Put in a new Battery, got nothin' - I am not dumb, but maybe I'm not bright?
   / Put in a new Battery, got nothin' - I am not dumb, but maybe I'm not bright? #101
I bought a LS tractor knowing diddle squat about tractors, but man do I love it now. I put in a new battery for the winter, I got nothing. I checked the terminals, clean. I checked to make sure I didn't put it in backwards. I tightened it down with a torque wrench. I swore at it a lot. I am not getting lights, dashboard activity, not a sign of life. I know nothing of tractors but I am ok with cars. Does this have a starter solenoid? Is there some sort of reset button when you change the battery that I cannot find? Anyone have any ideas apart from taking it to a shop 200 miles away?
Check the fuses.
   / Put in a new Battery, got nothin' - I am not dumb, but maybe I'm not bright? #102
Don't know anything about LS tractors, but charged the battery on an old truck, put it on, nothing. Cleaned the battery terminals with the little wire brush cleaner, cleaned where the ground and positive cables connect to the starter and frame, nothing. An older mechanic friend came over listened to everything I had done. Pulled out his pocketknife and scraped the battery poles and inside the battery cables. Truck turned over and started. Did I feel like a dumb ass? Yes I did.
   / Put in a new Battery, got nothin' - I am not dumb, but maybe I'm not bright? #103
Since Freddy has not answered I have another question. Bought an almost new Mahindra 5155, it had set outdoors at the dealers last winter. Had some, after market, LED light installed. Tractor works great, but no lights except the ones with independent switches(4 ways and work light and LED's). I have checked the fuses, they are mini's and difficult to remove and check, all appear good. The $300 4 way light switch, turn signal, horn and high/low beam headlights, may well be the problem, but changing it is a last resort. There are relays in the fuse block for high beam lights, low beam lights. How do you check those relays?
   / Put in a new Battery, got nothin' - I am not dumb, but maybe I'm not bright? #104
You do not have to remove those fuses to check them. There should be a small hole on the back of the fuse on both ends to insert a test light into it.
   / Put in a new Battery, got nothin' - I am not dumb, but maybe I'm not bright? #105
Do the Lights work? Dead battery? Try a known good one. Ground connection to tractor is equally important.
   / Put in a new Battery, got nothin' - I am not dumb, but maybe I'm not bright? #106
I was gifted a jump starter. ( The kind that looks like a brick) It has helped me out more times than I can count when I had a dead battery. I used it last week on the skid steer. Also has a port for emergency usb charging. One of these would really be handy for most folks with a possible dead battery.
Real handy to keep in the car too.
   / Put in a new Battery, got nothin' - I am not dumb, but maybe I'm not bright? #107
I wonder if Freddy figured out what the problem was.
   / Put in a new Battery, got nothin' - I am not dumb, but maybe I'm not bright? #108
Hemostats are super handy for checking all blade fuses. Easy to grab and lock on and reinstall. I have several that I've accumulated over the years and use them quite a lot. Very handy for handling small parts, etc. (Not just for doctors anymore . . . )
   / Put in a new Battery, got nothin' - I am not dumb, but maybe I'm not bright? #109
Do you have a jump pack that you could hook up to see if anything happens?
Well I do but I am going to need a tractor to pull it to a location with a plug. I just wouldn't think you would need to jump a new battery but maybe they sold me a lemon. Do you know if there is any safe switch that flips when you take out a battery? I could be just making that up in my head, but I am just frustrated. I will swing by ACE tomorrow and pick up that multi meter - It would be nice to have on hand.
Freddy, if you ever revisit this thread, a jump pack is a portable battery and cable setup that you can carry to the tractor. You don't need a plug, you charge the unit before you head to the equipment. Even easier than getting using another vehicle for jump starting.
Here is a nice one for larger equipment and it has a compressor, but you can find smaller, less expensive units:
   / Put in a new Battery, got nothin' - I am not dumb, but maybe I'm not bright? #110
Freddy does your tractor have a PTO switch? Make sure it is turned off.
If the switch is on the ignition will not get power to start the tractor.
2008 Chevrolet Express Box Truck (A56858)
2008 Chevrolet...
2000 GMC C7500 SINGLE AXLE VOCATIONAL TRUCK (A57880)
2000 GMC C7500...
ST205/75R15 Trailer Tires (A55788)
ST205/75R15...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2015 International Bucket Truck (A55973)
2015 International...
2015 Freightliner Derrick Digger (A55973)
2015 Freightliner...
