PTO Shaft Cap
/ PTO Shaft Cap #21
Harv, did you check the back end of the toolbox under the seat?
/ PTO Shaft Cap #22
Harv
You may have left it in many different<A HREF="http://www.acknowledge.com/tractor/L2500DT/photos/RackOptions.jpg" target="_new">
Boxes, Barrels and Coolers</A>./w3tcompact/icons/laugh.gif/w3tcompact/icons/wink.gif/w3tcompact/icons/smile.gif
/ PTO Shaft Cap #23
<font color=blue>did you check the back end of the toolbox under the seat?</font color=blue>
That's another thing they forgot to give me, Jag. /w3tcompact/icons/shocked.gif
Far as I know, there ain't no toolbox under the seat nor anywhere else on an L2500. That's probably why they call it an "economy" tractor. /w3tcompact/icons/wink.gif
Imagine how embarrassed I'll be if it turns out you're right. /w3tcompact/icons/blush.gif It'll be a couple more weeks before I see my tractor again, so I can't double check right now.
Ron could be right -- maybe the monkeys got out of my barrel and swiped the danged PTO shaft cover. /w3tcompact/icons/crazy.gif
/ PTO Shaft Cap #24
I never had one for my old L175 but had considered making an L shaped flap and welding a piece of pipe for the pin to slide through for holding in place. Just as a safety measure, but sold the tractor before doing so.
/ PTO Shaft Cap #26
I dont know about your tractor but on my new Tn70 that was deliverd Friday, had the shaft cap inside of the tool box.I am not sure if your tractor has a tool box or not.
/ PTO Shaft Cap
Yep, that's where I finally found mine. So, now I have 2 caps!
/ PTO Shaft Cap #28
Mike
You found yours?/w3tcompact/icons/blush.gif
How are you going to explain this to your dealers salesman?/w3tcompact/icons/tongue.gif
/ PTO Shaft Cap #29
On my TC29D, the mid pto has a plastic push on cover that has never been taken off, and probably never will be.
I have the screw on cap for the rear, and put it on when I'm not using the pto.
The manuel say's<font color=blue> " The PTO cap should always be installed when the PTO is not in use"</font color=blue>
It does not give the why. I figure it's to keep dirt, debris, and moisture off the shaft.
Ernie
/ PTO Shaft Cap
<font color=blue>How are you going to explain this to your dealers salesman? </font color=blue>
Very delicately! /w3tcompact/icons/wink.gif
2013 Kubota BX2370 44in 4x4 Compact Utility Tractor Mower (A61572)
2013 Kubota BX2370...
Bobcat 873 (A55272)
Bobcat 873 (A55272)
Bobcat E42 (A60462)
Bobcat E42 (A60462)
2020 Water-Land Dba Continental Trailers Trailer, VIN # 1ZJBU1415LC037150 (A61569)
2020 Water-Land...
2019 PETERBILT 567 TRI/A DUMP TRUCK (A59912)
2019 PETERBILT 567...
3PT HAY SPEAR (A63291)
