Radon gas anyone?
/ Radon gas anyone?
Odd your level went up. Maybe you have attic air getting in to your house? Get it through the roof and keep measuring.
The problem we all face is the unknowns. The entire system is assuming there is a path for the gas saturated air can be pulled. But also, there has to be replacement air. Otherwise it's like placing your hand over the end of your shop vac.
I saw a New Jersey report on failed systems and there was a lot of detail on how they accessed suction. A potential experiment; 1) see/feel how much air is exhausting at the discharge in attic. 2) If you were to place your fan on to short pc of pipe a your cored hole, you can see if the hole is allowing air to be pulled, loses compared to attic level. If you slab is sealed to damp clay, you may not pull much of anything. In any case, in this new Jersey case, they drilled several 1/2 holes around the slab to see how the draw varied.
/ Radon gas anyone? #62
Odd your level went up...
OH, fart!!! I did not make that clear, I drilled the hole, left it open without hooking up the fan. It was just a 4" open hole in the basement slab that caused the reading to go from 11 to 18 parts... Sorry about that!!!
The rental place closed at noon, so I had to drill the hole before everything else was hooked up. In fact, I had not done anything in the attic.
I have not gotten a reading after hooking everything up, and turning the fan on. I plugged in the fan, re-set the radon meter, and walked out to my truck and drove home. Plan is to head up there this weekend and see what the reading is (well, that and patch the roof shingles, hook up another gutter down spout, etc., etc....)
/ Radon gas anyone? #63
I just bought a meter, get 2 reading in my basement, alarms at 4.
/ Radon gas anyone? #64
:cool2: :drink: :dance1: :wizard: :united-states: I was so worried that blowing the fan exhaust "at" the crack of the ridge vent... was NOT going to work but it works enough for me :D I have the meter in the basement to see what it is down there.
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
2013 CHEVROLET SILVERADO 2500HD (A63569)
2013 CHEVROLET...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
2012 MACK CHU (PINNACLE) (A63569)
2012 MACK CHU...
Adams Under Truck Conveyor (A63118)
Adams Under Truck...
Gehl Mix-All 95 Grinder Mixer (A64047)
Gehl Mix-All 95...
