Preventing tractor back flip
/ Preventing tractor back flip #181
If the pinion can climb a stationary ring, what prevents it from climbing a slowly rotating ring? You can climb a stationary ladder. Can you not also climb a telescoping ladder at the same time it is extending? Does your climbing action necessarily and absolutely prevent the thing from extending?
Ooooo I just thought of an elaboration to the above ladder analogy that really brings it into alignment with the tractor scenario.
Suppose you are on the upper segment of an extension ladder. Suppose there is a rope attached to your belt buckle that goes down, through some tackle (let's suppose at a 4:1 ratio), and is configured to raise the upper section as you climb.
Now it's going to take you extra leg power, because for each 12" rung that you climb up, you're actually moving your whole body up 15". The twelve inches from one rung to the next, as well as the 3" (remember the 4:1 ratio tackle...) that you have pulled the rung up as you took the step. That's not to mention the fact that you're lifting the weight of the ladder segment as well. So it will take plenty of extra leg muscle. But it is doable.
So you're the pinion gear. You're exerting power against the ring gear and climbing. As you do so, the torque is exerted through the ring gear, through the tires to the ground, raising the nose of the tractor, lowering the drawbar, and rolling the tires and ring gear back by way of wrapping the whole assembly up and over the chain. That whole path of the torque is your "tackle."
That all makes sense in my head. Please tell me somebody else is able to read my inadequate description and get the concept!?!?!?
xtn
/ Preventing tractor back flip #182
Yet AGAIN.
The point where the chain attaches to the draw bar does NOT move forwards, it MIGHT move slightly backwards, according to the height of the attachment point of the other end of the chain to the load.
The contact patch of the tires does NOT move backwards.
(BOTH regardless of the amount of traction, i.e. even it were on a cogged rail)
BTW, I can dead lift almost 350 lbs - "almost" because I used to be able to - a couple of years since I did though (-:
I could lift a 200 lb man standing in a bucket if the bucket and handle were strong enough.
I can not lift my own 190 lbs by the handle of the bucket if I am standing in that bucket.
Extend the above example - it doesn't flip with a normal length draw bar properly used.
/ Preventing tractor back flip #183
... This fact is developed in previous threads and was linked earlier. Starting over at 0, xtn is doing a good job, but probably dont know nuttin about whats really going on cuz he doesnt design tractors.
May I humbly suggest the possibility that those threads may have arrived at different conclusions had I been a part of them?
/ Preventing tractor back flip #184
May I humbly suggest the possibility that those threads may have arrived at different conclusions had I been a part of them?/QUOTE]
Don't think so!:thumbsup:
/ Preventing tractor back flip #185
Yet AGAIN.
Please review my drawings. Do you think they are in error? They clearly demonstrate that with a fixed length chain, as the nose of the tractor rises the rear tires' contact patch does move backwards. They also demonstrate that the connection point on the drawbar can move forward, depending ONLY on the arc the chain allows. The geometry requires these things as absolutes.
You can lift yourself in a bucket if you're pulling on a rope over a pulley or other tackle that is connected to the bucket. This is the analogous to the tractor situation. If the engine has enough power to lift the nose at all, then the paths I've illustrated may be reached. I say may because the further up the nose goes and the closer the drawbar gets to the ground, the more effort (power) is required because the mechanical advantage declines. But the advantage does not decline to zero unless the drawbar extends beyond the radius of the tires, so with enough power the flip can happen.
So I stand by my original statement: The tractor could flip UNLESS:
1. There is not enough power, or
2. There is not enough traction, or
3. The vector created by the resisting load reaches an angle that points it under the tires' contact patch.
Please note that the drawbar reaching the ground OR a sufficiently high connection to the immovable load such that the chain points down at a high enough angle to point at or below the contact patch of the tires... will satisfy #3.
/ Preventing tractor back flip #186
Then we are equally arrogant.
xtn
/ Preventing tractor back flip #187
It would have been a help, yes, but the threads I linked ultimately reached congruence with this one in the basics. You never know about conclusions - they differ among participants regardless of actual fact.
larry
/ Preventing tractor back flip #188
Additional point for LD1 to consider:
Although relative to a fixed coordinate system in space the tires are rolling backwards and therefor so is the ring gear...,
...RELATIVE TO THE AXLE HOUSING, REAR END CASE, PINION GEAR AND INDEED THE WHOLE TRACTOR, which are all rotating rearward at a higher rate, the ring gear is rotating forward as it should.
