Buying Advice Questions about potential purchase, not sure where to start
/ Questions about potential purchase, not sure where to start #161
QA on this JD. which the bucket practically stayed off. Nice option!! Esp. after the grandson took out the pool fence with the bucket mowing with it.:rolleyes: Which I was told to take it off after that and put it acres away in a carport! Another reason one of my tractors has a FEL. and the other it doesn't or even needs to be installed on it for that matter.
/ Questions about potential purchase, not sure where to start #162
Agreed. And I would absolutely never buy a machine with a pinned bucket for dual use as a mower, despite @2manyrocks question about the actual need to switch FEL implements, because she's likely going to find that dropping the bucket before mowing and retrieving it when done is the quickest way to make the machine lighter and more maneuverable.
Dropping the whole loader is much better yet, but even as relatively easy as that is, dicking around with hydraulic hoses for every weekly mowing gets old real fast. Dropping a bucket off a JDQA or SSQA loader is a very fast and easy compromise, and removes a lot of the extended weight that turns your machine into a bucking bronco at mowing speeds.
I leave the bucket on when mowing, it's not a problem. No big deal. Even in my orchard where I need a tight turning radius to avoid trees.
As for carrying downed trees and brush - my photo above shows logs in or across the front bucket, secured by chains, and also debris on a pallet-based platform on rear forks. I carry dead limbs too big to shred after the annual orchard pruning, and occasionally stumps. I doubt she has this much material to move.
I have put on my front clamp-on forks a couple of times for this orchard cleanup but usually don't bother.
Oh - related - my decorative Redwood trees sometimes shed limbs during severe storms. I cut the limbs into lengths I can lift, long and brushy, and carry them in the 4x8 trailer. In some cases I attach the trailer to the trailer ball on the front loader. Then drive backward, so I can lift the trailer to a steep angle to dump it.
/ Questions about potential purchase, not sure where to start #163
For years I cleared brush and carried it in a little trailer behind the lawn tractor (the lawn tractor sees more work as a trailer puller around here tbh)
I attached angle iron-like things (uprights from an old rack) in the corners that stick up 4' to help hold the brush, and the brush was cut to 6' lengths.
Real pain in the butt really but way better than carrying it by hand.
These days I cut to about 8', make a pile about 8'x6'x6' and then smash it down with the forks, move the tractor around over it to get the brush really well tied together, and carry it in one chunk to a good drying spot and later to a burn pile. With the forks, I can move about 10 trailer loads at once.
Much of my land is flat and open; a couple acres keep me very busy with nearly constant cleanup - and it's not nearly as wet here as in SW Washington. I don't doubt that op's going to have plenty of use for forks on a little tractor even if she's only got an acre of woods, but the good thing is that you can always get forks "later".
/ Questions about potential purchase, not sure where to start #164
What I use on the Yanmar. I believe 4'x6' Which I still use today, Exact thing you stated. Downed tree, limbs etc. used it on a Sears Garden tractor which was my lawn mower and the Yanmar replaced. I'm Using it today to hual wood off the back property. I can get more in it then the FEL..
/ Questions about potential purchase, not sure where to start #165
If you can tolerate yet one more opinion...
You've had some excellent advice. I'll start by saying SHOP THE DEALER! Check with other tractor owners and see how they have fared with the dealerships you have in mind.
One writer suggested either a Kubota B or L series and I concur. They are about the right size for what you're dealing with. I'd stay clear of the BX for a couple reasons, mainly weight and having but a single brake pedal--the steering brakes on a B and L really help you out in a tight spot. If size is not a limiting factor, go for the L-series for the advantage of greater mass which gives greater traction and stability, the 26 horsepower should be all you'll need.
Another mower option--other than the rotary cutter--would be a flail-type mower. They'll give a cleaner cut on grasses, but don't do such a good job on heavy brush.
I also agree that forks are a less-costly option for moving most things. A grapple is nice, but much more costly and requires additional hydraulic connections.
