PowerTrac Customizations
/ PowerTrac Customizations #61
Re: PowerTrac Hook-em Up
Paul:
Everything I have assembled would be a bit too big for the 425. The quick attach plate is bigger.The length of the Lackender hoe would be too much. I posted a note to MossRoad, however, about the CatDigger on the Cadplans list. It is 4' long, I think, which would fit the 425 nicely. The outside 4' of any backhoe would work, I think, if you cut it off and welded on the quick attach plate, retaining only the bucket, end of the arm and cylinder. Similarly, my 4 in 1 bucket is 505 lb., but it is 60" heavy duty. WR Long can build smaller and lighter, as can other suppliers. The important thing is that with the Power Trac you are starting with really strong front lift equipment, lift and curl for the bucket or to act as the boom for the hoe, and the auxiliary PTO already set up to run the bucket or hoe hydraulics.
/ PowerTrac Customizations #62
"<font color=orange>Charlie, can you show in a picture how you attached the hitch to the plate? From the one picture it appears you have some type of pin set or is the hitch welded to the plate?
</font color=orange>"
Paul:
Sorry I missed your question last night. We started with the standard Power Trac quick attach plate. A 2" receiver ($19.95 from a trailer supply company) was welded end to the plate at about the center. We then added some flat stock with holes, thus bracing the receiver and providing attachment for the two bottom hooks and the side shackles.
Finally, the multiple ball and pin hitch is an off the shelf purchase. It is held in with the standard pin through the 2" receiver. We can use that insert either on the front or the back, where we welded the receiver a couple of weeks ago. In fact, the multiple ball hitch can also be used in the pickup truck to pull a trailer with the Power Trac on top.
Sorry no picture of the separate insert. My photos are limited since I don't have my own digital camera and haven't gone to the trouble of taking film pictures.
/ PowerTrac Customizations #63
Charlie,
Thanks for the update regarding the hitch, I have a good idea now of what you have put together.
Hate to be a copy-cat, but plan on doing the same based on your experience.
Your humor regarding the top was great.
Paul
/ PowerTrac Customizations #64
MossRoad,
Did you put the additional lights on the ROPS?
Also, have you or anyone else looked into a chipper that would hook into the hydraulic's on the front end?
Notice that PT has a winch, did you happen to see this when you visited PT?
Paul
The weather still hasn't been nice enough to remove the ROPS and install the light brackets. They are cut to size, just waiting for a few good days in the 50's.
I have a line in at several lawn and garden shops in the area looking for a chipper/shredder with a blown motor that no one wants to repair. I'd like to convert it to hydraulic. It might be a while. The shops all tell me that with all of the damage from the tornados last October and the ice storm in January, people are getting them repaired, rather than junking them. I can wait. I inspected our property after each bout of bad weather and, fortunately, we had little damage. Some stuff that was already down in the big woods just came down a little sooner.
I never visited Power Trac, so I didn't see the winch. Maybe someone else did. There is a thread on this board about winches. One mentions some hydraulic winches. I was considering one, however, I have been able to drive the PT425 everywhere so far. (Charlie, please don't flame me on this). I will look into it further. When we move our to our property, it would be handy for pulling some trees down the bigger slopes.
I welded up a trailer hitch like the one that I diagrammed earlier. It still needs some work and painting, but I think it will work. If it doesn't, I've only lost about $20.00 and a dozen welding rods.
/ PowerTrac Customizations #66
MossRoads,
Thanks for the update, sounds like your tractor time has been limited.
Still following you and Charlie in your exploits. This is shaping many of the decisions for my tractor needs.
Paul
/ PowerTrac Customizations #67
MossRoad:
Don't worry about flame from me about not yet getting a winch. The one I have my eye on is electric, and still on top of a truck where my brother uses it to load logs to get to his sawmill. I didn't look at the one at PowercTrac.
Your chipper-shredder project sounds interesting. I hope you find one soon, so you can report how to do it.
I'm still researching solenoid valves to select one to put in series with the aux PTO. Terry Estep, at Power Trac, said that it should work fine. I got a rocker switch at a boat store which will work for testing. Who knows, within a couple of weeks, I may be able to unjitch and back up, ripping the ends off my hoses. We Power Trac users certainly have to try to keep up with the Chalkleys.
/ PowerTrac Customizations #68
When I was working in truck repair one common repair was replacing the air hose ends on the trailer hoses. Guys would get out dolly down, release the 5th wheel and get back in and drive away. One good thing you only lost the air and didn't have a mess of hydraulic fluid to clean up and replace.