/ Preventing tractor back flip #189
Considering an immovable load, an unbendable draw bar, and an unbreakable chain, combined with unlimited torque, horsepower, and perfect traction, I believe what would happen would spin us up a freaking singularity and the birth of a new universe. Maybe we're messing with things that should be sorted out by the various deities.
I can hear George Carlin now ... Father, father, can God make a tractor so stable he himself cannot back flip it?
/ Preventing tractor back flip #190
Let's forget all the details we've been discussing and ask ourselves two questions:
1. Is it possible for the nose to rise up when pulling at all? At least to some equilibrium point? ANY equilibrium point?
2. Is it possible for the nose to rise up with momentum?
If your answer to both of those is yes, then you must believe it is possible to backflip a tractor by pulling a load. Sure, there are other conditions and factors that may prevent it happening, but it's POSSIBLE.
xtn
/ Preventing tractor back flip #191
I think the whole problem here is trying to equate this with BOTH infinite power AND infinite traction.
XYZ: you say that the tires DO roll backwards if there is infinite traction. But you are forgetting the infinite power trying to drive the tires in the opposite direction as that. Therefore, if power AND traction are BOTH infinite, this equation cannot be solved. Because infinite power meas that the tires will NOT spin backwards. Meaning the ONLY way for the tractor to move backwars is to slip/spin. And THUS infinite traction says that THAT canNOT happen. So we are stuck with an unsolvable equation.
You diagrams ARE correct IF traction ONLY was unlimited.
If power ONLY was unlimited, wheel spin would be inevitable.
Somewhere between these two lies the "real" world. And the simple truth that hooking to the drawbar WILL allow the front to raise into the air, but only to a point. Because as the drawbar rotates downward and forward, either the load is going to move, or the tires will spin. Both resulting in the front wheels settling back down. In the "real" world, flip-over highly unlikely. And the cases where it happens is most likely a result of operator error(running start, popping clutch, jerking, etc) or terrain, like pullig up a steep hill.
/ Preventing tractor back flip #192
xtn
Yes to both.
That is why I said 99% of the time. That other 1% for operator error. Things that cause enough momentum to actually backflip. Like jerking, running start, clutch popping, etc. and even steep inclines. I never did say it was impossible, because there are exceptions to every rule. But the physics clearly shows that is is VERY UNLIKELY. And in a steady/easy pull situation on LEVEL ground, it is NEAR impossible if the drawbar is lower than the axle CL.
/ Preventing tractor back flip #193
2. Backflips
● The second type of rollover is a backflip. In this scenario, there are two forces in action. These are REAR-AXLE TORQUE and DRAWBAR LEVERAGE.
● Rear-axle torque is the transfer of energy between the engine and rear wheels of a tractor. It occurs when the pinion gear in the Differential meshes with the crown wheel of the axle. Thus, the pinion which is driven by the engine applies a rotational force to the wheels via the crown wheel ( Figure 6). This may be described as the rear axle rotating with respect to the chassis.
Torque reactive force
Crownwheel drives tractor rear axle
Pinion is driven
by engine (torque)
Crownwheel is driven by pinion
Figure 6: The basic drive mechanism of a tractor
● If axle rotation is prevented as in the case where the tyres are stuck ( eg. in a bog, frozen to the ground or if the load is very heavy), the rotational force moves the tractor backwards around the rear axle, lifting the front wheels off the ground and a backflip can result. Since a tractor痴 centre of gravity is closer to the rear axle than the front axle, it may only have to rear to an angle of 70 degrees for the centre of gravity to pass outside the rear tipping axis. This is located between the contact patches of the rear wheels.
● A backflip can happen in as little as 3/4 of a second. At this speed, there is little chance that the driver will be able to take evasive action ( Figure 7). There are many circumstances where the reaction time may be even less than 3/4 of a second. This can occur when the Centre of Gravity is already approaching the rear tipping axis, for example, when the rear wheels of the tractor are stuck in a bog.
● Practices which involve rear axle torque reactive force acting to cause a backflip include:
1. Driving off in low gear but with high engine speed.
2. Attempting to drive the tractor forward when the wheels are unable to move forward.
3. Rapid engagement of the clutch of the tractor.
4. Rapid acceleration, particularly when driving uphill or pulling a
/QUOTE]
Nope, I'll defer to you. :D
I've sat in the tractor seat doing things that could cause it roll over backward!:thumbsup:
http://farmsafewa.org/media/1377/Tractor Rollovers.pdf
/ Preventing tractor back flip #194
There is one thing that is infinite already as per the original question... The far end of the chain is infinitely immovable.