/ Questions about potential purchase, not sure where to start #166
... and if on the Deere side, I'd be looking at the 2R series, such as 2032R. In fact, that's my favorite Deere compact series, since it has better ergonomics and visibility than my larger 3R series. It's also a lot easier getting on/off the 2R, as entry is easy from both sides, versus just one side with the 3R.
Either way, you can't go wrong. Like LRT said, shop the dealer. Kubota and Deere are equally superb on design, quality, parts availability, and resale value.
Thanks @WinterDeere and @Little Red Tractor for the additional insight - I'm still here reading, and rereading, everyone's comments, posts, and advice, so I really appreciate the continued wisdom!
As an update, I'm doing a couple things this weekend (if anyone wants to know lol). Today, going with pops to a TYM / LS dealer nearby since they're not open on weekends to acquaint myself with these options. Looking at their subcompact and compact options and getting an idea of how far my money will get me. Using the list everyone helped me put together, I'm going to be primarily looking at options that offer ease of operation and utilization.
I also talked to the fella that posted the B7510. He confirmed what I suspected - they're downsizing, got it regularly serviced, and even knows the son of the local Kubota dealer. He had positive things to say, I asked a few questions when I could get a word in regarding using it. Overall, without seeing it, my impression is it had light use - he has similar sized property and had similar uses (albeit in a flatter part of town). My concerns about this particular option is the lack of QA. BUT it comes with the implements I most urgently need. Because I don't have a trailer or a way to move it, he suggested having the local Kubota dealer helping move it, so I will look into that if I decide to move forward. How often will I want to remove the FEL? There's mixed response on whether or not you all do, based on what you use it for. It'll be due for the next 40 hour maintenance soon, as well. At what point should I be concerned about its age? Also, he was a talker, basically said he would let it go for $14K - so I'll probably just go full dummy, offer $13K and see what he says - factoring in paying for transport - curious about it.
Tomorrow, I have to go to the JD dealer anyways to get the parts to for my wacker, so I'll take a look while I'm there. Also going to stop by the Kubota dealer, too, to ask them about the trailer / transport, as well as look at what they have available in my budget.
Hopefully on Sunday, I'll be visiting the used tractor with the experience of seeing new tractors to compare against.
I hope everyone has a wonderful weekend!
/ Questions about potential purchase, not sure where to start #168
I never remove my loader, but occasionally remove the bucket when it’s in the way. Everyone’s response will vary on this question.
/ Questions about potential purchase, not sure where to start #169
My Ford has a Wagner FEL. which stays on the tractor. Just the plain cool factor and the age of it was one reasons I purchased it. Old as I am!! And the way it's setup the Whole FEL comes off Intact. Literally a couple small handful of bolts. I had a shop do a split on it and replace the clutch and shifter problems. They mentioned how easy it was to work on it! The Hyd. reservoir is built into the frame also. Not super H.Duty but plenty of lifting power for my needs. Used a JD 5103 with a QA. Bucket for Yrs. and it was a nice option! Esp if you only have one tractor. Which I have a Yanmar. No FEL. @ 24hp.. The front 2wd axle spindles just wasn't made to handle one IMHO.. The sealed wheel bearings went out. The bearings fell out of the front wheels. Wasn't hard to replace them. Org. rice patty tractor from Japan. Which I use a FM. on it 90% of the time. About what it was designed for. A Mud Tiller!!
/ Questions about potential purchase, not sure where to start #171
Do you have a vehicle that can tow?
Looks like a bare B7510 is very light - under 1500# - though the loader and implements will add a bit, it won't take much of a trailer to transport. You likely have a local equipment rental place and you can see if they have a flatbed trailer you can rent (here there's a place that rents one for $100/day which is really steep for the almost-wreck that trailer is but it's a lot cheaper than buying one and using it three times ever); buy a few straps and watch some videos on how to strap a tractor down.
Though my tractor's loader has a quick disconnect and self-removal (pull pins, flex the loader hydraulics just so to get it off the loader mounts, then disconnect hydraulics), I've never removed the loader. I remove the bucket regularly, most often to swap to forks, very occasionally to use the tractor sans bucket if I'm going to be mowing in my orchard which was definitely not laid out for something as big as the tractor.
