Buying Advice Pressure Washer
/ Pressure Washer #21
As others have said,the type of pump is the most important variable. The axial pumps do not hold up to heavy,frequent use.Make sure you get one with a CAT pump.
/ Pressure Washer #22
I have been shopping also and noticed some of the models (gas or electric) at home depot say "no bleach" on the soap dispenser.
I don't think bleach is good for any pressure washer pump......I use a separate portable pump tank to mist the bleach solution before blasting it with water
Works great for the boat or deck
/ Pressure Washer #23
1 gallon airless sprayer works descent enough for bleach.
not sure if i would even want bleach to go through a pressure washer. to much splatter from pressure washer, and would get bleach all over the place. resulting in "spots" were the bleach was.
with airless sprayer, i could keep the misting / splashing down to min. when using bleach.
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
Challenger 65D/75D/85D Tractor Parts and Service Manuals (A63117)
Challenger...
Case skid steer wheels and tires (A63689)
Case skid steer...
iDrive TDS-2010H...
1974 Ford F600 Grain Truck (A63118)
1974 Ford F600...
