WinterDeere
Super Star Member
- Joined
- Sep 6, 2011
- Messages
- 15,067
- Location
- Rural 'burbs, north of Philly
- Tractor
- John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
My log splitter manual spec's replacement of the hydro filter every year, which seems totally excessive, when the hydro filter schedule on every tractor I've ever owned is 400-500 hours.
While I'm usually inclined to just follow the schedule, the thing is both expensive and a PITA to change, as it's slung off the bottom bung of the reservoir. As soon as you unscrew it, the reservoir starts dumping thru the filter housing.
I change the actual hydro oil every 10 years. The manual doesn't specify a schedule for that, but that's probably close to 500 hours for me, and the stuff still looks clean and dry when dumping it on that schedule. I think water is the primary enemy of hydro fluid in a log splitter.
I'm leaning toward just doing this filter every 5th year, or even every 10th year with the hydro oil (actually ATF), as there's no dirt entering the system of which I'm aware.