I doubt you'll ever need to remove the loader itself, and likely never need or want to remove the bucket.
If you did get a newer tractor with a QA front, it does open some doors to attachments - such as a stump bucket for point digging (to remove small trees or shrubs - or make a hole for planting such!, removing medium rocks, nothing too deep) or forks, but moving relatively light stuff, like 2-300# of logs, forks that clamp on to the bucket would work fine. There are clamp-on stump buckets but I wouldn't advise their use as I suspect either they'll fold, or the bucket will, but you won't dig much with them unless it's in really soft ground.
Yes! I have truck - I'll look into this further if I decide to go this direction. There's an equipment rental business similar to what you described in the area, I guess I'm more anxious about doing this on my own and would prefer paying a premium for help to avoid introducing chaos / danger to the public.
/ Questions about potential purchase, not sure where to start #173
...if anyone wants to know lol...
It's a tractor forum. It's what we do.
Your money will go farther with TYM / LS, than with Deere/Kubota. What you lose in the long-run is resale value and knowing that the thing will be supported both by the OEM and the handfuls of third-party vendors that surround the two premium brands.
Personally, I'd take a 3-year old or even a 5-year old Deere or Kubota over a new anything from any other brand, every time. But there's a limit to that. I would not take a 10-15 year old Deere or Kubota over most other brands, due to the way the cost of parts starts to climb after the tractor is out of manufacture.
Deere will ensure you can get parts for your tractor beyond 30 years of age, and there are countless third-party shops and junk yards that specialize in Deere and Kubota parts, both new-old-stock (NOS) and used. But the cost of Deere parts does rise with years out of manufacture, and I believe I've heard the Kubota owners comment similarly, making the usage and repair of old tractors more expensive each year.
Let's be careful. here. If you mean quick-hitch on 3-point, that's a total non-issue. Not totally necessary, and can be easily added later for $200.
If you mean no QA on loader, then opinions will vary more. It means you can't drop the bucket and pick up a snowplow or forks on the loader. That's a no-go for some people, and a total non-issue for others. I've owned both, and will never go back to a pinned bucket, but that's because I like to switch the bucket out for snowplow and forks, and also like to just drop the bucket in the barn when running around with no need for it.
But you also mention removing the whole loader. Many will never do this, and argue it's not necessary. I personally like to remove my loader when I use the tractor for spreading fertilizer or seed on the lawn, or when aerating. But my loader is stupid-heavy, and leaving it on really impacts how fast I can go on a lumpy lawn. Those with wide-open flat spaces will probably argue they never remove, or never need to remove the loader.
My personal opinion and advice to you is that I'd make sure you have at least one of these two options: either removable bucket (SSQA) or removable loader. Either one can work, when you want to whip around the yard with the mower. Personally, I'd favor a QA bucket over removable loader for your needs, if you had to choose only one option, because removing the loader and putting it back on frequently gets real old. My recommendation is based on the impression that your property is hilly, lumpy, and has some tight spaces to turn a tractor with rear-mounted mower, making a rig with mower + bucket mounted at the same time awful long and cumbersome.
So, here's the thing. Everyone says "shop the dealer", and I even repeated it above. But the reality is that you'll never deal with that salesperson or sales department again, after you buy the tractor. You will deal with their service department and parts counter, but not sales.
Someone on a prior page mentioned asking friends and neighbors about their experience, and if you're so lucky to know a few people who have dealt with a given dealer, then that's great. But I always come away from these recommendations thinking they sound good in concept, but leave the reader with a task they can't easily accomplish.
I wouldn't sweat this issue. Yeah, you can rent a trailer with surge brakes, and get it done on your own, if you need to. But paying a local dealer or any car hauler with a rollback is a cheap insured way to get it moved by someone who does it all day everyday.
If you go on your own, make sure the trailer is rated for the load, the truck is rated for the trailer, and you do a quick brush-up on weight distribution and strapping. It's not rocket science, but it is a good bit of new material to learn atop everything else, if you don't typically deal with trailering heavy items.
