Preventing tractor back flip
/ Preventing tractor back flip #261
And as far as "stuff up front" goes I'm not talking about a welded hook on a loader bucket, the front of the frame on most tractors is just as strong as anything attached to the rear of the tractor including the rear axle assembly like the draw bar.
i would differ on opinion to this statement. Most ag tractors unlike industrial tlbs basically hold the front and back together via the transmission to the rear axle, and perhaps loader braces. Tlbs have a dedicated subframe. When using the drawbar, its attached to the rear axle where most tractive force takes place. Pulling from the front with enough rear traction can put undue stress on the tractor. This is a balls to the wall hard pulling senario tho, as in repeated snatches bacwards under heavy power.
/ Preventing tractor back flip #262
I'm curious, just how many times or instances do you use YOUR tractor to PULL something that is likely to cause a "back flip":confused:
Not very often. I have been doing what I have been doing for MANY years. Not trying to sound arrogant, but I have never came close. And I have latched onto and skidded, or tried to skid logs that were just too big.
And I usually do it by chaining short and onto the 3PH, that way I can raise the log up out of the mud/dirt, and add a little weight to the back for traction. But with the loader out front, there is little chance of going over. But I an not reccomending anyone else do this either.
/ Preventing tractor back flip #263
SPYDERLK said:
He made at least one major wrong choice or several smaller ones that added up. The most efficient wrong choice would be to pull from the top link or its mount on the tractor.
larry
Heck, might as well pull from the top of the ROPS. Yes, pulling from above the rear axle is much more efficient way to flip, as the tractor only needs to crawl out from under the attachment point instead of wrapping itself backwards over it.
/ Preventing tractor back flip #264
BINGO.
While the frame up front may look all beefy and strong, it probabally doesnt go much past the motor. If you look, most tractors transmission-rear end connection is just the castings. NO frame.
And even on the tractors I have seen that have 1/2 frame, there reallt is no good place to even hook without adding some sort or hook or something??
Either way, its just not good on the tractor. But I guess its a good thing you cannot get maximum tractive force by doing this, or you probaballly really mess someting up.
/ Preventing tractor back flip #265
Can you please address the part of my post that was addressed specifically to you?
xtn
What was written was all the posts were based upon certain assumptions with little personal experience or any empirical data. That included my posts...not that you posted anything directed toward me, personally. I've never had a rear roll over...have you? The only time my front tires ever came off the ground had nothing to do with pulling from the draw bar.
The professor most likely had more statistical data resulting from actual rear rollovers and greater knowledge of tractor design and dynamics.
Your comment in an earlier post about the professor generalizing...well, what do you think you're doing? Exactly the same thing...generalizing. The difference is the professor has more credibility.
/ Preventing tractor back flip #268
Reading that story, brings a couple of things to mind.
Thinking of my own experience, I'm guessing that many of us, who have pulled such things, may have come closer to flipping the tractor, than we realize.
I'd say that the fact, that the combine stopped, was the key to the accident. My mental process always seemed like, "start slowly, so as not to break traction", then once you are moving, "give it some gas to keep the momentum up". At this point, a sudden stop, caused by the pulled object, could be "sudden death" or injury (if you are lucky).
/ Preventing tractor back flip #269
Thinking of my own experience, I'm guessing that many of us, who have pulled such things, may of come closer to flipping the tractor, than we realize.
Absolutely. Could cause a very quick back tip that proceeded past the driven point soley by inertia.:thumbsup: ... altho quick deceleration of the tractor mass from the height of the drawbar favors a quick transient shift of weight to the front. But with the engine at full song its ready to grunt and rare it up fast.
larry
/ Preventing tractor back flip #270
Actually, in addition to "inertia", if the combine stopped and the tractor tires stopped due to good traction, the tractor drive system would actually power the tractor mass backwards around the drive axle.
/ Preventing tractor back flip #271
Sure, but weve addressed the Physics imposed inhibitions on that above ... and in other threads. Over and over. The seeming fact that this is seen very seldom leads me to believe there is some specific difference that occurs in these instances. It would be good to see some good documentation -- or indeed any worthy of the word.
larry
/ Preventing tractor back flip #272
If it comes down to an article of faith or a question of belief, I'm going with, "it can happen." It doesn't cost me anything. I just wish it would make me tax-free. Believing it can't happen has a potential cost that I would not want to bear. And so:
I believe!
Can I get, Amen?!?​
/ Preventing tractor back flip #273
I believe!
Can I get, Amen?!?​
Its just as important to know what circumstances make it possible and what can be done to prevent it so you dont have to be excruciatingly careful all the time.
larry
/ Preventing tractor back flip #275
larry
So, I chain the front of my tractor low to a tree and pull from the rear with a winch and a block. 24,000 pounds max with a single block is more than I could easily get on that draw bar and traction.
Early one morning, my neighbor up the road called me up. The school bus blew the trunaround at his place at the end of the road. The driver (one of my bestest old friends) had backed the rear wheels over the edge of the creek bank (a ten foot drop to the water). I didn't know what I'd find when I got there with my 27HP Cub Cadet. One look and I had to laugh. The best I could do would be get the bus to rocking and have it go over the edge and launch my little tractor in the deal. I had to take a pass at the cost of my friend's embarrassment. I couldn't pull his bus, much less, his chestnuts out of the fire. It took and anchored wrecker.
I try not to bite off more than I can chew. This tendency comes with age, if it comes in time.
/ Preventing tractor back flip #276
I don't know if this thread is still on the tractor flip question, but here's my simplified view:
Assuming the tractor motor does not stall and nothing breaks... the motor turns the axle and the axle turns the wheel. Something must turn. If the wheel turns easier than the tractor, then you move forward or spin your wheels. If the tractor turns easier than the wheels, then the tractor rotates.
Another way to look at it: imagine you have a battery powered toy tractor. Grab the body and turn it on --> the wheels turn. Now grab the wheels and turn it on --> the tractor turns.
-Jeff
/ Preventing tractor back flip #278
-Jeff
That is correct, but no one is saying a tractor cannot flip al by itself if the tires are locked(like frozen in ice).
But now take a chain and affix to a drawbar BELOW the axle of that tor tractor. And attach that chain to something solid. Grab the wheels and now see what havvens??? The chain drawn up tight (behind and BELOW the axle) counters the nose comming up. Ib the chain dont break, the nose will NOT go on over unless the tractor goes backwards toward the chain. Which is counter-intuitive because the tractor is driving the other diraction.
/ Preventing tractor back flip #279
Interesting thought about the differences between cable and chain. The elasticity could be a killer. Definitely adds another force vector. Time is also a solid factor (when what happens, when forces are rising or falling). Small fractions of seconds can make big differences when big forces balance against each other. What do they call it, a "tipping point?" In the case of this question, the tipping point could be when the front wheels are three inches off the ground (or less).
Using my winch, I always fear a rigging failure. It would be hard to jump fast enough.
1024 (A63111)
1024 (A63111)
BAMA BUILT 7x16 Hybrid Dump Trailer (A68134)
BAMA BUILT 7x16...
2009 GMC SIERRA 2500HD (A67714)
2009 GMC SIERRA...
2015 Ford Transit Connect Cargo Van (A64556)
2015 Ford Transit...
2022 Wallenstein WP845-ORA Towable Firewood Processor (A66734)
2022 Wallenstein...
2015 Peterbilt 320 Roll-Off Truck (A66736)
2015 Peterbilt 320...