/ PowerTrac Customizations #69
Charlie - Smart-aleck! /w3tcompact/icons/smile.gif If you can't manage to rip the ends off your hoses, let me know. I'll come do it for you - I'm sure I know how! /w3tcompact/icons/laugh.gif
/ PowerTrac Customizations #70
Mark:
I don't recall, but it's possible one of the photos of my PT 1845 mods has a broken anvil in the background. For people of our advanced destructive capability, needling someone about breaking a couple of hoses is merely a nod by an old pro to an amateur. We'll defer to you and others when it comes to making a machine more useful. At making it useless, however, we take back seats to none.
So far with the PT, the only damage has been when it ran over it's carefully positioned loading boom. Turning the ROPS canopy into the barn roof hardly did any damage at all. But, better weather is on the way, and the possibilities for destruction are infinite.
Yeah, I'll have to admit to a gouge or two in the garage walls in the first few days. That articualtion is kind of tricky in tight quarters, but every day it gets easier. /w3tcompact/icons/smile.gif
/ PowerTrac Customizations #72
Charlie - You're pretty good. I've broken a lot of stuff in my time, but I don't recall ever breaking an anvil! /w3tcompact/icons/laugh.gif
/ PowerTrac Customizations #73
<font color=red>I've broken a lot of stuff in my time, but I don't recall ever breaking an anvil!</font color=red>
Something to aspire to.
[Actually, they're easy to break - you drop them on a concrete floor. Move your feet smartly after release.]
Re: PowerTrac Customizations 3pt 5\' Box Blade Mod
Popped off my snow plow and popped on my forks. Went behind the garage and dug out my old 5' 3pt hitch box blade scraper. Wanted to see if it is too heavy for the PT425. I tossed it around like a toy, so I brought it up to the garage. I'm going to weld on the quick attach plate later this week and try it out in the garden. I'm only going to weld two beads, one on each side, for testing. If the PT seems able to handle it, I'll finish welding it on all the way around.
Pics WILL follow! /w3tcompact/icons/tongue.gif
/ PowerTrac Customizations #75
Guys with top 'n tilt brag about the value of tilting the box blade horizontally. Of course, mounting a swiveling quick attach and a cylinder to tilt it would only be just a little more work, right? Then maybe make it so it will tilt the snow blade, too ... and then ...
Now the tilting action of top and tilt is already built in with the dumping action of the PT425's front end loader arms and dumping mechanism. But how would I get it to tip horizontally?
That would require some sort of big pin arrangement...similar to what is on top of my mower, yes? And then some sort of frame and hydraulic cylinder to provide the tilt action.
Oh, man... this project just got un-simplified. Is horizontal tipping of the box blade really worth it? I'll have to investigate further!
/ PowerTrac Customizations #78
MossRoad:
Worth it? The project is to be evaluated only within itself, not whether the product actually does something. And there was a convincing thread some time back with the core theme that box blades are worthless in all applications, and only continue to exist so experienced tractor types can abuse newbies -- sort of like mechanical snipe hunts.
On my list for down the road is a swivel adapter. Your post may move it up the list, but I do have a little fence and farm work that seems to interfere with the modifications.
But, think of this:
Many of us have an old axle or two around. On a trailer, the stub axle often has a four bolt flange, that would easily weld to a PT quick attach plate. The wheel hub would provide plenty of attach methods for the implement. Then all you need is a couple of pieces of bar, channel, etc. and a hydraulic cylinder.
Of course, the geometry has to be set so you can turn it a bit more than 90 degrees, so when you fabricate your grapple, you can pick up a post from horizontal and lift it vertical, and then maybe we can put together a TBN group buy of solenoid valves...
Hey, I measured my 5' box blade this morning and it is 6'. It must have expanded over the last few years. Now I'm still going to have to see if the PT425 can pull it through the soil /w3tcompact/icons/smile.gif
/ PowerTrac Customizations #80
Rat, could you explain to me the difference between a 6N1 and 4N1 bucket ?
Goodyear 480/80R46 Tire and Wheel set (A65640)
Goodyear 480/80R46...
2011 FORD F-150 (A65643)
2011 FORD F-150...
20ft. x 8ft. Shipping Container (A65640)
20ft. x 8ft...
2009 Dodge Charger (A64194)
2009 Dodge Charger...
2007 STERLING L7500 TANDEM AXLE DUMP TRUCK (A59906)
2007 STERLING...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
