Quetion for all you electrician kind of guys
/ Quetion for all you electrician kind of guys
Hmm, just got home and a utility company truck was pulling out of my driveway. I drove back to my newest barn and, guess what? A brand new meter. And, with nothing attached to it, it doesn't turn. Now I'm really suspicious of them. I'm thinking I should try the same test with my home meter.
/ Quetion for all you electrician kind of guys #22
Give it a try... sounds like something I should do to check the meters I have...
/ Quetion for all you electrician kind of guys #23
We had an issue along these lines some years back on our farm. We were getting VERY high electric bills. We checked and rechecked about everything, but still couldn't find out "where" that electricity was "going to." We even went away -- out of town -- with EVERYTHING turned off. We assumed that would prove that the bill could go way back down -- but by golly, we STILL got a high bill.
This went on for several years --- monthly electric bills of about $300, when it should have been about $60.
Eventually, one day I was out by the barn and saw a line of water coming in under the barn wall on one side. It was flowing under the concrete barn floor, and pooling up into a virtual flood in the field on the other side of the barn.
We used a backhoe to dig up all around the well head. Sure enough, about six feet down, there was a small crack in a fitting, which was PVC and not brass. ALL THAT TIME the well pump had been turning on and off 24 x 7, due to the leak. In fact, we had once replaced the well pump because it had died. Apparently the on/off running for years just burned it out.
We replaced the fitting for about $5, and never had a high electric again. I figured that we paid at least $200 a month for water running into a ditch, over the course of four years. We lost about $10,000 to that "little Problem." :mad: I did contact the electric company, but they offered nothing to offset my losses.
You might also see if an outside night light (sodium or otherwise), could be drawing power.
I also was told by various experts that even if all your lights are off, freezer and fridge unplugged from the wall, etc, you will still darw a small current just to keep the service hooked up to the property.
Hakim
Hakim
Yeow! That "little" leak sounds like it ended up being a rather "big" expense.
You are correct about 'vampire' items plugged in that draw a small amount of current. Believe me, I've done quite a bit of net surfing and asking around in the last couple of days. Again, I'm by no means an electrician or any sort of authority, but I've asked a lot of questions in the last couple of days about this subject. It seems that most people who are well educated in the field tell me that most anything that has a transformer anywhere in it's circuitry will be a 'vampire' as well as most anything that has an 'instant on' feature. They compared it to a computer in sleep mode, saying it wasn't drawing much at all but was sitting ready to be awakened and be ready to use right away.
I do have 4 dusk to dawn lights and, at current prices, they cost me about $4.73 each a month to run on average. So I'm aware I'm spending about $20 a month for night lighting. I'm okay with that. What concerns me was the phantom electric drain and not the vampire drain (see, throwing out that lingo now like I'm some sort of expert :D). The 'phantom' drain shouldn't be there and nobody can explain it; thus the 'phantom' (sort of) replacement of my meter when I complained. A 'vampire' drain is what you mentioned; most anything that is plugged in that draws a slight amount of power without really doing anything while it's in it's 'vampire' mode.
I'm learning more now but I'm still concerned how many revolutions per hour my home meter may be turning without anything at all attached. As I mentioned, I would never know if I was being overcharged $5, $10, or $20 per month on my electric bill. Oh, did I mention how my son got a new girlfriend and stuck me with over $600 worth of additional airtime cell phone expense last month? :mad:
His number is no longer in service...
/ Quetion for all you electrician kind of guys #25
... Oh, did I mention how my son got a new girlfriend and stuck me with over $600 worth of additional airtime cell phone expense last month? :mad:
We got our teenager a pre-paid phone. We give her $30.00 every two months. That equals 300 minutes or 600 text messages or any combo if both. It taught her budgeting, time management, etc...
/ Quetion for all you electrician kind of guys #27
I am not the best one to try and explain this as I deal with the construction end of electrical linework and not so much the metering, but here goes, electric meters have what we call creep, and that is due to the magnetism in the meter it will creep very slowly until the holes line up and it should stop, if it does'nt and or makes a complete revolution something is wrong and it should be addressed by the metering dept from your power company, power companies have all kind of fruit loops squealing about their bills, most of the time it is because of something going on when they aren't home such as adjusting the thermostat 10 degrees from normal and then re-setting it before the dad gets home and the list goes on and on, but on occasion someone does have a legitimate problem that needs to be addressed, hopefully armed with this little bit of info someone will know that you have done a little research and know a little bit about what you are talking about, hope this helps.
/ Quetion for all you electrician kind of guys #28
dargo - your story makes for interesting reading- now I am interested in seeing if there is something wrong with my meter. ;) just for giggles. This is something that everybody should check every so many years of owning a house.:)
/ Quetion for all you electrician kind of guys #29
Utility companies must believe that the meters can fail or be inaccurate.
