Better fluid level indicator??
/ Better fluid level indicator?? #1
Sarge338
Bronze Member
Mahindra 2555
This is going to sound like a stupid question, and it probably is, but is there any kind of an aftermarket gauge that can be added to a tractor to show hydraulic fluid levels… like a fuel gauge?
I have a Mahindra 2555, and I recently changed the PTO seal. Afterward I refilled the fluid checking the dipstick after every operation of the hand pump. I stopped pumping just shy of the high-level notch of the dipstick. Fast forward a few weeks, and I was cycling all of the hydraulics (self-contained) of a new backhoe attachment when I noticed several places on the rear end of the tractor that looked wet. I knew I had cleaned everything after the PTO seal replacement, so the only thing I could figure was the fluid was being pushed out through the seals. I checked the dipstick and it is WAY high… above the flat area of the dipstick. 1) I don’t know how it’s twice as high now as when I filled it, and 2) if I can’t rely on the dipstick to give me an accurate reading, how do I know what’s in there?
On a side note, anyone know of a good way to have a controlled drain of excess fluid? Dropping the drain plug tends to drain more than I want, unless I’m doing a full fluid change. And given the above scenario, I’d rather not end up in a cycle of draining and refilling.
/ Better fluid level indicator?? #2
I bought something like this on Amazon. For what you want to do it would be nice. I always remove drain plugs when doing fluid replacement because I don't trust the tube to get it all. It is useful when transferring oil, fuel and hydraulic fluid.
/ Better fluid level indicator?? #3
Pull one hose of a cylinder and put it in a bucket. I would say probably on of the curl cylinders on the loader might be the easiest. Then just run the tractor and actuate that function to fill the bucket.
As to check the level, always check the lever with the loader on the ground and 3 pt lowered.
/ Better fluid level indicator?? #4
I'm guessing the backhoe wasn't on when doing the pto seal? The backhoe is where all your extra oil came from or if like my NH I can have a low reading then next day have a normal reading. Just the way tractor built. No loader or anything else on NH.
Thanks for the input, everyone! I’ll follow your advice for draining the excess fluid. I’ll keep looking for a better way to gauge the fluid level.
/ Better fluid level indicator?? #6
The hyd. fluid level varies quite a bit on my Kubota as well. I use this fluid extractor / dispenser to adjust the level. It works by inserting a tube in the dipstick hole.
I also use it to extract most of the hyd. oil when doing an oil change.
Awesome!! Thanks for the info!
Yeah, the measured hydraulic levels in a 3 week period were WAY different. There has to be some kind of value/formula out there somewhere for determining what volume cold fluid will take up when it gets hot. I have to assume that’s why I now have extra fluid.
/ Better fluid level indicator?? #8
In what position are the back hoe cylinders when checking fluid level? Generic rule of thumb is estimate 15-20% volume difference on extended cylinder vs retracted.
@oldnslo, my backhoe’s hydraulics are self-contained. Its hydraulic pump connects to the PTO of the tractor. Other than not being able to fully drop the pt hitch, the backhoe shouldn’t impact the tractor’s hydraulic levels.
I only mentioned it, because that’s what I was messing with when I discovered all of the wet spots on the rear of the tractor.
/ Better fluid level indicator?? #10
Sorry missed the part about being self contained in original post. Not sure what would cause being over filled other than running PTO will heat the oil from splash and gears turning which should not cause excessive over fill. Any chance the vent or breather for the transaxle is plugged?
At this point, I think just about anything is possible. The difference from fill date to over-filled date is ridiculous.
I really wish this thing had a gauge, or at least a sight glass, for the hydraulic level rather than that tiny little dip stick.
/ Better fluid level indicator?? #12
I have one of these, they are great little pumps. I've used mine to suck the fluid out of an automatic transmission before doing a trans filter change and refill, saves a lot of mess. Also use it to refill my Silverado diesel when doing an oil change, much easier than trying to pour 2-1/2 gallon containers of oil into the fill tube. They are quick and easy to set up and pump a surprisingly high volume of oil. Only use with oils though, they need the lubricity of the oil to keep from burning out the pump vanes. Antifreeze or water will destroy them quickly.
/ Better fluid level indicator?? #13
If you have a port or two you can run a piece of clear hose or tubing external from tractor for oil level indicator. You would need to protect it from damage.
Awesome! Thanks for the info.
/ Better fluid level indicator?? #15
As oldnslo said, you could, if you can get the necessary fittings and protect the clear tubing from damage/snags, run a tube from the drain to the fill hole. Then you'd have a sight glass you could look at. You could also put a valve in that tubing, at the level you choose, to drain off excess fluid, if necessary.
Chris
/ Better fluid level indicator?? #16
Depends on the threading of your drain plug and how vulnerable it is to impact. You could install a small ball valve, or an "EZ Oil" drain plug, if your drain plug thread works. They are usually some common standard thread, as teh manufacturers rarely want to pay for custom stuff if they don't need to.
/ Better fluid level indicator?? #17
Another idea, would be to put a drain plug at the site glass location. Then you can then just open it, and any excess would run out. If, I ever have to go into the axle/transmission I will figure out a way to do that. But, unless it is disassembled I would be afraid of getting metal chips in the transmission.
/ Better fluid level indicator?? #18
John Deere 318 and 420 garden tractors actually had a sight glass to show oil level attached to the back of the rear end/transmission housing. The oil levels would rise once the oil was warmed up because the more viscous oil returned to the transmission faster. Even that was slow to show level increases as oil was added. I always worried about cracking the level tube or breaking the 3/16 plastic hose which ran to it, but it never happened.
In your situation, I think that you probably put in a lot of oil fairly fast, and checked the level right away. I think if you had filled a bit more slowly, and not to the top, but to the bottom of the dipstick and then waited 10-15 minutes to check for a final level, the dipstick might have read more accurately. Also , running the engine and warming the oil up, once you were close to the minimum mark, and then stopping and checking the level would be the way to do it.
At least now you know that your particular design tractor is slow to show oil added to the trans casing. You know, in future, to fill slowly and not try to go to full mark and pause 10 or 15 minutes to check level before you top it off. There should not be any surprises for you from now on.
4'X4'X4' MANHOLE W/ COVER (A64281)
4'X4'X4' MANHOLE...
MILLER CP-302 CV-DC WELDER & (2) DEWALT CIRCULAR (A64280)
MILLER CP-302...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
2005 SBX-5 60in. Box Blade Tractor Attachment (A61572)
2005 SBX-5 60in...
2023 CATERPILLAR 299D3 SKID STEER (A64279)
2023 CATERPILLAR...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
