Preventing tractor back flip
/ Preventing tractor back flip #241
The dear professor generalizes.
And you're doing anything different...or, for that matter...any of the posts on this thread (including mine) doing anything other then conjecture based upon theory and a modicum of real life situations sprinkled in? We're all generalizing.
The difference is, this professor has more of an agricultural background then anyone here (although there might be a couple of real farmers posting). I would wager he's has a a pretty good database of tractor incidents to work from too.
/ Preventing tractor back flip #242
THat is the point. The wheels WILL come up. But if properly hitched, it wont go on over/QUOTE]
It won't go over?? Well well what do we tell the folks that did go over?:D:D
Just need a little torque that's all.:D:thumbsup:
/ Preventing tractor back flip #243
I recommended not "pulling" from the rear..ie pull from the front! post #6.
I don't think there has ever been a tractor "back flipping" using this method
/ Preventing tractor back flip #244
No, but a good chance of damaging the gears, transmission or other components.
Also, tires such as R-1's or R-4's are undirectional. You'd have to reverse the tires for traction.
I have pulled from the front on occasion, but that was for a pretty light load (smaller trees, for example).
/ Preventing tractor back flip #245
Maybe I'm missing something but you can still pull from the front in forward gear with the chain or cable attached to the front of the frame:confused:
/ Preventing tractor back flip #246
Yeah, I thought you meant pulling in reverse gear.
I suppose you could rig to the front weight bracket, but you'd want to keep the cable or chain low enough that it doesn't foul the tires, hydraulic lines, cables or linkages under the tractor. Also, changing direction might be a problem (if you needed to change direction).
/ Preventing tractor back flip #247
I would think that anyone trying to pull such heavy or restricted loads would take whatever measures to prevent the dreaded "back flip", rather than using a bigger tractor. Just trying to propose methods that answer the OP's question.
/ Preventing tractor back flip #248
I suggested that in the last "tractor flipover backwards" thread a couple years ago and basically got laughed at. I personally would prefer pulling from the front end, but only for a particular situation of short duration such as trying to get a vehicle unstuck, etc. I am NOT suggesting that someone pull their 6ft wide disc harrow from the front end all day long to plow a 100 acre field, just to make that very clear.
While tractor flipovers from the rear are not that uncommon, you rarely ever hear/read of one flipping over from the front end, even with 4x4 engaged. With just the two rear wheels driven in reverse, I would think that the chances get even smaller of flipping one over frontward but I won't say it'll never happen. Murphy's Law, you know?
Yes, I do realize that the ring & pinion gears are designed to be stronger in the forward direction, and not the reverse direction so you may be more likely to break something this way (maybe they should be stronger!:thumbsup:). I also realize a tractor won't pull quite as much weight going in reverse as compared to pulling from the rear (and going forward) because of the weight distribution, but again has anyone heard or actually seen a frontwards flip over happen?
Hey xtn, you want to draw up some vector force diagrams for pulling from the front end, and how it will go forwards just before it tips over frontwards??? :confused2: That should be good for another 200 posts in this thread! :p Sorry, just messing with you! :laughing: :D
/ Preventing tractor back flip #249
Just speculating but I don't think a majority of back flips come from pulling properly sized implements, I would think most come from trying to pull stumps or other objects that offer more restriction than the operator realizes. ?
/ Preventing tractor back flip #250
Most I've read about were stumps and such. The only one I know of locally (I'd posted this earlier) was a guy skidding a log up a slope. He was rigged (so I heard) to the drawbar, but the slope moved the tractor's center of gravity way aft.
/ Preventing tractor back flip #251
Prudence is the best safety factor, You can never be too careful.
Being aware of the possibilities will help most avoid the chances, getting in a hurry and taking unnecessary risks never help.
/ Preventing tractor back flip #253
You can pull from the front if you want to, I just hope I never buy a used tractor that you owned.
Tractors are desiged to pull from the drawbar. The stuff up front isnt strong enough to do any real pulling. Plus the fact that you are cheating yourself out of a bunch of traction, this having to take longer, or take smaller pulls (like when skidding logs)
Not to mention the fact that if you are pulling something any given distance at all, how do you turn??
/ Preventing tractor back flip #254
With the independent brakes, of course!!! :laughing: Really though, I don't pull from the front all that much. As I mentioned, I understand that the drivetrain is strongest going forward, and by design a tractor pulls best going forward. No argument there.
/ Preventing tractor back flip #255
The difference is I've very accurately stated every detail of my claims with regard to they're being generalizations and the conditions under which they are valid. The professor says the tractor can't go back too far because the drawbar leverage prevents it, and that's just not an absolute given.
Can you please address the part of my post that was addressed specifically to you?
xtn
/ Preventing tractor back flip #256
Yeah, probably not. But ability to pull is quickly lost as the front rises and the taut chain comes up under the rear axle and causes a lifting force on the drive wheels. A long drawbar lets you put all weight on the rear wheels safely.
larry
/ Preventing tractor back flip #257
Id tell em I want to see their tractor.
larry
/ Preventing tractor back flip #259
I'm curious, just how many times or instances do you use YOUR tractor to PULL something that is likely to cause a "back flip":confused:
Improper use and ignorance is what causes "back flips" not knowing how to use a tractor or the right sized machine for the required task.
When I'm in doubt I will choose precaution over taking a chance every time.
And as far as "stuff up front" goes I'm not talking about a welded hook on a loader bucket, the front of the frame on most tractors is just as strong as anything attached to the rear of the tractor including the rear axle assembly like the draw bar.
And by the way, Any tractor I have owned or used is going to be in better condition than one used by an ignorant operator that does not recognize the tractor's capabilities and regularly uses it beyond its intended capabilities, like trying to pull something that could in any way, shape or form cause a back flip!
/ Preventing tractor back flip #260
...just how many times or instances do you use YOUR tractor to PULL something that is likely to cause a "back flip":confused:
That's where I came to after fewer pages than this. Glad I have my winch.
2022 EZ-GO ELITE...
2006 CHEVROLET 2500 SERVICE TRUCK (A63291)
2006 CHEVROLET...
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2023 New Holland C327 Compact Track Loader Skid Steer (A61572)
2023 New Holland...
