Buying Advice Pressure Washer
/ Pressure Washer #1
TractorBob1529
North Carolina
MX5100DT
Like tractors, there are tons of pressure washers out there. I don't have a preferences to one brand or another...I just don't know what to look for. I need some advice, guidance on what to look for in a pressure washer. General use around the house and cleaning equipments. Like to not spend a fortune, $300-$500 range.
Like to know the difference b/t horizontal vs vertical pumps too.
Help please!!!!
/ Pressure Washer #2
If it was me, I would go with a gas powered troy built.
And I see you have a M-F 1529. And with my experiance with M-F 1528 (Please stay away) from the radiator with a pressure washer.
The aluminum radiator fins, they bend very easy. I didn't know with my 1st. tractor, and used a pressure washer and closed off 1/2 of the radiator. (man did I feel stupid) I was going to replace the radiator, $600 bucks was an expencive lesson, but NAPA sales a radiator fin comb for 15 bucks that saved the day.
Its better to blow it out with a air hose .
david
/ Pressure Washer #3
2000PSI, cheapo / on sale / clearance works for me.
recently picked up a "dirt devil" pressure washer. works good enough. i do not need 3,000 plus PSI. to much PSI, and hit any sort of wood with a pencil led jolt of spray, and you can splinter the wood and tear it a part. when cleaning decks and like. set the nozzle to a wide spread pattern, and keep noozle 1 to a few inches away from wood decks. (depends on wood) and it does its job.
the 1500 PSI (cheapest) out there, can work, but the little extra PSI is fine enough for me.
gas powered vs electrical. any were i need to go, to use a pressure washer, needs water, meaning either garden faucet, or a well. both which should have electricity. i do not need another engine to take care of. and amount pressure washer sees it's use. not worth trying to deal with "old gas" and then carb getting gummed up.
if you needed to pump water out of a lake or stream, and haul water for animals. a gas pressure washer, would be something to consider.
as far as pressure, i do not want "high pressure" that begins tearing the paint off of a car or tractor.
/ Pressure Washer #4
whatever you buy get one with a cat pump...if you do you will be happy in the long run. Brand doesnt mean much. Motors are never the problem its the pumps that go out.
/ Pressure Washer #5
I have this basic Northstar model: NorthStar Pressure Washer - 3000 PSI, 2.5 GPM | Gas-Cold Water | Northern Tool + Equipment and it's been good for a couple of years of occasional use. It was on sale for $350 when I got it. Now they have some Powerhorse models that are priced pretty low. Pretty sure the Powerhorse models have Chinese Honda clone engines. I still have my 1500 psi electric. It's okay too. Higher pressure and flow lets you clean faster, holding the wand further away with a wider angle nozzle. I like the traditional nozzles on the Northstar. It also accepts common accessories.
/ Pressure Washer #6
I bought one of these..... Honda 2700 psi 2.4 GPM Gas Pressure Washer-UT80993A at The Home Depot
Not an expensive one but really churns out the power......One thing I do is to not let it idle with the unloader too long......maybe a minute max......If I have to I just keep trigger on......these pumps can overheat
This unit has the built-in soap (just change the nozzle and the soap comes out at low pressure
An extra 25 hose is handy too......it gives you a back-up in case of a leaky hose and gives the extra length
/ Pressure Washer #7
I've got three in the family and each has it's purpose.
Probably use the $69 one from ACE Hardware the most... it's electric, 1.6 gallons and 1600 psi.
My brother bought a Honda powered unit from Costco last weekend for $249... looks ok.
I have a 11hp Honda Powered unit with a CAT pump that I paid about $800 for 15 years ago... mostly use it for whole house wash downs, clean swimming pools and walks...
/ Pressure Washer #8
Not to hijack but a related question. Are the ouitput pressures variable on these pressure washers. So if i bought one that had 3000 psi capability I could dial it down for more sensitive jobs?
/ Pressure Washer #9
By adjusting the spray pattern the intensity can be controlled.
Some require switching tips and other have adjustable spray wands with a twist.
/ Pressure Washer #10
i take my original post back. having warm water, vs cold water. if you had a pressure washer with a heating element on it... hhmmsss.
/ Pressure Washer #11
I have been shopping also and noticed some of the models (gas or electric) at home depot say "no bleach" on the soap dispenser.
/ Pressure Washer #12
/ Pressure Washer #13
I have had a number of electric power washers and a pair of gas powered models and for 90% of my use I will pick an electric model over a gas powered type. For car washing, cleaning siding, etc. you can just stop using an electric model. But with gas power, it can be a huge PIB having to stop/start/stop/start all the time.
I almost never use my gas model now except for large jobs that need super cleaning power like decks and sidewalks, etc.
/ Pressure Washer #15
I like the idea of the electric pres. washer and been looking at the Greenworks at Lowes.
Shop Greenworks 1700 PSI 1.4 GPM Electric Pressure Washer at Lowes.com
It's got 201 reviews with overall rating of over 4 out of five. Has anyone had any long term review of this washer. It's on sale too for $159.00.
Looked at the specs....13 amps is a fair size motor, I like the really long power cord and hose lengths. Not sure how you store the hose or power cord but to me those two things are a huge PIB about most power washers. I would LOVE to have a reel of some kind to wind the cord up. I am not a frequent Lowes customer and have never seen this brand of power washer but it does appear to be sturdy and well built.
/ Pressure Washer #16
I had an electric one about 1500 psi and I hated it. Took forever to get anything clean. Got a Honda powered Husky 3000psi rig and never looked back. Love it.
/ Pressure Washer #18
I had an electric 1700 psi unit but it was too slow and couldn't handle tough jobs like cleaning grime from plastic lawn furniture. Now I have a 3,000 psi gas engine unit, Briggs & Stratton washer with of course a Briggs engine and it has been doing everything I need for the past 3 years. I don't think the normal electrics are up to the job because of the power it takes. Need 220 volt or short cords with 12 gauge wire to a 20 amp circuit on a 110 volt line.
/ Pressure Washer
Never was a Lowes shopper till I moved to WNC. Just getting to Lowes takes 30 minutes, the nearest Home Depot is about 100 miles away. That's why I shop Lowes, plus I get 10% for being a veteran. Anyways...looking at a gas pressure washer now.
Shop Troy-Bilt 2700 PSI 2.3 GPM Gas Pressure Washer at Lowes.com
Some reviews, good and bad. This unit is down to $269.00 plus another 10%. Decisions, decisions!!! :confused2:
I'm going to try something out and in 30 days Lowes may see a return. I'm going to use it like I stole it.
/ Pressure Washer #20
That is a super price for a gas power washer...and that Briggs engine is the same one that powers most of the new push mowers with a Briggs engine. I have a 2 year old mower that uses the Briggs 6.75 torque model and I just love the engine, so easy to start, very thrifty on fuel, and oil consumption is almost zero.
2012 International (A59230)
2012 International...
2019 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2019 ASV RT-25...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
iDrive TDS-2010H...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63688)
2023 Kubota L3560...
2018 John Deere 333G Track Loader (A63111)
2018 John Deere...
