Cleaning Mildew, Stains from Asphalt Roof Shingles
   / Cleaning Mildew, Stains from Asphalt Roof Shingles #1
snpower
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
We live in a semi wooded lot and there are some pretty good dark stained areas on one part of my roof. I've tried various products by several manufactures (30 Seconds Outdoor Cleaner, Scott's Outdoor Cleaner, that have in the past, worked well. on lighter stains. Even at full, non diluted strength - these are not cutting it. I am applying with my 3,000 PSI power washer and a long reach nozzle.
Looking for product/technique recommendations! Thank you!
   / Cleaning Mildew, Stains from Asphalt Roof Shingles #2
I get some sort of house wash mix from the pressure washer store. It has some bleach smelling stuff with detergents or surfactants in the mix. I spray it on with the low pressure nozzle, chemical injector hose and let it sit a bit. I wash it off with the high pressure nozzle held a good bit away from shingles. It has worked pretty good on my white shingles on house and barn and on my Mom's brown shingles. Pressure washer is rated at 2,700 PSI. It is not getting clean from high pressure but it needs more pressure than 40 PSI of water hose. Soap Warehouse Brand of House Wash Supreme. I think this is a house brand of the pressure washer store I visit.
Also note that my injector works with a short wand. When I use the long reach 20 feet extendable wand, the long wand does not work with the injector system. Only with the short wand. I get a nice bit of sudsy foam on the roof. Foam does not last long but it is still there working, assuming not working on a hot roof in the sun. On the 4/12 roofs I can walk on the roof. 9/12 I cannot walk. 6/12 on Mom's house is the edge of my walking abilities.
   / Cleaning Mildew, Stains from Asphalt Roof Shingles #3
   / Cleaning Mildew, Stains from Asphalt Roof Shingles #4
^ this works good.
One of my problems with getting dark stained areas on my asphalt shingles was the oak trees dropping leaves and acorns. Removed oak trees, then placed a new roof after 31 years.
The zinc strips are working good on the north side of my house with a 12/12 pitch. Sunlight on the south side takes care of the problem there.
   / Cleaning Mildew, Stains from Asphalt Roof Shingles #5
FWIW: I've also used copper strips along the ridge line, especially for moss. For algae and moss lower down, I have used "Wet & Forget". It probably works on roofs as well. I have never used it on a roof.
Walmart, Costco, Ace, etc. Comes in an "extreme reach" spray applicator for use on a hose end to reach roof tops.
All the best,
Peter
   / Cleaning Mildew, Stains from Asphalt Roof Shingles #6
   / Cleaning Mildew, Stains from Asphalt Roof Shingles #7
Looks ponytug and I were responding at the same time. LOL Jon
   / Cleaning Mildew, Stains from Asphalt Roof Shingles #8
Roll copper strip material 2" wide, fastened near the ridge cap is what I did. Copper kills almost any growing green thing.
Years ago door knobs were made of copper, it kills bacteria.
I put copper sulfate granules in my septic tank, flushed down the commode. It kills tree roots, actually all roots growing in the septic field.
Got a stubborn unwanted tree, scatter a couple handsful of copper sulfate around the drip-line. Next year tree is dead.
   / Cleaning Mildew, Stains from Asphalt Roof Shingles #9
I had my house re-roofed after 30 years. New shingles have a granular copper mix in the shingle. They have been up there for twelve years now. No stains.
   / Cleaning Mildew, Stains from Asphalt Roof Shingles #10
"Wet it and forget it", applied with low pressure bug sprayer. It might take two applications applied a few weeks apart. It works just like the name.
   / Cleaning Mildew, Stains from Asphalt Roof Shingles #11
Pool chlorinating liquid worked prety good for mine. I mix it 50/50 in a pump sprayer. Killed the heavy moss I have on the back side of my shed and light algee growth on my house.
It's also way cheaper than these other name brand products.
   / Cleaning Mildew, Stains from Asphalt Roof Shingles #12
Snpower Thanks for starting this thread, the north facing roof of my house suffers from this issue, it’s not real bad but after reading this thread I’m going to start looking for a way to treat mine.
   / Cleaning Mildew, Stains from Asphalt Roof Shingles #13
Silly question, but how do you secure the zinc strips?
   / Cleaning Mildew, Stains from Asphalt Roof Shingles #14
I can't imagine using a pressure washer of any rated pressure to clean my roof! Insurance companies are mandating roof replacement when the roof "appears" to be worn, which is basically the granules that have washed away! I can put up with moss and mildew better than paying for a new roof!
Zinc works great, and if the pitch of your roof isn't much, heavy enough to stay in place. I would think daisy chain them together by drilling a hole in them and bolting them together, or tie them with a good string/rope. Make sure to leave an opening for water to wash the leaves around them, or you will be adding a new problem.
David from jax
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
(INOPERABLE) DYNAPAC DOUBLE DRUM ROLLER (A58214)
(INOPERABLE)...
SKID STEER MOUNTING PLATE (A60430)
SKID STEER...
206707 (A58375)
206707 (A58375)
BUYERS PREMIUM & PAYMENT TERMS (A59905)
BUYERS PREMIUM &...
2001 Chevrolet Suburban SUV (A59231)
2001 Chevrolet...
