhere - nearest town is 25 miles away. I always consider County Fire staff, County staff and others as assets and resources to help me get it right. But not everyone up here agrees with that.
   / Recommendations to shoot / determine a grade on proposed road #39
Where I live there is no water storage requirement for rural areas. They truck water in and if they can not keep up, your house burns down.
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
iDrive TDS-2010H...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2008 Ford F-250 Reading Service Truck (A59230)
2008 Ford F-250...
2019 CATERPILLAR D6 HIGH TRACK CRAWLER DOZER (A60429)
2019 CATERPILLAR...
iDrive TDS-2010H...
