quick attach forks for Kubota 3130
   / quick attach forks for Kubota 3130 #1
gfilion
kubota 3130 L series
I have a set of forks from an old fork lift that we modified to use on the 3pt hitch of my kubota 3130 tractor. I wanted to see if i could adapt this to fit on the quick attach LA723 loader on the front end for obvious reasons. Does anyone have a drawing specification for any quick attachments that would help me modify the unit. I was thinking of a drawing detail that illustrates the position and size of the "cups" that the quick attach loader would connect to. It also has the quick attach locking pins. Any suggestions would be appreciated.
that sounds like a great idea but the link you sent me doesn't seem to show a quick attach frame for a Kubota loader. I know nothing about skid steers so perhaps i need an education. If you are saying i can purchase manufactured mounts that can be welded to my existing attachment that is exactly what i would be looking for. Please advise.
   / quick attach forks for Kubota 3130 #4
I took it to mean you already had the SSQA adapter on your LA723 loader now? I am confused. Lets ask this: does your bucket quick attach to your loader arms now? Or is it pinned on? It is QA's then you already have the QA adaptor on the loader arms (two big gray levers that actuate 2 vertical beveled pins that fit in the recess's on the bucket?)
If that is the case all you need is one of those mounting plates to weld onto your forks and you are good to go. Now if your bucket is not QA now and it pins on directly to the loader arms then you need to see your friendly Kubota dealer about the QA adaptor (400-500 dollars) or get one of the generic ones (several manufactures) or construct one yourself. (More than I wanted to tackle) I did convert my bucket to QA this summer. here is the thread:
http://www.tractorbynet.com/forums/customization/208653-so-you-think-converting-pin.html
fill us in with some more info or photo would be great
thanks
James K0UA
   / quick attach forks for Kubota 3130 #5
I think Kubota used to use a proprietary quick attach design that wasn't SSQA compatible?
I have a QA Loader LA723 complete with QA bucket L2240. When i looked at the link you directed me to it did not appear that the adaptor would fit Kubota's QA system. This would be the direction i want to go for sure. I seem to be having problems posting a picture.
   / quick attach forks for Kubota 3130 #7
The Kubota SSQA is the same as everyone else's SSQA. The question is do you have SSQA or a propriatary quick attach? go down to where you post and click on manage attachments. to upload pictures. make sure the pictures are less than 1 Meg in size.
James K0UA
I will try to find some pics to upload.
   / quick attach forks for Kubota 3130 #9
Here is the standard
SAE J2513
  • Skid Steer quick attach plate dimensions.pdf
   / quick attach forks for Kubota 3130 #10
Does it look like this?:
   / quick attach forks for Kubota 3130 #11
My L3130 has the SSQA on the FEL. I bought a set of forks that had the SSQA and the seller said they are all the same, except the width, some SSQA are narrow and some are wide. Your bucket is standard SSQA, just measure the width to make sure you get the right one.
   / quick attach forks for Kubota 3130 #12
Go look at this video, which shows you how to covert a Pin on to SSQA bucket setup. But the reason I am posting the video is so that you can see if you have the Universal Skid Steer Quick Attach or the Proprietery Quick attach as shown by the photo of the previous poster Baby Grand. I think you have the Universal SSQA. but we are not sure. In this video is a good look at the Universal SSQA that Ted is demonstrating. Note the 2 large gray levers sticking up in the unlocked position.
How to Convert Pin On Style Loader to Universal Quick Attach - YouTube
Also you can play this video, as Ted demonstrates the pallet forks they
are also SSQA, this is what I "think" you have on your tractor. But without a photo we cannot be sure. It may be a Proprietery system But watch the video and you can get a better idea how all this works.. The interesting part showing the disconnection and connection starts at 3:35 on this video. hope this helps.
Construction Attachments 42" Compact Tractor loader Pallet Forks CAL-1PFCMPSM42
James K0UA
2016 DRAGON SAND CONVEYOR (A58216)
2016 DRAGON SAND...
2005 WESTERN STAR DUMP TRUCK (A60430)
2005 WESTERN STAR...
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
2021 CATERPILLAR 299D3 XE SKID STEER (A60429)
2021 CATERPILLAR...
(20) WOOD PALLETS (A60432)
(20) WOOD PALLETS...