One time my house was not occupied for a number of months which caused the utility bill to drop drastically. I happened to arrive there just as the PG&E guy was swapping out the meter. He said he was swapping out the meter because there must be something wrong with it. I didn't bother to explain to him the reason for the low bills. I thought I'd let it make them crazy since the house was going to be unoccupied for awhile longer and the new meter wasn't going to change anything.
/ Quetion for all you electrician kind of guys #30
Some meters will creep, but not all do it. The utility really has no control over that creep and aren't out to get you. Most will replace the meter I'm sure. You also have to keep in mind that bad connections may cause this also. Bad connections cause heat, which is essentially dissipated power. I have seen this also, but have also seen 100's of other strange things with electricity like a bad main breaker causing creep.
If you look on your meter you will see Kh. If it's 7.2, that means your meter will register 7.2 watt hours for every revolution of the disk. So if that disk rotates once in 20 seconds you divide 3600 (seconds in hour) by 20 = 180. So you take 7.2 * 180 = 1.296 kw/hour or Kwh times the multiplier of the meter, most of the time 1 depending on the R/R or register ratio.
If you have a large service where CT's are installed a multiplier will be used since you are only metering a portion of the service. Say the CT's are 400:5, the multiplier will be 80. If they are 200:5 it would be 40 and so.
Most new meters are solid state so there are no moving parts and all digital so it's hard to do but some have the worm that crosses the display you can time like the disk.
/ Quetion for all you electrician kind of guys #31
... the meter makes 3.8 revolutions per hour, every hour, with nothing attached. ...
Now that you have it repaired, can we figure out how much money that would have actually cost you per year at your current rates?
Then let's multiply that by the number of customers they have to see the potential overcharge money they could make if everyone's meters crept like yours. I think it would be fun. :)
Honestly, I thought about doing just that. However, since there is zero chance of me getting anything back, I'm not sure I want to know.
/ Quetion for all you electrician kind of guys #33
Bet they wouldn't have been so quick to change it had it been reading higher that normal .
/ Quetion for all you electrician kind of guys #34
Hakim fessed up about his well problem. ;)
/ Quetion for all you electrician kind of guys #35
And then there was the time when I was doing a total remodel on a rental. I'm talking to the studs, new elect, plumb, windows, the works. I don't remember how long it took but it was probably close to a year. Hay what can I say I'm no Eddie Walker and at my age I'm only good for 4 or 5 hrs a day. Anyway PG&E apparently assumed there must be some error in either the meter or the meter reading because one month I received a large utility bill, I don't remember now the exact amount but it was close to $2000. They just went back to previous year's usage and estimated what the normal usage should be and sent me the bill.
Now we didn't have any trouble explaining that the place was unoccupied and they reversed out the charges, but I was amazed that they would even do that in the first place, just make up a number!!!
/ Quetion for all you electrician kind of guys #36
It would be about 15 kwh / month or 186 kwh / year * .10/kwh about $18.60/year IF it's a constant 3 revolutions per hour.
Normally the Public Utility Commission will allow you to re-bill 6 months in the utilities favor, or all the way to the beginning if in the customers favor.
If you owned a store and someone bought something and brought it back saying they didn't use it and you had no way of knowing, would you believe them?
/ Quetion for all you electrician kind of guys #37
PG&E has done that to me several times... sometimes they estimate usage and other times they have replaced the meter because I was overseas and only had a refrigerator going...
I caught them one time at a rental... they came in and read the meter to establish new service and 20 minutes later the regular meter reader came by and read the meter... my usage for 20 minutes at a vacant single family home was $22.
I complained and told them there was no way I could use that amount of electricity and gas in 20 minutes... turns out they attempted to bill me all the utility usage from the time the previous tenant vacated and had the service taken out of their name...
Apparently this is standard operating practice for utilities... they get paid no matter who they get paid from...
I've called PG&E before to report that a tenant has moved out and squatters moved in and they would not talk to me unless I was willing to put service in my name... I wished them well... about a month later I got a call asking if I know the whereabouts of the previous tenant because of a $440 outstanding bill... I told them I had no idea... but I had called to let them know the tenant had moved out the month before and was told they couldn't discuss it with me...
Sometimes I've had to appear in person with ID and my Grant Deed just to get service turned back-on... It's kind of a one way street with the Utilities now... they will call and ask all kinds of questions about a customer but will not divulge any information in return...
VOGELE VISION 5103-2 ASPHALT PAVER (A60429)
VOGELE VISION...
Peterbilt 377 Semi-Truck (A61306)
Peterbilt 377...
2017 Ford F-150 Pickup Truck (A59230)
2017 Ford F-150...
2020 FREIGHTLINER M2 26FT STAKE BODY (A59905)
2020 FREIGHTLINER...
2019 American Signal T465 Towable Solar Message Board (A59228)
2019 American...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
