Buying Advice Questions about potential purchase, not sure where to start
   / Questions about potential purchase, not sure where to start #91
You're going to run into smack-dab into the biggest question that gets asked. How much power is enough? Or the corollary, how much power is too much.
I have an older model Kubota BX 2350 that I got used and love. It's what I need. I have 3.14 acres, but it's all flat. I don't have boulders. I could use it for mowing, but honestly a lawn tractor isn't nearly as good as a ZTR mower for mowing something this sized. It just isn't.
You'll find that a sub-compact will do less damage to your grass, if you care, while a compact+ will do more but have more capability (lifting capacity, etc.) This is important to me where I use it for carrying misc lumber, put in some fence posts with a PTO rear auger, pushing snow (Pennsylvania), carrying mulch into my raised bed garden area (smaller tractor is better here), digging smaller holes (put in a greenhouse), moving gigantic 300 lb pots around with the boom lift, occasionally moving small pallets of stuff with a pallet fork, and some misc tilling. I do this all over my lawn so I have turf tires and the reduced weight makes a difference in lawn damage. I never use it for cutting grass. If I had a field I'd get a brush hog or flail or rear mower, but it's a lot slower for cutting grass because there's so much steering slop vs precise turns on a ztr. I also use the tractor with a carry-all a LOT, and am lately using it to ferry around a 50 gallon rain barrel to water some new plantings in the drought.
You'll find that, head-to-head (Youtube videos for "Tractor Time with Tim"), that (from memory). There's a lot of good content there.
The JD sub-compact has more front bucket lift capacity
The Kubota has slightly more rear lift capacity.
The Kubota is easier to operate the bucket and do tilt/lift operations at the same time (his experience). The JD is harder to find the sweet spot between lifting and curling (but can be learned)
The JD has more niceties with the drive-over easy-attach deck (if that matters)
I think the JD had slightly more pulling capacity, but honestly don't remember (the BX has more than enough for me)
   / Questions about potential purchase, not sure where to start #92
Hi!
I will have to try your recommendation with the chain and hook. I have all of those tools at my disposal right now, and will be giving this a go this weekend :) My broad fork is how I've been getting at the rhizomes but it's just an overwhelming uphill battle that I am constantly losing. Due to the huge rocks just beneath the surface of the soil, my brush cutter with the fitted blade has become a sketchy weapon - I never know what I'm about to hit.
I will look into what you suggested as well, my cursory review of what was available had me thinking the BX2380 would be the best option for my needs and then came all the (overwhelming) options about add-ons. I think that can be covered by talking to the dealer directly, I just want to know what base version I should seek out. Do you think a front loader (is that the bucket attachment?) would be something to immediately purchase?
Thank you so much for your thoughtful reply! Such great advice!
Look at Yanmar, Holland and other non-best brands. I have a used 2500 Yanmar with FEL (front end loader) made in 1977, bought about 15 years ago. You will find uses for the FEL than you ever thought of. Yanmar also makes most of the parts for John Deer (JD) including engine and more. Buying from elderly or others looking to size down to move to Florida or someone to move up to a bigger tractor (always go at least 1 size larger than you think you need) I live on 2.6 acers in East Tx. Up till 20 years ago, I knew nothing about tractors and no one to learn from. Tractor by net, books and computer helped me a lot. Now I know about as much as a 6-year-old farm boy (actually he is much smarter because he has a dad to teach him) A lot of tractor people will even deliver it to you, and most will give you a crash course on how to operate it. And I do mean "crash course". Tractor and implements are "VERY DANGEROUS" but follow all safety rules, suggestions but most of all the advice from this site you will love it.
If you have a neighbor that is willing to go with you to check out a tractor, take advantage of it. Remember, there are no stupid questions, just people too stupid to ask it.
As for this site, read about everything. You never know when it might pertain to you.
(What is that little lever under the seat for?) You too will learn what FEL means.
Also check out main@yanmar-tractor-owners.groups. Not just for Yanmar tractors. Lots of experience, and will answer all your questions(yes, even the stupid ones).
Best of luck,
John
   / Questions about potential purchase, not sure where to start #93
Any tractor other than JD, they are moving to Mexico, that means JD employees out of a job and cheap Mexican labor. I'll never own a JD.
??? So, you'd own a Mahindra (India), a Kioti (Korea), Fendt (Germany), or Kubota (Japan), but not the one brand that still makes more tractors in the USA than all other brands? :rolleyes:
To be fair, Kubota does make some tractors in USA, but most of the CUT's they sell in USA are built in Japan. The reverse of Deere, who makes most of their products in USA, but is moving more to Mexico in the near future.
   / Questions about potential purchase, not sure where to start #94
To start, I haven't read all 9 pages so forgive me if I say something already said.
I will disagree with @rScotty on one thing. While rotary cutters can fling stuff 360° (yes even under the tractor) and often quite far and VERY fast, a flail rotates perpendicular to travel, everything goes out the back and there is little that gets thrown. On the other hand, you can back a rotary into brush and it will cut, a flail won't go in as far and therefore won't cut as much and won't really cut well until you move forward. And you want to know what is in there before you back in, rotary blades are heartier than flail knives or hammers. On the other, other hand, I can back my flail to the fence and cut the "corners" of the area which is impossible with a rotary.
Additionally, my 5' flail makes great multi use 750# rear ballast - which you need, along with loaded rear tires, if you do anything substantial with the loader. The flail is quite close to the machine so as a unit is easier to store if you don't have a lot of space. My 35 HP Mahindra 1533 with forks (get these!) or bucket plus flail fits in my barn bay with the door closed. I would have to remove a rotary cutter to house the tractor.
