preheating glow plugs question
/ preheating glow plugs question #1
sweep
Ohio hill country
2006 TC45A
Hello
Just purchased a new TC45A. In the owners manual it says you must preheat the glow plugs but one paragraph down it say you do not have to preheat.
I figure you would need to preheat in the wintertime but what about the summertime? My tractor starts fine in warm weather without preheating but should I preheat the plugs the first startup of the day in summer?
Thanks
sweep
/ preheating glow plugs question #2
I preheat any diesel first time starting cold. After that, as long as the engine is warm I just turn the key, no preheat.
/ preheating glow plugs question #3
I agree. Jay
/ preheating glow plugs question #4
Doesn't that tractor have an automatic preheat timer switch? My TC33D had one and it went out and the dealer had it in doing a conversion to the hydraulic system, he just ran a toggle switch out beside the steering. I liked the idea so I put a push button on it and ran it through the dash near the key. When it is cold it won't start so I hold the button for about 4 to 5 seconds and she fires right off. After that I don't have to use it anymore the rest of the day if it is a warm day. And in cold weather if you don't let it set to long it will start.
When the engine is warm you don't need the glow plugs anyway. As far as I am concerned it probably saves the glow plugs.
/ preheating glow plugs question #5
I too pre-heat 1st time out - same in my truck.
But it's a good question....if it's real hot out and the fuel fires easily, would it harm anything to let 'er rip in the summer w/o pre-heating?
I doubt it would matter, but maybe one of the diesel experts would weigh in (hmm, or perhaps I should have done a search 1st - sorry if it's already covered and covered ...) :)
~Paul
/ preheating glow plugs question #6
~Paul
Some do, some don't. Usually the diesels with a combustion pre-chamber don't start good without the glowplugs. The DI's Direct Injection ones don't really need a glowplug until it is 32F or lower.
TRACTOR SHEDDER (A60736)
TRACTOR SHEDDER...
Bobcat A770 (A60462)
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
2014 F-150 STX (A56438)
2014 F-150 STX...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
500 BBL FRAC TANK...
