Preheating question
/ Preheating question
There are some pictures under the u-built forum. No pictures taken today. The ears are welded on, only a little undercutting. Dc stick is another learning curve for me. I had some trouble getting the heat into the right area. I finally found a use for that old toaster oven I have been keeping in the shop. It worked great to pre and post heat these small pieces.
Cam
/ Preheating question #12
I went over there and looked. You do some nice work! :thumbsup::thumbsup:
Thank you.
My wife bought me a new welder and a cut master 52 plasma cutter for Christmas in July. It has been an enjoyable learning curve. I was able to borrow the mag drill from work to do most of the hole drilling. I have since bought an adapter and the first of many annular cutters to use in my drill press. Some of the smaller parts I was able to get cut on the plasma table at work.
Cam
/ Preheating question #14
Yeah those annular cutter are the only way to go. ;)
Now I have annular cutter envy, the down side of tractors by net
Cam
/ Preheating question #16
They come in handy when you want to saddle pipe too.
/ Preheating question #17
I looked all over, and cant find the thread for the pics. Any help buds?
I was not real happy with the way the ears came out, the 1/8 rod was only 3/32 and there was just not enough weld material. I got a few 1/8 rods dorm the rod oven at work and did 2 more passes. Everything looks better. I was a little hot with the smaller rod.
Cam
Takeuchi TL12R2 (A60462)
Takeuchi TL12R2...
2009 Kubota M108S (A60462)
2009 Kubota M108S...
429983 (A61165)
429983 (A61165)
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
ATTENTION PLEASE READ (A60463)
ATTENTION PLEASE...
Iranch IRMC High End Massage Chair (A60463)
Iranch IRMC High...
