Quick Hitch
/ Quick Hitch #21
I use a QH for everything but still find it convenient to have the implements level when hooking up. For the stuff that's outside, I have "landing spots" that I have level with concrete blocks or 4x4's.
I built either tiny sheds for some equipment that needs to sit outside, and for others I just built a roof panel that sits right on the equipment, with the equipment sitting on concrete blocks:
/ Quick Hitch #22
View attachment 3328464 View attachment 3328465
Well if that isn't the cutest little shed for a brush hog that I've ever seen, lol. Would probably be a pain to hook up inside that shed if not for the quick hitch eh?
I still don't have a consistent storage solution for keeping my attachments out of the weather. It really takes a lot of roof area to keep 4 trailers and 10 attachments dry!
/ Quick Hitch #23
I built it before I had the quick hitch, and it wasn't terrible, except that you had to walk around the front of the tractor to get from one side to the other, when hooking up or disconnecting.
That she is actually up for grabs, if anyone wants it. I already sold the brush hog, and no longer need the shed.
/ Quick Hitch #24
The only "attachment" I use that would really benefit from a quick hitch is the concrete ballast block. That thing is a royal PIA to get hitched. Mostly cause I don't have any level spots to drop it.
Top and tilt is the answer for unlevel ground.
/ Quick Hitch
I found it Tractor Supply, want to make sure it will work before ordering
SpeeCo Cat 1 Quick Hitch Adjustable Top Link Bracket​
4.8(33)
Item # 2531920
$170.99
/ Quick Hitch #26
For those running w/o bushings, or bushings lacking the larger bulb at the end, any issues with side-to-side play allowing the implement to fall out of the quick hitch?
The opposite side of the hitch controls the implement. If the implement is pushed left, the implement frame hits the left hook, which keeps the right pin from sliding out of the right hook. The linch pins only keeps the bushings on the pins. They doesn't stop side to side movement of the implement.
Bruce
/ Quick Hitch #27
/ Quick Hitch #28
I tried a conventional quick hitch like the one pictured above...connecting a drive shaft was too hard for this old man. Pats or Euro hooks is a better option.
/ Quick Hitch #29
I find it easiest to hook up the PTO when the hitch and the implement are still maybe 10-12 inches apart.
Bruce
/ Quick Hitch #30
A photo showing why I need the extra slack allowed by a chain at the upper link location. The top of the mower was jammed against the QH which lifted the rear tires off the ground, I couldn't climb the grade. (and risked damage to the mower's upper link). Lifting the mower still didn't help.
It was necessary to shorten the top link to the tractor, to proceed.
p1350118rym186dmow5-jpg.163272
/ Quick Hitch #32
4.8(33)
Item # 2531920
$170.99
That's a good price for a quality QH. Like Tinhack I got the HF QH back when they were about $75 but now at $140, not a bargain.
Another plus for the Speeco: unlike many of the clones, it's hook is offset away from the mounting holes to make room for an implement's upright straps at that location. I finally put a Speeco hook on my HF QH, it works better that way. Here's a post with photos in an old QH thread describing this.
/ Quick Hitch #33
On my ballast I put a short piece of 1 inch water pipe on pin and secured it with bolt and elastic lock nut.....
But for ballast is anything gained by having a precision fit at the lower pins?
If the ballast is wide enough to just fit between the QH's lower hooks so it can't fall off, then slop there shouldn't affect the usability of the ballast - no?
/ Quick Hitch #34
Alternatively you could replace the long angled braces on the mower with chain
/ Quick Hitch
I'm going to order it and if I need this adapter I can make it work. Also some 3/4" pins to replace bolts on hook to adjust up and down quicker if needed. Thanks!
All my attachments thus far, don't think I'll ever need a tilter. Rake is 4', 28" from pin ends.
/ Quick Hitch #37
My lower ballast support is based on CAT 1 draw bar.... Good design process make easy work if its done with some forethought....
/ Quick Hitch #38
I used straight pins on my ballast box - the width just fits between the hitch arms, so there's no way it can slide off either way. i deigned the cage with a notch to suit the top link placement compared to the bottom pins. One of these days i'll empty out the blocks & paint it. Been saying that for a few years so far...
/ Quick Hitch
I watched "Dave Knows How" on you tube that shows how to use QH with older non QH ready attachments. Guys knows his stuff!
/ Quick Hitch #40
A photo showing why I need the extra slack allowed by a chain at the upper link location... It was necessary to shorten the top link to the tractor, to proceed.
As jyoutz said earlier, a hydraulic top and tilt function is the QH's best friend.
I actually didn't bother with tilt, I store and use my implements on level-ish ground. But I have and use the hydraulic top link, constantly.
USA Flag Metal Sign (A64557)
USA Flag Metal...
JOHN DEERE 325G SKID STEER (A65053)
JOHN DEERE 325G...
2007 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2007 INTERNATIONAL...
2022 EZ-GO ELITE...
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
2015 A and A Melters A-110 Towable Hot Rubber Melter (A64553)
2015 A and A...
