Question on drill bits??
/ Question on drill bits?? #21
DORMER drill bits.
I purchased a set about 15 yrs ago as they were rated as the industry best around here.
Would you believe that in my usage (kinda recreational machenist, like most TBN's) that most have never been sharpened?
Trick is slow speed, cutting oil and moderate pressures.
The bigger the hole, the slower the speed.
Actually if you lack cutting oils even water to cool is better than nothing. The 'blacksmith/welder' guy I know always uses an old coke bottle of water to cool his bits and I think his bits date back to his grandfather.
On the otherhand his drill press also dates back to his grandfather- a big old hunking slow press with many reductions.
Dormer bits cost about 2X regular HS but, take it from me, they are tough.
1/2"hole in 5/8" stock is like a hot knife in butter. (well almost)
Not rocket science: quality bits+ cutting oil+ slow speed is the secret.
/ Question on drill bits?? #22
DORMER drill bits.
/ Question on drill bits?? #23
My father was a machinist and did a lot of work with stainless steel. His drill press would not go slow enough for him so he made a double pulley double fan belt conversion so his drill press would go under 300 rpm. The right type of drill bit, lubrication, slow speed and steady firm pressure worked most of the time. When I would try to drill stainless, before I talked to him, the drill bits would harden the stainless and the bit tips would be rounded of and dull enough to not be able to cut butter.
Farwell
/ Question on drill bits?? #24
Farwell
/ Question on drill bits?? #25
a. use sharp drill bit
b. use slow rpm as the machine allow
c. (push) feed hard
d. keep the drill bit cool
Remember, the shawings should be in brown color, it they are blue you turning the toolbit to high of a rpm. Only carbide tools are made to be use on higher rpm range, but all tools need a proper tool pressure to last long. By feeding hard you removing a thisker chiip shawing and with it removing heat as well. Hope this helps someone.
/ Question on drill bits?? #26
c. (push) feed hard
/ Question on drill bits?? #27
Apparently that must be a common problem with drill presses. I used to have a relatively cheap drill press from Tractor Supply Co.; 5-speeds, I never used anything but the slowest speed and it was still too fast.
/ Question on drill bits?? #28
/ Question on drill bits?? #29
</font><font color="blue" class="small">( By feeding hard you removing a thisker chiip shawing and with it removing heat as well. Hope this helps someone. )</font>
Huh???
Whiskered chimp thawing?
This here hip pshawing?
Thicker chip shaving??
I've tried and tried....and I put my money on the third guess....hate that when that happens... Mom tells me it's gonna get worse as I get older....
/ Question on drill bits?? #30
Huh???
/ Question on drill bits?? #31
I was at HF and found a set of Silver and Deming dirll bits for fairly cheap - I want to say $20 - sale of the normal HF price of $40. Anyway I picked them up.
What the heck does Silver and Deming mean?
I was at TSC and they had one Silver and deming bit for $20!??
Where is a good place to buy cutting oil? I will try Napa tomorrow.
/ Question on drill bits?? #32
/ Question on drill bits?? #33
)</font>
Silver & Deming Manufacturing Co
I bought a set from HF and found them to be usable..I did bend two shanks when the work came loose..but that wasn't a problem with the bits.....
/ Question on drill bits?? #34
)</font>
/ Question on drill bits?? #35
<font color="blue"> What the heck does Silver and Deming mean? </font>
"Silver and deming drills are general purpose drills with a reduced shank to fit into a standard chuck, typically 1/2". Often used for portable drills with standard chuck capacities. All S&D drills are 6" long with a 3" flute length. Alternate terms are blacksmith drills or prentice drills. "
Above Quote from this site. Click Here
/ Question on drill bits?? #36
/ Question on drill bits?? #37
Drill doctor......... Great tool. I wish I had one 30 years ago! Took me a while to "tune-up" thirty years of dull bits, but once you get them up to snuff you can keep them sharp and at the correct bevel etc.
/ Question on drill bits?? #38
/ Question on drill bits?? #39
</font><font color="blue" class="small">( What the heck does Silver and Deming mean?)</font>
Silver & Deming Manufacturing Co.
Salem, Ohio
This company could trace its history back to 1854, although the "Silver & Deming" name does not date back that far. The titular heads were Albert R. Silver and John Deming. In the later history of the company, Emmor W. Silver was a principal; he was perhaps a son of Albert.
Silver & Deming was created in 1867 or 1868 after L. A. Dole had died, and Dole, Silver & Deming was renamed. In about 1874, Silver & Deming became Silver & Deming Manufacturing Co. In 1890, the company reportedly split, with one part becoming Silver Manufacturing Co.
Silver & Deming made a variety of machines that were primarily aimed at wheelwrights: hob-boxing machines, spoke-tenoning machines, etc.
Silver & Deming apparently invented the large-size twist drill bit with a turned-down shaft so they can be used in a chuck smaller than the bit's cutting diameter. They did not patent this idea, so the idea was quickly copied by others, but these bits are still called "Silver & Deming drills".
/ Question on drill bits?? #40
Salem, Ohio
Farmall Super A Tractor (A62613)
Farmall Super A...
LOOK! (A65640)
LOOK! (A65640)
Trimble True Count Clutch Wiring (A65640)
Trimble True Count...
2011 FORD F-550 CAB AND CHASSIS(INOPERABLE) (A65643)
2011 FORD F-550...
HD Bale Ring w/ Hay Saver (A66408)
HD Bale Ring w/...
Cattle Feeder (A65640)
