scott_vt
Super Member
- Joined
- Oct 5, 2004
- Messages
- 8,026
- Location
- east wells,vt
- Tractor
- 1986 MF 1040, 1942 Farmall A, 1949 Farmall Super A
Mornin Dave,
Lots of good advice from all the guys here. I read through the thread quickly and didnt notice anyone mention pre drilling your 1/2" hole first with something like a 1/8" drill. I usually do this for two reasons. First and most important is that once your intended hole location is prick punched the 1/8" drill wont wander from your layout and second the 1/2" drill will go through the steel plate much easier /forums/images/graemlins/grin.gif I dont do this in the shop on my Bridgeport because I dont need to but its the way to go using a home drill press arrangement.
Any good quality H.S.S. drill set will serve you well. As some others have stated, I sharpen and touch up drills on the grinding wheel. Smaller drills are just replaced because they are inexpensive, drills smaller than 1/8" can be a pain to resharpen manually.
If you do have carbide drills, you would need a diamond wheel to sharpen them, oh and by the way, diamond wheels are quite expensive /forums/images/graemlins/grin.gif Most home shops wouldnt have them /forums/images/graemlins/grin.gif
