Recommendation requested
/ Recommendation requested #1
Anonymous Poster
Epic Contributor
I'm buying a house on 6.3 hilly acres - mostly grass though. It is rather steep in places. Beyond cutting the grass I'd like to have a loader and be able to plow a driveway that is about 1/4 mile of gravel. The driveway itself is fairly level. I figure 4WD is an unnecessary expense...
I was looking around this evening and the Deere 4210 caught my eye, since at some point I'd also like to have a post-hole digger and maybe be able to move some earth a bit. Nothing really heavy-duty is required daily, but I want flexibility and power.
Now, I'm not rich, and the 4210 ain't cheap - any thoughts/suggestions? Is it too much for the task? Beyond that I'm thinking perhaps Kubota - anyone with some insight here could probide a welcome response.
Thx,
MD in VA
I'm no guru and I'm new out here but I've been trying to effectively plow my 600' driveway with my 8n and a 6' plow... sheer hell... It wouldn't be if it were 4WD... my $.02... go the extra mile and get 4wd. .... /forums/images/graemlins/smirk.gif Then again, you do live in VA (looks like)... heck... maybe you can get away with it. I'm in NY... no chance here when you get the snows like we did this past winter...
Hear ya and thanks for the input - we haven't had much snow here in the past few but this year was the exception. So much for the global-warming theorists... You're right BTW in that I'm in Virginia - north end by the to of the state.
As I said, thx. for your $.02
/ Recommendation requested #4
MikeVA,
Welcome to TBN. Before you know it, we'll be recommending the best tractor for you and you'll be asking about bigger ones! /forums/images/graemlins/grin.gif
</font><font color="blue" class="small">( I figure 4WD is an unnecessary expense... )</font>
I would seriously re-figure that. You mention wanting to use a front end loader (FEL). When the bucket on the FEL is full, there will be very little weight on the rear wheels, hence it's necessary to add ballast on the back. Even so, traction to the rear tires is decreased. Having power delivered to the front wheels gives much better control to the tractor when using the FEL. Also, most of these tractors only have brakes on the rear wheels...having 4WD couples the front and rear wheels together giving you better braking force when engaged.
If your property was flat, then I would say you might want to try to get away without it. I still wouldn't recommend it though, unless you just couldn't afford it. Considering you have "hilly acres", 4WD is a must.
I think you'll hear similar recommendations from others.
Good Luck, and feel free to ask any questions and to search the archives of TBN.
~Rick
Excellent point - I had not considered that the weight in the front would offset the back end - I was thinking more in terms of mowing rather than the FOL... My searches were saying that with 4WD you are actually adding perhaps 15-20% drive power due to the smaller tire size - but that doesn't take into consideration load-weight up front. I can easily see your point. Thanks for the tip = I'm sure I'll have a few other items pop up before I buy, and it's nice to know that there are people out there who will freely share opinions and truly know a heck of a lot more than I on the subject :)
/ Recommendation requested #6
Since I don't use my tractor for mowing, I can't really speak from experience on mowing issues, but I believe I've read from many that do mow on hills that engaging 4WD allows them to mow steeper hills with more confidence. Generally, for mowing on the flats, 4WD could be disengaged, but when on hills, it's quite a benefit to help the tractor get its power to the ground.
~Rick
/ Recommendation requested #7
Along with the FEL issue... 4wd really compensates for a lighter machine (such as your average cut). With a large ag machine, you can weight down the rear tires to gain the traction that you need... but with the average tractor used to mow yards & such (work around the house) large amounts of weight lead to other problems. So most go with a lighter machine, but have 4wd to get them through the tough stuff.
/ Recommendation requested #8
moving any snow, moving dirt, going up and down hills. u do need 4wd on samller tractors. the increase in performance is astounding. do your self a favor and rethink that part of your purchase.
