Generator PTO Generator
/ PTO Generator #101
I have a 7500 watt generator that has the idle down feature. When it senses a load it revs up to the speed rated for 60 hz. When the load is removed it returns to idle after about 2 seconds. At idle it produces around 40 hz according to my meter.
Terry
/ PTO Generator #102
you are probably right about the 0 current. I have not tried it so I dont know. but your arguement on that point makes sense. I guess your arguement goes back to what you are going to use the power for. If you are going to have a generator running so that you can have power for lights or tv or whatever then you can start the generator and have it run when you need it and turn it off when you are done. I believe I could do the same thing with my genrator. However if you are going to have power available so that you can turn on a light or power a fan for a heater. Then you are going to need to leave the generator running and my idle down feature on the generator would be a lot better. Luckily for both of us they make and sell both kind of generators so that we can both be satisfied with our choice whichever one is better.
I just have a different idea of 'emergency backup power' than some... IE.. in an emergency situation wher ethe grid is down.. and may be down for? who knows how long? I think I will be conserving fuel and generate power only when needed.. and not just be making it for convienience sake.
as you say.. both are available for those that need convienience power and those just worried about having enough fuel to make it all the way thru the crisis without the tv and lamps at the flp of a swich. ;)
soundguy
/ PTO Generator #103
A battery backup system to run small items, such as lights, tv, radio, etc would make the generator more efficent. When the batteries draw to a low state, or it is time to run the freezer/fridge (or my favorite COOK!)start the generator and use it during the needed time, but allowing it also to charge the battery bank. Makes great use of the fuel available.
David from jax
/ PTO Generator #104
David from jax
I agree, and think we need a separate forum to discuss all the "Alternate energy" ideas which seem to come out at this time of year
In a long term, don't know when the power is coming back type outage, that would be the way to go, inverter and a bank of batteries.
That's what the folks who live off the grid do, they are the true power managers, and it's not just lite loads, they have high out put inverters, pretty costly though.
In my home the vast majority of the time it's just lights and TV, only use the dryer 1 day a week and the stove 1 hour a day at the most, got oil fired heat and HW, the fridge being the biggest draw on average all day probably, so that's why I keep going back to an easier way to make 3-4 kw with my pto.
Maybe a small battery system would be ideal for me, but you'd prob spend more on even a small system than the genny. Of course I still want the pto genny for charging the batteries or using the dryer, stove, welder or compressor etc.
IMO, back up or standby power has to be made by diesel power, simply for the storage and stability concerns, (use to be cheaper but as was pointed out, can't use that anymore) and the fact that I always have several hundred gallons on hand (three 275 gallon oil tanks$$$)
JB.
/ PTO Generator #105
JB.
That is another consideration that i did not mention what type of fuel do you have the most of. I certainly dont keep 275 gallons of diesel fuel around If you have that kind of resevoir that would make sense to be able to use something that used diesel fuel. I actually am considering an actual standby generator. I saw one that would put out 200 amps and was labeled at having regulated power for computers and digital circuits If power went out I could run my whole house with it. It runs off of LP gas and I have a spot where I could just T off of the line where it goes into my house and have the generator sitting right next to the house ready to go. I use propane to cook with and for backup heating. I am on a route so they fill my tank every two weeks. I need to budget that kind of money but it would be a solution that would make sure I was prepared for a long term outage if that should happen.
/ PTO Generator #106
You may have to heat the propane tank when using a lot of power.
larry
/ PTO Generator #108
Some of these units run off natural gas. That way if it is an electrical power failure you would have an unlimited supply of gas from a connected underground utility. However if the loss is due to some cataclism such as earthquate you will probably lose natural gas utility also.
Yes, you may have to heat the propane tank in very cold climates as the use of the propane causes the gas to boil off and cool the tank (ever see frost on your BBQ bottle). As the temp plummets the internal pressure drops to the point it will become unuseable.
/ PTO Generator #109
David from jax
I also agree.
I keep a good interstate battery as a spare.. I take it with me to run a 12v winch on tractor hunting expiditions.. or when i go to a show just incase mine or another persons tractor dies and needs winching up on a trailer.
in any case.. i have 4 inverters.. well 5 really.. but one is small.. just enough for a laptop. Various sizes. I also have a jumper / booster pack that has 12v outlet, led lamps.. etc. I have a few hand crank lamps and radio's.. as well as a hand crank lamp/weather radio/radio/tv.
For the first bit of an outtage that is storm related.. i usually don't rig up genny power -yet-.. If i need an update on weather a hand crank radi suffices... insividual lamps can be run off an inverter..e tc. Once I know outtage will be for 8+ hours.. i get the genny ready to keep the refers cool and cycle them.. etc. / recharge the bat's for the inverters.
soundguy
/ PTO Generator #110
Heat the propane tank ?
Ever been to a tractor show and seen the big one-lungs running off a bbq tank.. and after sucking on it for a few minutes the thing freezes up.
remember the cooling effect of releasing a compressed gas....
soundguy
FRESHLY REFURBISHED! 2016 KBH Fertilizer Tender Trailer - Isuzu Diesel (A61307)
FRESHLY...
2013 Deere 75G (A60462)
2013 Deere 75G...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
John Deere 5090E (A60462)
John Deere 5090E...
200 Gallon Tank (A57148)
200 Gallon Tank...
