PowerTrac Customizations
/ PowerTrac Customizations #101
Re: PowerTrac 1845 4 n 1
Sedgewood - You can talk to Long directly about the PT bucket, if you like (it's just a correctly-sized regular Long 4-in-1 with a PT attachment plate welded on it), but you'll have to buy it from Carver or another Long dealer. Long can also perhaps tell you if there's local dealer, but it doesn't make a lot of difference, in my opinion - Carver has as good a price as anybody and by now he probably knows what a PowerTrac is anyway... /w3tcompact/icons/wink.gif
/ PowerTrac Customizations #102
wasabi - <font color=blue>I just want to echo Sedgewood's accolades for Charlie, MossRoad, MCHalkley and others who so tirelessly expound upon the virtues of their powertracs (braggerts, all of you!).</font color=blue>
Just to set the record straight (I do enough misleading around here myself, without others getting into the act /w3tcompact/icons/smile.gif: Ok, so I'm a braggert. /w3tcompact/icons/tongue.gif Ok, I sometimes engage in tirelessly doing something which you are as welcome to call expounding as others are to call something less flattering. /w3tcompact/icons/shocked.gif But, alas, I'm not a PowerTrac owner, though I'd like to have an 1845 or something that size for "little jobs" (please, no offense intended here, you 1845 owners - everything is relative). I suppose the case could be made that I've done about as much as anyone to encourage others to look seriously at PowerTrac before buying anything, but I'm an EarthForce EF-500 owner. I came as close to buying a 2465 as anyone can come to buying anything, but didn't. For my needs the EarthForce machine is better. My needs are, shall we say, a bit out of the ordinary from the average TBN'er... /w3tcompact/icons/laugh.gif But, still, definitely not unique - there are quite a few others here who are looking seriously at EarthForce machines.
/ PowerTrac Customizations #103
MChalkley;
My mistake...I stand corrected. Now that you so kindly bring it to my attention, I do recall your lengthy thread about jumping ship to the EF brand...and the considerable ruckess that ensued as a result of your thoughful decision. Nonetheless, you are clearly still a force at work here (no pun intended)
/ PowerTrac Customizations #104
Welcome aboard, John:
I got my 4 n 1 direct from Long, but I think you probably would have as good a time working through Carver. Power Trac sent them an attach plate, and Long put it on. The standard Power Trac bucket has its back 60 degrees off vertical, which Long matched. (If I were to do it again, I'd probably shoot for 75 degrees, so that the bucket curls farther down. Don't take that as a recommendation, however, since I am still a rank novice with a 4 n 1)
The open and close circuit for the bucket is the auxiliary PTO circuit which also operates the attachment lock. Despite advising them in writing and orally, Long did not believe that the connections on the bucket needed to be two 1/4" female. They came through with one male and one female 3/8", which I replaced.
Some time soon, I hope to modify the hydraulics to the bucket so that the curl lines are switched to the open/close cylinders by a solenoid operated valve. That way, a button on the joystick will determine whether sideward motion of the joystick curls the bucket or opens or closes it. Currently it is a bit clumsy opening and closing the bucket with the lever by your right knee, but lifting and curling with the joystick. Mark Chalkley had the diverter switch on his Kubota. He got a valve from Long, but used a higher capacity one on his rig. I doubt you'd need more capacity than Long provides, but I haven't talked to them about it. If mark can find it, he is going to lend the Long-supplied valve to me to experiment. If he can't come up with it, I will be calling Long to get a valve and instructions. You may want to ask them.
When I dealt with Long, I talked to Don Sloan, but also got a call or two from the person actually building the bucket. If I can come up with his name, I'll post it. Their address and Phone numbers are:
W. R. Long, Inc.
1607 Cedar St.
Tarboro, NC 27886
800-823-4570
Fax 252-823-4570
Caution: That address is for FedEx or similar delivery only. I actually had my check returned to me by the Post Office, saying that Long didn't have a mailbox at that address. That delayed my bucket a week, or so. Long has a Post Office box number which I don't recall, so if you're mailing anything, you need to get that from them.
What will be your primary applications of the 1845?
/ PowerTrac Customizations #105
<font color=red>"I've tried converting a board strecher, but it must be metric or something"</font color=red>
I often cut a board three times and it's still too short. Same with budgets.
/ PowerTrac Customizations #106
<font color=red>"Charlie, MossRoad, MCHalkley and others who so tirelessly expound upon the virtues of their powertracs (braggerts, all of you!)." </font color=red>
Wasabi:
I knew it wouldn't take MChalkley long to disassociate himself from us Power Trac braggarts. It's just that he couldn't quite master the required articulated swagger, so he had to go for the EF crabwise slide.
/ PowerTrac Customizations #107
I've seen politicians do that sidewinder crab thing....you wouldn't be suggesting a vague connection there would you? ...and here, all this time I thought you guys were all registered in the same party!
