Rear Blade Rear Blade Tips
/ Rear Blade Tips #21
Neil-
JJT is right. If you first take the entire area to grade, then call in the truck(s) and have them spread an inch or so of road base, you will end up with a finished product that is more uniform, will last longer, and will require less effort on your part. You will need to make sure there are no trees/wires in the way, as these trucks require considerable vertical clearance while dumping.
<font color=green>stan</font color=green>
2015 KENWORTH T800 TRI-AXLE (A65643)
2015 KENWORTH T800...
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
(12) 4.5"x9' Steel Posts (A66408)
(12) 4.5"x9' Steel...
New 2x27 Ratchet Strap (A65583)
New 2x27 Ratchet...
New Quick Attach Power Spreader (A65579)
New Quick Attach...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
