rdbigfarmboy
It has one hydraulic pump for the lift system and one for the power steering. Remove and check the hydraulic filter look for tape type or gasket sealant and metal shavings it doesnt take much to stop a valve. Sounds like an obstruction or linkage disconnected. I would go with obstruction. Since its under warranty let Farm Pro fix it. On older stuff we would drain the oil clean the filters and run diesel thru the system to clean the obstruction. If that didnt work take it apart. Since it is new it may be from the assembly process. I have a Tractor King 70 hp and have found final assembly and quality checks are lacking on the tractor. Rural king is correcting the assembly issues
