Protecting top on a new welding table
   / Protecting top on a new welding table
Mr.G Its brand new, never been used..... I live near the ocean, in 1 week it can have a light coat of rust.
   / Protecting top on a new welding table #22
Used to be a frequent member here, ShieldArc. He helped me design mine. I wanted a fold down cutting table on one end. He taught me how to design the braces that hold it up. Can be folded down with no tools. He was a valuable asset here on TBN. I learned a lot from him.
   / Protecting top on a new welding table #23
Buy some cheap vinyl (disposable) table cloths...covering the table will greatly cut down on the rust...they are only a couple bucks...maybe even cheaper at the dollar stores...
Running a dehumidifier when there is high humidity will make a big difference...
I use a dehumidifier in my shop around 6 mo out of the year It's amazing how much water it pulls out of my shop and away from my tools and equipment.
   / Protecting top on a new welding table #24
Thompson's water seal soaks in and lasts for a long time.
   / Protecting top on a new welding table #26
I just refurbished my DIY CNC plasma cutter that is actually a retired XLO knee mill.
it had rust, and a lot of cleaning later,, it is rust free.
The Turtle Wax CERAMIC coating is the "GO TO" coating ,, now, for car protection,
I thought I would try it on the bare metal.
Well, I have mixed emotions,, right now.
1) the coating is WATER BASED!! if you apply too much,, you create rust!!
2) when properly applied, and dried,, the coating seems to be working.
3) it is the easiest coating to apply EVER! Spray on a LITTLE,, wipe dry.
I think to protect a steel bench, you are gonna need multiple coats.
the surface of the steel table after any rusting has lots of nooks and crannies for a surface.
I also cleaned my welding table (6'x6'), but, nothing has been applied,, yet,,,
   / Protecting top on a new welding table #29
"If it gets spattered or a bit of corrosion, I belt sand it. Easy peasy."
Just another reason for starting with a 1" (or more) thick top 😈
This one's 3'x7'x1", a CL find for $200 about 10 years ago - weighs just over 1000 lbs including the legs - seller actually DELIVERED it, couldn't complain... Steve
   / Protecting top on a new welding table #30
I bought my table from Weld Table 3 or 4 years ago and all they recommended was to soray it with some WD-40 when I was done welding. Very minimal rust even though I only weld every month or so.
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A55758)
Year: 2017 Make...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A55787)
2017 Toro Z-Master...
PALLET OF LANDING MATS (A52708)
PALLET OF LANDING...