/ PowerTrac Customizations #108
Indeed. These three enthusiastic posters have been especially helpful to me. In fact I'd never even heard of Power Trac before I stumbled on these threads. This has been an interesting journey. I have about 40 rather rugged acres here, a 1500 foot driveway and about 2000 feet of private road I share with my neighbors. I currently have an International 484 (about 40hp) with a FEL that I use to do minor road grading and snow plowing. And a 5 ft Bush Hog for mowing, both here and for various neighbors. Partly due to a horrendous deer tic problem I've been trying to develop trails in the woods so I can once again walk my property without picking up so many tics. And I find the 484 just too big in the woods. And there are a few small backhoe jobs I want to do. This got me thinking I might look for a narrower, lower tractor for woods work, one with a small detachable hoe. Ideally one also heavy and powerful enough to do the brush hogging and driveway maintenance so I could get rid of the 484. Then I got thinking an articulated tractor with front mounted attachments would work better in the woods. I did an internet search and to my surprise turned up nothing suitable, just the usual too small lawn & garden stuff and too big EF and on up stuff. This was a major disappointment. I really wanted to get my attachments up in front of this tired ol' AARP qualifying head swivel. So I went off to my local International (Case) / Kubota dealer to see what Kubota might offer. I found the soon-to-be BX22 and the 2410 on the narrow and low enough end of the spectrum but not big enough to do the driveway and brush hogging. The next level up I found to be nearly as wide as the 484 and taller in fact with the ROPS. So I had pretty well made up my mind to go with the BX22 and mid mower and keep the 484. While waiting for the dealer to get one in I started poking around the net to see what others were thinking about it, found TractorByNet, spent some time here, and, I've forgotten now just where, came across a Power Trac discussion, went to their website and WOW - there it IS!! well..... the rest is history.. Thanks guys.
/ PowerTrac Customizations #109
Mark, thanks for the Long info and especially for the long comprehensive Power Trac posts. What a wealth of useful info you have gathered for us newbies.
Charlie, thanks for the long Long info. From looking at what pictures I can find of the Power Trac bucket I think you mean the back is 60 degrees off horizontal, right? I didn't get a chance while at Power Trac to play with the attachments but did drive around the yard a bit and my sense without trying to measure it is that the attachment plate has a range of rotation of about 90 degrees, 45 either side of vertical. Is this correct? If so I gather the bottom of your bucket will go from about 15 degrees below level to about 75 degrees above level. Am I right here? In which case I would think the 75 degree included angle would indeed be better for digging out ditches etc. My current FEL has about a 110 degree range of motion with the bottom going from about 95 degrees below horizontal to about 15 degrees above. Which is great for grading and pushing dirt with the edge of the bucket but at the other extreme not so great for carrying a load. Things tend to fall out, like when I went down a 20 degree hill with my chainsaw and a can of gas in the 15 degree bucket. The chainsaw fell out one side and the gas out the other. Which I promptly ran over, smashing the saw. And the plastic gas can. Which launched the gas in a nice fine spray over my head, drenching me in gasoline. It also wet the grass so the tractor broke traction. Down the hill I went at a most alarming rate of speed, trying to squint through the painful gas in the eyes and steer just enough to miss the tree at the bottom. The lucky get to learn from their experiences. I digress.
Back to the 4n1. I too will want to put the open close function on a curl line solenoid and will be following your progress with that modification. Right now it is kind of hard to visualize how it will all come together without a machine here to look at.
I'll call Don Sloan at Long as soon as the bank confirms that they want to go in with me on this adventure, hopefully early next week.
John
/ PowerTrac Customizations #110
<font color=red>...and here, all this time I thought you guys were all registered in the same party! </font color=red>
Oh, but we are: The TBN Other Brands Party. We just don't vote as a bloc on anything, even the color of Mark's signature EF.
/ PowerTrac Customizations #111
John:
<font color=red> From looking at what pictures I can find of the Power Trac bucket I think you mean the back is 60 degrees off horizontal, right? </font color=red>
Absolute right. I must have been lying down when I typed vertical instead of horizontal.
I haven't had any problem with the available down angle digging. When dumping into a trailer or truck, however, I'd like a few more degrees down, so I don't have to shake it as much to get it empty. I haven't measured, but I'm sure at full lift it gets lower than 15 degrees bucket bottom below horizontal, but does not go near vertical. It does roll back: rather than dumping things out the front, it can toss dirt (or in my case manure) over the back and into your face. You learn not to do that.
I'll try to remember to observe a bit more carefully this weekend and let you know.
Well, I'm a day late, but congratulations on a great machine!
/ PowerTrac Customizations #113
Thanks MossRoad. And thanks for all the many many great posts. The great wealth of info here is very persuasive and I'm sure I wouldn't have made the 700 mile trek to Tazewell without it. Power Trac should be grateful. I can hardly wait to play with my new toy.