I did not fork over the money for front hydraulics and a grapple though they would be very nice to have. But $$$$$ and as mentioned you would need a lightweight grapple if you get a small tractor. I'm sure I would not be happy with a subcompact, too little lift capacity (pay attention to this as you compare tractors, my 1533 lifts several hundred pounds more than an equivalent Kubota ... but the Kubota has more PTO HP ... SO many variables!). I use the forks to carry downed trees if pulled out of the woods. I cut them to 8' - 12' depending on diameter for bucking to 16" back at the barn. And I've used them to pry rocks out of the field. I made firewood dry/store racks that hold 1 run which I put on the landing of the second door to the enclosed porch as needed so I don't have to go out in the cold and snow to get wood. Much less handling that way - splitter to rack to stove. Forks are also needed to get all the attachments you end up buying later off the delivery truck ;)
You will probably want a quick hitch for the rear attachments, no way I could manhandle the flail to get it aligned to the tractor. Some tractors do have telescoping 3 point lift arms which would make it somewhat easier.
   / Questions about potential purchase, not sure where to start #95
I will also add that I knew NOTHING about tractors until 5 years ago. I bought new, figuring I didn't need to learn how to fix it soon after buying. I learned a lot watching YouTube videos. TractorTimeWithTim is where I started, he had a JD 1025R and does way more with it than one might expect, he now has a LOT of tractors and related equipment. He grew up on a farm so all these things were not new to him. Also TractorMike, I learned a lot from him too. In the end, it is time with the machine that you'll need to get comfortable. Be the tortoise, not the hare. As was noted, even the small machines have a LOT of power compared to our puny human selves. Easy to break things.
John Deere and Kubota are both great tractors. If you get a backhoe be sure to get it with a thumb. Get 4-wheel drive. Get loaded tires. A cab is a nice luxury if you expect to use in very hot or cold weather.. Of course get a loader. Finally, decide what is the maximum/heaviest tractor you can afford and then buy the next larger one.
Please excuse this dumb question - what is a thumb? I would love to get a backhoe - would you recommend getting that when I make the initial purchase if I decide to purchase new?
Thank you for your post - this resonates - but over the last few days, I have learned so much! What books do you recommend? I've begun to watch YouTube on the subject from the suggestions provided and it's been very illuminating, I just retain information better by reading as it forces my concentration.
Thank you! I'm building out a playlist to run based on everyone's excellent recommendations :)
Again, thank you everyone so so much for all the insight. This is such an amazing resource and you all have taught me so much already!
   / Questions about potential purchase, not sure where to start #97
Loader controls are often referred to as "lift" and "curl", the first being the hydraulic cylinders that lift the loader arms, and the latter being the hydraulic cylinders that dump or roll the bucket fore/aft. When directing an operator at the controls, we typically use the wrist to show curl, and movement from the elbow or shoulder to show lift.
But those picking up logs or brush piles often want some way to "grip", and because gripping with the hand is the easy way to demonstrate this when directing an operator, the implements used to grip items are usually called a "thumb".
In most cases, you'll find these on excavators and backhoes, but also found on pallet forks (often called "grapple" in that case):
They're super-useful on larger CUT's, but I'd honestly not put one on a subcompact or even a Series-2 JD. They add weight, which will reduce your loader lift capacity, and are targeted for picking up mostly heavier items. Grapples and thumbs are very useful, but I'd argue more so on larger machines than what you're probably shopping.
No suggestion on books, but on YouTube, any beginning shopper can benefit from the older episodes of "Good Works Tractors". The videos have progressed more toward selling things than instruction, as time goes on, so I bailed on watching that channel a few years ago. But the earlier videos were good.
Like wise with "Tractor Time with Tim", which was very good specifically for those looking at sub-compact tractors.
There are always new ones popping up, I haven't really watched much since the last time I was shopping for my latest new tractor, 2018/19.
   / Questions about potential purchase, not sure where to start #98
I did not see anyone bring up the. TLB. TRUE - tractor/loader/backhoe. Made for working on construction job sites - they tend to be heavier duty. Higher flow hydraulics, etc. Just something to consider. If you have need of a backhoe - these are not like the add-on, subframe attached backhoes. Much more power. For real digging/moving things - trees, rocks etc. Get the hydraulic thumb - HUGE advantage. And - for front end loaders - there are all kinds of options - need dependent. root or log grapples, clamshell buckets, etc.
I just think it is a more versatile machine. BUT....my needs are not ploughing or grading. Tho I can remove the backhoe, and do those things if I needed.
   / Questions about potential purchase, not sure where to start #99
Maybe a bit of overkill for the OP's described needs and budget? :oops:
   / Questions about potential purchase, not sure where to start #100
I agree. The little Kubota B26 has been made now for close to 20 years as an old style TLB without emissions or computers. TLBs are just like tractors, but on TLBs the backhoe is standard, while the 3pt becomes the optional attachment. Has a PTO and simple 3 speed HST transmission plus a 4 post canopy.
They tend to have industrial tires. Nice. An older one might just barely be within her price range
As for good books on general tractors and tractoring I don't know of any such. It seems an odd omission.
rScotty
Deere 335P (A53317)
Deere 335P (A53317)
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
*Selling at Royal Auction Zephyrhills, FL Location* 9, gooseneck hitch, (A59230)
*Selling at Royal...
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59575)
2017 FREIGHTLINER...
2019 RAM 5500 Bucket Truck with Versalift VST47 Boom - Cummins Diesel - 4X4 - Automatic (A56438)
2019 RAM 5500...
