PTO in reverse?
/ PTO in reverse? #1
dave66
Been researching for buying a used Yanmar and have seen that the PTO's on the grays run opposite direction as US domestics. True or Untrue? Have a couple implements from my recently deceased tractor and want to know I can still use em.
/ PTO in reverse? #2
My Gray Yanmar don't run in the opposite direction.
/ PTO in reverse? #3
The only ones I know of are some early Mitsubishi, Satoh, and Kubota models. All of them had nonstandard shafts also. I think they were 25mm-25 spline, not sure of that but obvious at first glance they are not standard cat 1!
I think, not sure but think, that all with 1 3/8 dia cat 1 shafts are clockwise.
/ PTO in reverse? #4
Can you post a link or links to where you saw this?
/ PTO in reverse? #5
Yanmars turn the correct direction.
/ PTO in reverse? #6
The only one that I KNOW turns the opposite direction and has a non-standard (smaller and more splines) PTO shaft is the grey market Kubota B6000. All Yanmars that I have ever seen have a standard PTO shaft and rotation.
Where did you get information that greys turn the opposite of US tractors?
Mike
PS. Welcome to TBN. Stick around and you will get all the information you will need to make truly informed decisions. :)
2006 KENWORTH W900 (INOPERABLE) (A67714)
2006 KENWORTH W900...
2019 PETERBILT 567 (A67714)
2019 PETERBILT 567...
2018 Autocar ACX Xpeditor T/A New Way 31ASL 31yd. Side Loader Garbage Truck (A66736)
2018 Autocar ACX...
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
500BBL WHEELED FRAC TANK (A67714)
500BBL WHEELED...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