/ Questions about potential purchase, not sure where to start #174
My friends who love their JD and Kubota machines tend to understate the price differences for equally equipped machines and overstate the 'problems' with resale.
When you get to a certain age, resale becomes someone else's problem. 😀
TYM, LS and Kioti will do more work in the same sized tractor and will cost 10s of thousands less for the same sized/equipped machines. In general, these brands tend to be sold by smaller dealers who care more about small operators and equipment.
Kubota sells a lot to corporate entities (governments, colleges, etc.). Many of JDs dealerships are now big corporations in their own right. This can be great if your a big operator, but you may be ignored.
The other side, of course is that some some smaller dealerships come and go and leave you without support.
Bigger isn't better. Smaller isn't better. Find the one that suits you and tune out the brand loyalty.
On backhoe...just rent a mini-ex if you come across a backhoe job. Rental will run maybe $300-$350. A cheap backhoe will add $7000 and be in the way when you aren't using it.
/ Questions about potential purchase, not sure where to start #175
I agree with your principle, but not your numbers: "10's of thousands." She's shopping for a $20k package, which probably means $14k tractor + $6k in implements, or thereabouts. She's not saving tens of thousands of dollars between brands, on that.
And if you're planning on living another 20+ years, either resale or parts availability will become your problem. Some brands seem to discontinue parts after 15 years, or thereabouts, which ironically is just when your need for repair parts usually goes way up.
But that's not to say there's only one way to go, here. I totally understand why some buy other brands, especially if sensitive to up-front price or less concerned with what will happen after 2040.
/ Questions about potential purchase, not sure where to start #176
OP may not want to fool with changing attachments on the FEL. I'm not sure what attachments she'd want for the FEL anyway or if she could find them in a size that's appropriate to the B7510 since so many are designed for skid steers designed to lift much more weight.
If she was in the mood for a grapple they even make attachments that fit to the loader itself. Add-A-Grapple I think they're called. Lack of SSQA is certainly no reason to pass up a deal like that.
/ Questions about potential purchase, not sure where to start #177
The $20k total budget dictates either a SCUT, or a used CUT (it would have to be a creampuff). The 7510 is a contender. Talk with a landscaping company about delivering it for you.
I never take my loader off.
A quick attach bucket is certainly nice, but not a necessity for the OP.
Clamp on forks will be sufficient for the OPs needs.
Starting needs,
Tractor and bucket
Rear blade
Rough cut mower
That will do 90% of her work
/ Questions about potential purchase, not sure where to start #179
@WinterDeere, Yanmar's warranty is transferrable.
Transferable only once. I agree with looking at Yanmar. You can also find them used. Look for these models: SA324, SA425, SA325 or SA425. Difference between the SA3s' & 4s' is tire size only. Larger tires on the 4 series. The difference between the 424 & 425 is a accessory outlet and dual rear remotes standard on the 425.
You want rear remotes so try to find an SA325 or SA425.
Just buy a new one. They're right around the 20K price point.
/ Questions about potential purchase, not sure where to start #180
From someone who owns a tractor with a pinned bucket. I can unpin and drop my forks or bucket in two minutes on my Yanmar.
I also don't have the extra weight of SSQA eating up lift capacity and extending the load out further from pins.
Sooooo, I choose pin on over SSQA all day long. If I cared to convert it I could.
Why people keep giving poor advice, to not not buy a tractor that is better, just because of bucket attachment is beyond me.
SANY SY225C9C5KL EXCAVATOR (A59823)
SANY SY225C9C5KL...
CAT930K (A58214)
CAT930K (A58214)
2021 CATERPILLAR 299D3 SKID STEER (A60429)
2021 CATERPILLAR...
2017 KUBOTA SVL75-2 SKID STEER (A60429)
2017 KUBOTA...
2020 Chevrolet Silverado 1500 Pickup Truck (A59230)
2020 Chevrolet...
2013 Land Rover Range Rover Sport 4X4 SUV (A59231)
2013 Land Rover...