There are three things that MIGHT be made infinite: Power, Traction, and Weight of Tractor's Nose. We can make any two infinite and still have a workable situation.
We could have infinite power and infinite weight on the nose. The result is no traction.
We can have infinite traction and infinite weight on the nose. The result is no power to do anything, ie. no movement at all. But hey it's a solvable result.
And we can have infinite traction and power. The result is the nose comes up. And without something to stop it, it will keep going up and over.
Hmmmmm. Let's look at things from a different direction. My diagrams don't need infinite traction or infinite power. Power only needs to be enough to raise the nose and overpower the increased effort required as the drawbar approaches the ground. Traction only needs to be enough to put that amount of power to the ground without significant slippage. Neither one has to be "infinite." They just have to be enough to flip the tractor. Hey, I admit the tractor is unlikely to flip under normal circumstances, but if you want to know how it could happen even without jerking, that's it in a nutshell.
Let's look at it from another way still: You say infinite power will not let the tires roll backwards. That just isn't true. Since the weight on the nose is not infinite, the infinite power can flip the tractor over backwards with the tires locked into position, right? Like if the tires are frozen to the ground, right? Rolling them backwards a foot or so while the power raises the nose isn't that much more to overcome than having them sit frozen to the ground while the power raises the nose. So your claim is false anyway.
I don't get why you are unable to reconcile an engine trying to turn the tires forward but them rolling backwards anyway. If there is enough (not infinite) power and traction, the geometry simply requires it and there is no way around that. Suppose you wrapped chains around the tires to hold them in place (simulating the frozen-to-the-ground scenario) the tractor could rear up and flip, right? Now suppose you use the chains to pull the tires backwards a bit while that is happening... would the universe explode? No of course not. The tires can roll backwards - if the net sum forces dictate it - at the same time the engine is twisting the tractor up and over, and this can all happen without breaking any laws of physics. And when the drawbar is chained to an immovable object, the net sum forces DO dictate it.
xtn
/ Preventing tractor back flip #196
Egon,
1. In your post, #193 above, I have no idea what point you're trying to make with regard to the current discussion, and I'll be surprised if anybody else reading this has any idea. We are currently exploring the dynamics involved way beyond what the text in your link describes. I mean nothing is wrong with it, but it's an incomplete analysis compared to this thread, so I don't really know what your point is. Anybody know what the point of Egon's post is? Please chime in if you get something relevant from Egon's post that I've missed.
2. If I'm arrogant for thinking I might have had any effective input to a thread, aren't you equally arrogant for just deciding that I wouldn't have?
xtn
/ Preventing tractor back flip #199
The chassis rolls backward. We dont need infinite power .. just relatively high power and very low gearing so that extremely high force is available. Since things would progress slowly there would be no momentum issues. You posed tracks cast in concrete in a previous thread. To limit forces needed, use a 2 wheel tractor, long chain to limit angle change. : Short drawbar[< R]= full back flip, long drawbar[>R] = drawbar touches down and engine stalls or something breaks. Tractor moves backward in both cases after chain tenses.
larry
/ Preventing tractor back flip #200
xtn
CAll me hard headed, but I still dont see the tractor tires rolling backwards as the chain tenses up.
Stop and ask yourself what causes the front to climb up anyway? isnt it the the "equal and opposite" reaction force to the tires turning forward??
So if the tires roll backwards wouldnt the front set back down?
And dont we have the clutch engaged and infinite power trying to turn the tires forward?? yet, somehow that infinite power and traction tightens up the chain in a way the tractor rolls backwards??
And to open up another can of worms here, I think I an in agreement with Roy Jackson, in that a straightr pull, with the chain STRAIGH and LEVEL with the drawbar, if the drawbar is below the axle, it does pull down on the front.
XYZ: and others involved, I know it may sound childish, but I encourage you to do this. Get out one of your 1:16 scale model trators. Set this very expirement up. Attach a string to the drawbar and then to something immovable on a bit of an angle like your diagram. Then with your hands, try to drive the back tires. You can get a good bit of weight/traction just with your hands. You may be suprised at what happens. I did this yesterday before I even posted.
2022 EZ-GO ELITE...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
John Deere 4455 (A64119)
John Deere 4455...
John Deere 4044M (A60462)
John Deere 4044M...
CATERPILLAR 232B SKID STEER (A64279)
CATERPILLAR 232B...
2025 Miscellaneous Mini Excavator Attachments (A61572)
2025 Miscellaneous...
