Radiator hose "snapped"
/ Radiator hose "snapped" #81
It's not worth the risk of over heating your machine by having the repair give away while you are working away from the house.
/ Radiator hose "snapped" #82
You'll NEVER clean it good enough for any kind of "glue", including JB. A radiator shop may be able to "weld" it, but I doubt it. A new one is in order, I believe.
I've fixed them. Not saying it's my first choice. But sand it, carburetor cleaner the area, burn with propane torch, wire brush it off, she be clean for epoxy.
/ Radiator hose "snapped" #83
I bought a plastic welder. It works good on those projects.
/ Radiator hose "snapped" #84
Not only that a radiator is under pressure not like a plastic jug with just fuel sitting in it.
/ Radiator hose "snapped" #85
I was thinking the tapping idea....not sure how that would work in the radiator as it "seems" to be plastic, at least at that connection point. New OEM radiator = $1000...Bobcat is crazy, but I might be stuck. I'll pull the radiator and see what I'm working with...maybe a shop has some ideas then again, need to find a radiator shop near me, lol.
Thanks all
I'd measure the size of the radiator and try to find one in a junk yard. Some of the smaller cars should be close to the same size. Just check inlet and outlet positions and try to find a metal one. Junk they make now days....another reason to buy old.
John Deere 5075E Tractor w/ John Deere 520M Loader (A64047)
John Deere 5075E...
Kubota L2501 (A62177)
2008 CATERPILLAR D4K XL CRAWLER DOZER (A64279)
2008 CATERPILLAR...
2025 SAWYER 85BP20 20FT T/A ENCLOSED BUMPER PULL TRAILER (A59912)
2025 SAWYER 85BP20...
2013 PETERBILT 367 WINCH TRUCK (A63569)
2013 PETERBILT 367...
6 1/4 INCH OD 90 DEGREE ELBOWS (A63569)
6 1/4 INCH OD 90...
