Propane questions
/ Propane questions #31
^ I agree, except I do use a propane grill for some foods depending on the occasion.
The best way to grill is with hardwood, then a close second is chunk charcoal. The briquettes leave a kerosene note to the food and using lighter fluid to start the fire is absolutely horrid! You can taste the lighter fluid in the food even after the fluid has supposedly burned off.
A smallish torch similar to weed burner for starting a chimney of wood, charcoal or briquettes is the best of both worlds.
My brother cooked out at least 3-4 times per week and was picky about type charcoal and starter used. Refused to use self starting due to lingering fuel smell and taste. After hearing dad complain about price of or running out of lighter fluid,14 y o son bagged up empty lighter bottles and refilled them from a neighbor's diesel tank. Brother was livid over the sorry fluid ruining steaks so he cooked over wood for a week or two util boy told him about the intended good deed. My brother passed before his kids bought places of their own but he swore when they did he would mess with their lights,gates,water hydrants and anything else that might disturb them.
/ Propane questions #32
I always use one of those 'sheet metal' chimmney fore starters and a wad of newsprint to start my chunk charcoal. Never any sort of accelerant.
/ Propane questions #33
It should be a pretty easy install for the LP company. Install a tee with a shut off pointing towards the regulator and install a quick dis-connect after the second stage regulator before it goes into the house. You have CSST going into your house so there is flexibility Make sure the quick disconnect does not have an excess flow or if it does it should be rated at 25% great than the generator BTU load at full fire ( when it starts up ). What size LP tank did you say you had ?
2023 MADJAX GENESIS 300 ELECTRIC CART (A57192)
2023 MADJAX...
2009 CHEVROLET C8500 DUMP TRUCK (A59823)
2009 CHEVROLET...
2005 CASE 580 SUPER M SERIES 2 BACKHOE (A62129)
2005 CASE 580...
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
2014 Chevrolet Tahoe SUV (A59231)
2014 Chevrolet...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
