Preventing tractor back flip
/ Preventing tractor back flip #1
retiredmgn
Platinum Member
I was having a discussion with a friend.
Situation - a chain is attached from the bottom drawbar (several inches below the center of rotation) to an immovable object.
My contention is the front wheels are being driven into the ground. Hence, no wheelie. He says it will still wheelie the same as having the pull point several inches above the center of rotation.
Pull above the center of rotation is a no-brainer -you're going over.
Who's right?
/ Preventing tractor back flip #2
It will still flip over :(
It will just be more of a sling-shot flipover :( :(
You're right, initially the front wheels will be driven into the ground, but then given enough rear wheel traction, something has to give. That something is the front end switching from being jammed into the ground to being sling shot (slung shot?) upward, & over.
/ Preventing tractor back flip #3
As long as the attachment is below the "center of rotation" as you said... no wheelie !
The only way I can think to produce a wheelie is slack in the chain and popping the clutch. Then torque is greater than tractor's inertia and it rotates.... until the chain pulls the tractor back down
/ Preventing tractor back flip #4
Prove it to yourself and buddy.
Draw a tractor on paper... graph the forces acting on the wheel and tractor drawbar.
/ Preventing tractor back flip #5
I thought I could find a video example of an actual flip, but can't so far. However, check this tractor pull video out; Note that the tractor is pulling a wheelie the whole time. Certainly they pull from below the center of rotation, yet still get the front wheels off the ground: ‪NTPA Tractor Pull - Jefferson City, MO‬‏ - YouTube
/ Preventing tractor back flip #6
I have seen roller guides welded at strategic locations under tractors that allow the operator to pull from the front with the cable/chain/strap connected to the drawbar and run to the front of the tractor, so they pull using reverse.
I can't get a visual of this in my head. Logically it just don't work.
That's what I did to try to convince him I was right. Draw a circle with a dot in the middle. An arrow on the circumference showing counter clockwise rotation. A line from below the dot heading right.
Seems obvious to me but he is a stubborn old coot and refused my logic.
/ Preventing tractor back flip #11
There are two lines of force, at the level of the rear axle, and where the tire treads pull against the ground. This has gotten me to thinking that it can go over.
/ Preventing tractor back flip #12
You can use the Ford, but sign a release. It has no Rops, and has rared up more than Trigger on tv..
/ Preventing tractor back flip #13
The angle of the pull must be taken into account as well as the angular motion at the axle.:)
/ Preventing tractor back flip #14
Still thinking. The axle can't move the tractor forward unless the tires are pulling at ground level, so the operative forward force would have to be at the ground level. And the drawbar would exert a rearward counter force above the ground, should the tractor move forward.
I think the moral of the story is do not pull on something that won't move.
/ Preventing tractor back flip #15
The only thing I have to say is common sense isn't common.
/ Preventing tractor back flip #18
You never know it won't move until your front tires are up in the air, and even then it might be inching forward. :laughing:
Maybe I've hit my head too many times but I think my front tires are off the ground more often than not. Some day I will have a bigger tractor.
/ Preventing tractor back flip #19
Tire speed makes a difference. (Faster = more likely to rare up)
Ground speed makes a difference.
Distance from axle centerline to hitch point makes a difference.
distance from hitch point (on tractor) to hitch point (on object being towed) makes a difference. (Shorter = more likely to rare up)
Traction makes a HUGE difference. (see #1 and #2)
Tire inflation/construction makes a difference (tractors CAN bounce like a basketball in a hard pull)
Height of drawbar makes the BIGGEST difference. (lower is better)
I've seen a few pulling tractors with drawbar well below axle centerline and hitch point VERY close to axle climb up and go over backwards.
Ya gotta consider ALL the forces at play.
/ Preventing tractor back flip #20
If that chain is angled down allowing the load of pulling to load the rear tires giving good traction, they will walk the front end up and with enough momentum, right on over. Use shallow angles and this won't happen if hitched low.
The only way to completely prevent rearing up is you have a drawbar on the ground at the level of the tires but that isn't practical.
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
2361 (A64281)
2361 (A64281)
CONE BOTTOM HAY FEEDER (A63291)
CONE BOTTOM HAY...
LOADER MOUNT HAY SPEAR (A63291)
LOADER MOUNT HAY...
2019 CHEVROLET 5500HD LCF S/A  4X2 24FT BOX TRUCK (A59912)
2019 CHEVROLET...
