PTO Shaft Cap
/ PTO Shaft Cap #21
Harv, did you check the back end of the toolbox under the seat?
/ PTO Shaft Cap #22
Harv
You may have left it in many different<A HREF="http://www.acknowledge.com/tractor/L2500DT/photos/RackOptions.jpg" target="_new">
Boxes, Barrels and Coolers</A>./w3tcompact/icons/laugh.gif/w3tcompact/icons/wink.gif/w3tcompact/icons/smile.gif
/ PTO Shaft Cap #23
<font color=blue>did you check the back end of the toolbox under the seat?</font color=blue>
That's another thing they forgot to give me, Jag. /w3tcompact/icons/shocked.gif
Far as I know, there ain't no toolbox under the seat nor anywhere else on an L2500. That's probably why they call it an "economy" tractor. /w3tcompact/icons/wink.gif
Imagine how embarrassed I'll be if it turns out you're right. /w3tcompact/icons/blush.gif It'll be a couple more weeks before I see my tractor again, so I can't double check right now.
Ron could be right -- maybe the monkeys got out of my barrel and swiped the danged PTO shaft cover. /w3tcompact/icons/crazy.gif
/ PTO Shaft Cap #24
I never had one for my old L175 but had considered making an L shaped flap and welding a piece of pipe for the pin to slide through for holding in place. Just as a safety measure, but sold the tractor before doing so.
/ PTO Shaft Cap #26
I dont know about your tractor but on my new Tn70 that was deliverd Friday, had the shaft cap inside of the tool box.I am not sure if your tractor has a tool box or not.
/ PTO Shaft Cap
Yep, that's where I finally found mine. So, now I have 2 caps!
/ PTO Shaft Cap #28
Mike
You found yours?/w3tcompact/icons/blush.gif
How are you going to explain this to your dealers salesman?/w3tcompact/icons/tongue.gif
/ PTO Shaft Cap #29
On my TC29D, the mid pto has a plastic push on cover that has never been taken off, and probably never will be.
I have the screw on cap for the rear, and put it on when I'm not using the pto.
The manuel say's<font color=blue> " The PTO cap should always be installed when the PTO is not in use"</font color=blue>
It does not give the why. I figure it's to keep dirt, debris, and moisture off the shaft.
Ernie
/ PTO Shaft Cap
<font color=blue>How are you going to explain this to your dealers salesman? </font color=blue>
Very delicately! /w3tcompact/icons/wink.gif
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
Great Dane Van Trailer 1989 (A63689)
Great Dane Van...
Wacker Neuson RD12 (A57148)
Wacker Neuson RD12...
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
1999 JOHN DEERE 344H WHEEL LOADER (A63276)
1999 JOHN DEERE...
Ripper Tooth Excavator Attachment (A61572)
Ripper Tooth...
