Raising an extension ladder
/ Raising an extension ladder #1
RobA
Platinum Member
Chester County, SE PA
Kubota L5030 HST
Has anyone ever used the bucket of their tractor or the bed of a pickup to lift an extension ladder to reach higher? Is this one of those things that's not exactly safe but people do it anyway?
I need to change out a light fixture at the peak of my barn. It's about 24 feet up and my ladder won't reach high enough. I've rented a portable man lift before but wanted to avoid doing that.
/ Raising an extension ladder #2
No comment. ;)
/ Raising an extension ladder #4
Could you do it from the inside of the barn if you made a small door to reach through? Or remount the light on a small door that swings inward? And maybe a platform inside that your ladder can reach.
Bruce
/ Raising an extension ladder #5
No but I've seen it on YouTube 😆😆
Watch c/l and find a taller ladder. How high are we talking? I have put a ladder on a flatbed truck for about 4' if the conditions were just right, but that was back when I was still bullet proof and ladders and scaffolding was used daily in my building business.
/ Raising an extension ladder #6
On one hand, the bucket is a good rigid flat surface and the ladder’s feet can’t slide away from the building...
....but on the other hand...
/ Raising an extension ladder #8
Use a pickup truck instead
/ Raising an extension ladder #12
Never... but I have laid a ladder on the roof and used my bucket to keep it from sliding down! Had to use another step ladder to reach the bucket so I could access the other ladder. Did I mention that I hate roof shingles???
(photos Sunday night when I can access my other computer...)
/ Raising an extension ladder #13
Local church has very stout 12’ folding wood ladder. At least 75 years old. Once upright there is a wood section that is raised vertically up the middle another 8 ft or so. Like an inverted Y. That second section is one scary place to be.
/ Raising an extension ladder #14
I still raise my bucket all the way up in my barn, then lean a ladder against it and climb up to change bulbs.
/ Raising an extension ladder #15
The cost of that man lift is minuscule when compared with the hospital bills, and six months in a cast.
/ Raising an extension ladder #16
If the back of the truck would be enough difference to get the job done I wouldn’t think twice about that. The loader is a little sketchy but I’d probably still do it.
/ Raising an extension ladder #17
Just did this today to work on a metal roof. Felt very stable and safe even though it looks like a real rig job. No other good way to get up to the ridge in this case.
/ Raising an extension ladder #18
By the way, I used a couple timbers to brace under the bucket to avoid leak down. My loader will drop 1-2" after about 20 minutes, which isn't bad, but I didn't want to be worrying about that while up there on the roof.
/ Raising an extension ladder #20