/ Recommendation requested #9
Don't forget the resale aspect. 4WD greatly impacts the value in the used market. In some cases the difference between 2 and 4 wheel drive used tractors is more than the 4WD option when the tractor was new.
/ Recommendation requested #10
If you are going to have a FEL I think 4WD is a must. It makes quite a difference when digging into a pile of material such as dirt or gravel to have 4WD working for you. It is even more beneficial if you are using your FEL to dig in the dirt or to push and shove on heavy objects such as logs. Having 4WD is kinda like giving your tractor a shot of steroids when it needs it!
/ Recommendation requested #11
Did anyone mention 4WD?
/forums/images/graemlins/grin.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/grin.gif
/ Recommendation requested #12
Drive over to Tazewell, VA and check out the Power Trac line of tractors manufactured in your home state. Check out the PT425. I really am impressed with mine. Good luck in your search.
I have been looking at all post for awhile now. This is my first reply. Just thought I would let you know that I had a 2 WD tractor w/fel. It worked OK. I have sold that one and just bought a Kubota B2910 4 WD w/ fel and R4 tires. The snow last winter did me in. I also live in Va. Most of the time the 2 wd worked ok but sometimes you get a bucket full of snow and the rear tires would just spin. The rear tires on the 2 wd were loaded.
/ Recommendation requested #14
Hi Mike,
I know what I'm about to say may be herasy, but I have about the same landscape and have a Jinma 224 to handle the job. What the @#$%^&* is a Jinma, a chinese tractor that you assemble. I paid $6.5k for the tractor and a 60" RFM (on ebay). An FEL can be added for another $2500. Total $9K if you're willing to be your own mechanic and put 40hr of sweat equity into it. You're $8k ahead of the game. I can do a lot of my own maintenance for $8k.
They're not for everybody, but the project alone was just too much fun to pass up. I have limited info on my web site: www.diyquest.org.
YMMV,
Mark
/ Recommendation requested #15
DIYGuy,
That RFM looks very familiar. It's 100% identical to my First Choice Mower. Nice job on the tractor assembly - sounds like much fun to me. /forums/images/graemlins/cool.gif
OK all, I got the message on 4WD :)
Now on to more of the goodies that I'd love to hear your thoughts on:
I've decided to upgrade a bit - this is what I have thus far:
4310 130DLV
1005 4WD Front Axle in base
ROPS in base price
2015 12/12 trans upgrade
Dual mid SCV (necessary for both FEL and mower deck???)
iMatch hitch w/bushings
3rd SCV kit
Speed match kit (is it worth $40.00 for primarily mowing??)
Cruise and lighting/brushguard kits
Beyond that (and perhaps including that), I'm kinda lost - sticking with the stock base tires for now.
Anything that those with some past experience might change? Also, what to do about the FEL and the mower deck?
Everyone's been great thus far - I seem to have found the prime site for this! Thanks to all for your input...
Mike in VA
If I recall, Tazewell is near Richmond - correct?
Thanks for the tip...
/ Recommendation requested #19
</font><font color="blue" class="small">( Tazewell is near Richmond )</font>
I'd consider Tazewell to be a long ways from Richmond. Look just south of the southern tip of West Virginia on U.S. 460.
/ Recommendation requested #20
</font><font color="blue" class="small">( I've decided to upgrade a bit - this is what I have thus far:
4310 130DLV
ROPS in base price
3rd SCV kit
)</font>
Glad to help, but Okies can't understand yer list.
Could U clarify it?
2020 Peterbilt Vac Tron (A60352)
2020 Peterbilt Vac...
1973 White Trucks Western Star Dump Truck (A61165)
1973 White Trucks...
2025 SDLanch SDLE20 Diesel Mini Excavator (A60352)
2025 SDLanch...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2015 Ford F-350 4x4 Ext. Cab Service Truck (A61568)
2015 Ford F-350...
2017 JOHN DEERE 333G (A60736)
2017 JOHN DEERE...
