Buying Advice Pressure Washer
/ Pressure Washer #21
As others have said,the type of pump is the most important variable. The axial pumps do not hold up to heavy,frequent use.Make sure you get one with a CAT pump.
/ Pressure Washer #22
I have been shopping also and noticed some of the models (gas or electric) at home depot say "no bleach" on the soap dispenser.
I don't think bleach is good for any pressure washer pump......I use a separate portable pump tank to mist the bleach solution before blasting it with water
Works great for the boat or deck
/ Pressure Washer #23
1 gallon airless sprayer works descent enough for bleach.
not sure if i would even want bleach to go through a pressure washer. to much splatter from pressure washer, and would get bleach all over the place. resulting in "spots" were the bleach was.
with airless sprayer, i could keep the misting / splashing down to min. when using bleach.
3PT POST HOLE DIGGER (A63291)
3PT POST HOLE...
KMC 3pt 6 Row Vine Lifter (A64119)
KMC 3pt 6 Row Vine...
2025 IREV Electric Scooter (A64194)
2025 IREV Electric...
2008 CATERPILLAR D4K XL CRAWLER DOZER (A64279)
2008 CATERPILLAR...
80003CFL (A61568)
80003CFL (A61568)
Challenger 65C/70C/75C/85C Tractor Parts and Service Manuals (A63117)
Challenger...
