Snow Attachments Pushin snow
/ Pushin snow #1
Olmike
Holton, Kansas NO. of Topeka
case 1835 uniloader,720K grasshopper,76 F350 with dump bed,cushman truckster with dump bed
Heres couple of pics of my rear mount blade on the front of my 1835 case.I mounted A TPH QA on the skid steer QT.Works great for pushin snow.I push with the back side of the blade so it doesn't dig the gravel.
/ Pushin snow
Forgot the pics.
/ Pushin snow #3
Nice SET UP!
With the hydraulic power-angle on the blade it has a lot of possibilities for dirt work, as well as snow.
I assume you flip the blade around, facing fwd, and push the snow with it?
/ Pushin snow #4
Will your blade rotate 180 degrees? or can you convert it to
Jim
/ Pushin snow
I push snow with the blade the way you see it.It doesn't dig into the gravel that way.
Mrjimmi, I can unbolt 2 bolts and rotate the blade 180 and put em back in about 3 minutes. The cylinder is A steering cylinder off of A case combine.
/ Pushin snow #6
First post...let's see how she goes.
Why is there so much talk about blades, when to me, a newbie to tractors, a blower seems the only way to go? Maybe it's my circumstances(southern Ontario, Canada), maybe it's lack of experience with a blade, or maybe it's mostly financial(ie.making the desicion to put out the money for a blower right away rather than go the cheaper route and try to be crafty with how I could use a blade....)
I get a fair amount of white stuff on any given day(for about four months) and can't see how piling it up would do after a few dumpings.
Someone please enlighten me as to the pro's and con's of blades and blowers and more specifically how a blade can work in moderate to heavy snowfall areas(if at all possible)
...Just a thought from a dummy that doesn't want to be so dumb.
/ Pushin snow #7
Olmike, I was in Holton today, my mother lives there. I was born and raised in Whiting, lots of family still live there. I noticed tons of tree damage in your area, we were lucky and didn't have damage.
/ Pushin snow #8
Short answer for me, here in central Indiana, we don't get a lot of snow and a blade is a multitasking implement. You will find dozens of notes on using a blade and/or blower for snow removal filled with pros/cons, modifications, and advice. Just use the search. But be warned - this place is addicative!
/ Pushin snow #9
Which is better for you isn't just a function of how much snow you get, it's also a function of what areas you need to clear.
Long, curving driveways.
Long, straight driveways.
Large open areas.
Stone or paved.
With a blade (front or rear) or a FEL, you need a place to push the snow. If you run out of places to push the snow, you will need a FEL to relocate the piles of snow. For all intents and purposes, a FEL is front blade you can't angle. Personally, if you have a FEL (I do), I've never seen the value in a rear blade for removing snow. Yes, you can angle it, but even though I have a rear blade, I could never see me getting down off the tractor to change the angle. Much easier to come at the snow from a different angle with the FEL. If I can't come at it from a different angle, I drop the bucket and drag the snow to a spot where I can.
NOTE: The driveways I clear are all relatively short, under 100', with plenty of space to push the snow. If the piles get too large, (happens rarely) I push them back further.
IMO, for areas that get moderate to heavy snow, a blower is the only way to go. But, you will need a place to store it. If it's windy, you will wish you had a cab. Although, if you're in a moderate to heavy snowfall area, that's probably a requirement too. For a rear snow blower, you'll want rear remotes so you can angle the chute from inside the cab.
/ Pushin snow
billbill1,You know me, I live east of town.
/ Pushin snow #11
Hydrovane-I live in central Ontario and have both a rear blower and a backblade. The blower had been sitting in the barn for two years until we got the dump last week. I installed it, blew snow for 3hours then the universal on the PTO shaft broke. After the New Year I will probably make a trip down to Belleville and buy a new yoke but for the average 6-10" snowfall the backblade is easier.
Once the shoulders get built up with snow I just use the snowbucket on the FEL to relocate it over the edge of a hill or out onto the lake. If I have to clear the trail outback for maple syrup I sometimes use the blower but most springs I can just use the bucket, especially if its been packed down by snowmobiles.
/ Pushin snow #12
pat32rf.
I am about 1 1/2 hours north of T.O and get a fair dumping on any given night(alot more snow here than in T.O or 1/2 hour north (in Brampton)where I used to be).
My issue, I suppose, with a blade is that my driveway is curved like an L, is about 75' long, 20' wide. The sides get over a foot high in several good dumpings(and that is using a blower..ie I'm moving the snow from the drive way beyond the edges, so that's just actual snowfall.) So I imagine in this circumstance, I would be using the bucket all the time to push it over the edge. I think that after those few good snowfalls, I would be spending alot more time using a blade and bucket than just blowing it in the first place.
I do see the advantage, I believe, in using blade/bucket if the driveway is long and narrow. I guess I could save time and money by moving into a place with a long and narrow driveway, selling the blower and buying a blade...OH WELL...
/ Pushin snow #13
Mike, long time-no see. I wondered when I saw your post if that was you. I recognized the barn. That old Studebaker truck looks like one Dad had when he died, where did you get it? Hope all is well with you and yours.
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
Pallet Racking Uprights (A62613)
Pallet Racking...
2004 Ford F-550 Single Cab Flatbed Truck, VIN # 1FDAF56P94EC72605 (A65563)
2004 Ford F-550...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
2022 EZ-GO ELITE...
