Rear Blade Rear Blade Tips
/ Rear Blade Tips #21
Neil-
JJT is right. If you first take the entire area to grade, then call in the truck(s) and have them spread an inch or so of road base, you will end up with a finished product that is more uniform, will last longer, and will require less effort on your part. You will need to make sure there are no trees/wires in the way, as these trucks require considerable vertical clearance while dumping.
<font color=green>stan</font color=green>
Root Rake Loader Attachment (A59228)
Root Rake Loader...
JOHN DEERE 644K WHEEL LOADER (A58214)
JOHN DEERE 644K...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A61307)
Neckover GL24-2-7K...
2005 LEEBOY 685B MOTORGRADER (A62129)
2005 LEEBOY 685B...
pressure washer, and trailer (A56859)
pressure washer...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A61307)
Bulk Lot of NEW...
