PTO generator selection help
/ PTO generator selection help #121
I bought a 25kw continuous 50kw surge 1800 rpm Generac PTO unit in 1999 in preparation for Y2K which never happened.
After reading this post I need to ask if there is a real advantage of 1800 rpm versus a 3600 rpm PTO generator?
90cummins
I believe that 1800rpm generators are usually quieter, and often, but not always, more efficient on a BTU/kWh basis. (Frictional losses in an internal combustion engine generally tend to increase with rpm.)
All the best,
Peter
/ PTO generator selection help #122
I personally think the only advantage that you have is the required speed of the generator. Half the speed does reduce wear and possibly allows the tractor to run a lower RPM. I don't think there are any significant changes in the quality of power from a generator until you get into inverter units.
/ PTO generator selection help #123
I have heard that brushless generators have really dirty power. At least one oscilloscope trace seemed to verify that. The sine wave looked halfway to a squiggly sawtooth. That makes no sense to me, but maybe I don't understand how rotating field generators work.
/ PTO generator selection help #124
Based on my experience, I would not make that particular assertion. Clean, or dirty power arises from lots of sources; choices in winding design, choices in voltage regulation, choices in rotor design/construction, and of course maintenance and tuning.
To the extent that brushes aren't in good shape and in the commutator design is not good, you can get a lot of noise out of a brushed design.
I think a lot of this comes down to the quality of the pieces of the generator and the overall construction.
I have a couple of inexpensive generators that I use to power things like 120V tools in remote locations. Since they are just running a motor, often a cheap motor, I don't sweat the power quality ever. However, I have looked and the power was actually very good, but all it takes is a diode or a capacitor or a regulator to start dying and power quality goes out the window.
Running pricey home devices that are electronic? I think that is a different story; test and measure, and keep testing and measuring. As someone famous once said "trust, but verify", and for electronics, I would also add "use as many surge and EMI protectors as you can", as every little bit helps.
All the best,
Peter
ATS 60 Gallon 2 Stage Air Compressor (A62679)
ATS 60 Gallon 2...
John Deere 336 Square Baler (A66408)
John Deere 336...
2012 BMW 328i Coupe (A61569)
2012 BMW 328i...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
2000 LUFKIN FL-II T/A  48FT FLATBED TRAILER (A59914)
2000 LUFKIN FL-II...
2016 International DuraStar 4300 Dump Truck (A64556)
2016 International...
