Rear wheel weight
/ Rear wheel weight #1
TheMan419
Indiana
New Holland Boomer 24
I am having a brain cramp. Having some issues with traction. If I am on the driveway no problem.
I need to actually move some snow out in the "yard". Need to make a path from the barn to the manure pile for example. If the snow gets too deep before I can get to it I have traction issues.
More weight on the rear will help that yes? I am pushing snow with the bucket. So if I pick up my tiller for an additional 600 lbs of weight that should solve some problems? I do not have chains so that is not an option right now.
/ Rear wheel weight #2
Yes, adding rear weight will help. Add a 3 pt. implement or rear wheel weights or load the rear tires. All will help when plowing snow. I use loaded tires, chains and a 3 pt snowblower for counterweight and plow with eitherthe bucket or a front snow blade.
/ Rear wheel weight #3
If you add too much you'll experience steering issues. Until that point, the more the merrier.
/ Rear wheel weight #4
I have a Kubota M6040. 820# grapple on the FEL, 1550# of Rim Guard in the rears, 1100# Rhino rear blade on the 3-point. All adds up to - 10,100 pounds. Keeps my R-1's firmly planted when I plow my driveway. Even the hard frozen berms don't stand a chance.
/ Rear wheel weight
Just hooked up the 600lb tiller last night because that was the heaviest thing I had easy access to. What a difference that made! I don't want to fill the tires because one of my main uses is mowing horse pasture in the summer. I do not want to add to the compaction.
Now I have to re-think my winter time storage so that I can leave the tiller hooked up for snow plowing duty.
/ Rear wheel weight #6
I rarely need any rear wheel weight on my little JD2210 pushing snow. But if I do I hang suitcase weights sideways on the 3pt arms. Quickly adds weight without adding length. 3pt attachment weight gets bulky real quick.
/ Rear wheel weight
Yeah I grabbed what I had. I am getting a delivery back into a barn. Needed to move some snow out of the way. So mostly out in the open. Would not work clearing snow off the drive where space and manuvering is more necessary.
2003 Freightliner MC 331 2,800 Gallon Fuel Truck (A64194)
2003 Freightliner...
AGT Cat 320 Coupler (A65583)
AGT Cat 320...
John Deere 15' Rotary Hoes (A66408)
John Deere 15'...
2013 Chevrolet 3500 Dually (A62613)
2013 Chevrolet...
Hr:1033.8 (A61572)
Hr:1033.8 (A61572)
2005 Chevrolet Silverado 2500HD Duramax Diesel (A66408)
2005 Chevrolet...
