PTO in reverse?
/ PTO in reverse? #1
dave66
Been researching for buying a used Yanmar and have seen that the PTO's on the grays run opposite direction as US domestics. True or Untrue? Have a couple implements from my recently deceased tractor and want to know I can still use em.
/ PTO in reverse? #2
My Gray Yanmar don't run in the opposite direction.
/ PTO in reverse? #3
The only ones I know of are some early Mitsubishi, Satoh, and Kubota models. All of them had nonstandard shafts also. I think they were 25mm-25 spline, not sure of that but obvious at first glance they are not standard cat 1!
I think, not sure but think, that all with 1 3/8 dia cat 1 shafts are clockwise.
/ PTO in reverse? #4
Can you post a link or links to where you saw this?
/ PTO in reverse? #5
Yanmars turn the correct direction.
/ PTO in reverse? #6
The only one that I KNOW turns the opposite direction and has a non-standard (smaller and more splines) PTO shaft is the grey market Kubota B6000. All Yanmars that I have ever seen have a standard PTO shaft and rotation.
Where did you get information that greys turn the opposite of US tractors?
Mike
PS. Welcome to TBN. Stick around and you will get all the information you will need to make truly informed decisions. :)
WELDING TABLE (A68842)
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A65056)
KNOW BEFORE YOU...
PORTA POTTY (A67714)
2013 GMC Seirra 2500HD Ext. Cab Knapheide Service Truck (A68183)
2013 GMC Seirra...
2016 CHEVROLET TAHOE (A66091)
2016 CHEVROLET...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
