Pressure washer
/ Pressure washer #11
We've had something called a Black Cat electric washer for a number of years. The chamber to put stuff into has never worked but everything else is fine. Think it was bought at Lowes. Not sure.
Mine has that chamber, but will only siphone out of it if you use the low pressure soap tip.
Once you switch to a high pressure tip, it stops siphoning out of that canister.
/ Pressure washer #12
Got sick of cheap washers crapping themselves, bought an electric Stihl with metal pump, also have a 36v Ryobi for the boat
/ Pressure washer #13
Ok, I took a look... it is a Mrliance. Does a great job. It was about $99. Probably more now...
/ Pressure washer #14
I bought a Coleman power washer probably going on 20 years ago, mainly for power washing my deck, concrete pads in front of the garage, and sidewalk. It has a Honda engine on it that starts with one or two pulls every time (if you turn the fuel and ignition switch on). The only problem I've had with it was when a friend borrowed it in the fall and didn't run the water out of the pump, which froze and broke the pump casting. Bought a new housing and piston/valve kit, and it's working like new. I think friends have put more hours on it than I have.
159115 (A60430)
159115 (A60430)
1985 Ford Ltl9000 Tender Truck (A61307)
1985 Ford Ltl9000...
2014 Crossroads RV Elevation T/A 5th Wheel Toy Hauler Travel Trailer (A59231)
2014 Crossroads RV...
HYSTER H80XL STRAIGHT MAST FORKLIFT (A62129)
HYSTER H80XL...
2020 Bobcat MT85 (A53317)
2020 Bobcat MT85...
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
