Oil & Fuel Reading Hydro Filter Innards?
   / Reading Hydro Filter Innards? #11
Does anybody out there make magnetic drain plugs that will fit the tractors? Got them on my BMW motorcycle trannies, and they always tell a tale. Usually just some nondescript fuzzy stuff sticking to it. If you get slivers or chunks you know you have trouble brewing.
They are very easy to make. Go to Radio Shack or your prefered purveyor of finer magnetic wares and get a few 3/16" or 1/4" diameter magnets about 1/2 inch long. Select a drill bit that's line-on-line or just under and drill into the bottom of your drain plug. Use a bench vise to press the magnet into the plug. Or you can drill a tad oversize for a loose fit and secure the magnert with Duro 2 part epoxy. That's how my 1971 SAAB 99 g-box plug came from Trollhatten.
I have used both methods & prefer the epoxy way. Every new (to me) car I get receives this treatment both in the engine and transmission plugs. It transforms an otherwise routine oil change into a diagnostic event. If you like that sort of thing.
-Jim
Dennis...
Should work... but coffee filters are S L O W in passing oil... KennyV
KV,
OK. What would be the best option for this job? Would need to be something that did not dissolve into the oil and would catch the fines. I was thinking of those shammy towel things that are likely made of poly-pro.
Dennis
   / Reading Hydro Filter Innards? #13
If you know someone in the restaurant business, get a firer oil filter ... they are perfect for this, they look like a giant coffee filter ... KennyV
KV,
Perfect! Off to the restaurant supply house. That and a big funnel and a colander to keep the filter off a hard surface and flowing.
Thanks,
Dennis
They are very easy to make....<snip> It transforms an otherwise routine oil change into a diagnostic event. If you like that sort of thing.
-Jim
Jim,
I will do that for sure. Easy do it yourself and no shipping charges.
And, I *KNEW* I should have gotten that drill press vice when I was at Harbor
Freight last Saturday. Dangit! No I have to go back again.....
Thanks for the simple and great idea,
Dennis
   / Reading Hydro Filter Innards? #16
Dennis,
Glad to be of help! Now your next oil change will be an event you can look forward to.
About the filters - when I did my 50 hr service I dumped the hyd oil into a big Rubbermaid tub, trolled it with a magnet & got bupkus. It was almost colorless & clear as water and had no burned odor at all, so there was no way I was going to replace it. I ran it through a very tight weave, clean cloth stretched over a funnel set in the tranny fill hole. It helps if you wash & dry the underside of your gearbox before draining to get all the non-magnetic dust & stuff off. Lifting & pouring was awkward, but it went off with out a hitch. Wish I had thought of food sevice filters - thanks, Kenny for that idea.
Jim
2016 Chevrolet Express 2500 Passenger Van (A55973)
2016 Chevrolet...
500BBL SKIDDED FRAC TANK (A55745)
500BBL SKIDDED...
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
1997 international 4900 DT466E (A56435)
1997 international...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