/ PowerTrac Customizations #114
Charlie,
<font color=red>It does roll back: rather than dumping things out the front, it can toss dirt (or in my case manure) over the back and into your face. You learn not to do that.</font color=red>
I see on Carvers site that Long offers a spill guard. Adds 46 lbs if the figures are correct. Learning beats losing 46 lbs of load capacity. The HD60 is listed at 670 lbs as it is. Has this extra weight been too much of a burden to carry with a bucket full? I gather from other posts that Power Trac's 1200 lb lift capacity is rather conservative.
How's the Lackender hoe working out? Every now & then I'd like to dig a hole, but I'm having a hard time visualizing the dynamics of digging with the Lackender. I asked Sean at Power Trac if they had considered a hoe for these machines and he said they tried it but that it just didn't dig very well because of the tractor's rearward weight bias (a real plus otherwise but not helpful for hoeing).
/ PowerTrac Customizations #115
Charlie, etal. I have more questions and seek your sage guidance regarding potential PT package. I'm trying to drill down to specific needs and am confused by some of the options and equipment discussed here. First of all, I see the 2445 comes with standard with an electric PTO, but the 3pt hitch is an (expensive) option. I can see how a PTO option would be handy for "conventional" attachments, but am perhaps missing something...I don't see what good a PTO would be without a 3pt hyd hitch? Secondly, I am trying to deciphre your thread re: Long bucket customization....don't the PT bucket options cover those needs? Thoughts?
/ PowerTrac Customizations #116
John:
I did some measurements. With the bucket down, the bottom can curl down to 32 degrees below horizontal, and curl up to 25 degrees above horizontal. At max lift, the curl is 40 degrees down and 78 degrees up. That is where I'd like it a little more down, but if I did that, it would dump things out when the bucket is low. Guess Power Trac got it pretty close.
I haven't done enough with the Lackender hoe to learn how to use it. I've done a couple of practice holes, and can tell you it beats the stuffing out of a pick and shovel. I have no backhoe experience, so I'll think the Lackender is great even if it won't hold a candle to a real backhoe, mini excavator, etc. I'll have to think a bit about why rear weight bias is a problem. I would think it would help, not hurt, but I'll play with it a bit before I claim any level of understanding.
The machine picks up a full bucket of wet compost with no problem at all. It's probably equivalent to typical topsoil. With the big bucket, I had no problem with a heaped load of topsoil, so I'm not concerned about reduced capability with the smaller 4 n 1.
/ PowerTrac Customizations #117
Doug:
When a PT 2445 was No. 1 on his list, Mark Chalkley was proposing some changes to Power Trac on the 3-point, PTO setup. I never looked seriously at the 2445 because slope mowing was and is my primary objective. Once I played with the Power Trac front attach system, my dislike for 3 point hitches morphed into a determination never to fool with them again. So, I bought more attachments than I first planned. Our farm still has four conventional tractors, so I'll probably use a 3 point again someday. Today, however, I had the big bucket on the 1845 twice, the rough mower twice and the auger once. If they were three point, I'd still be out there, and probably bruised to boot.
There are a number of tow-behind PTO driven machines. Our old square baler, for instance. You can get a lot of different mowers which are tow behind, but use the PTO.
I'm sure the 2445 is a good machine, but doesn't fit what I need most.
Re buckets, the experienced guys on the list swear by 4 n 1 buckets. I got one from Long on their recommendation. Power Trac has a grapple attachment which is good for stacks of brush, etc. The 4 n 1 is allegedly good for picking up logs, etc. but also for grading nearly like a box blade. Can't prove it by me yet. Power Trac used to offer a "clamshell" bucket, but doesn't now.
I don't know yet whether the Long bucket was worth it for my particular uses.
/ PowerTrac Customizations #118
Charlie,
Wow, the man has a 2 degree eye. I'm impressed. Thanks for the research. So the curl range is much different at top & bottom. I agree they got it pretty close at 60 degrees for those numbers. However. I made a rather large assumption (presumption?) that nobody was making anything but self leveling buckets anymore. Having never used anything but a self leveling bucket the significance of "stuff" falling out the back of the bucket didn't register with me. So one has to master the lift & curl dance. I'm not so sure I like that. I think I can live with it on the bucket but it might get a bit tricky keeping a load level while lowering it to the ground with the forks which I plan to add to my collection.
Relative to the hoe/rearward weight bias the problem is not too much weight on the rear but rather too little on the front to get sufficient downforce to dig hard ground.
/ PowerTrac Customizations #119
<font color=red>I don't know yet whether the Long bucket was worth it for my particular uses.</font color=red>
In spite of the firm commitment to the 4n1 I've expressed earlier, I too am having a hard time deciding. I had hoped for more down curl so I could use the toothbar like rippers on a box blade to rip up my driveway. Now that won't work without much more curl. Power Trac's box blade seems kind of light weight to me. It occurred to me one could weld a 3ph quick hitch to a guick attach plate and then choose from any number of box blades, angle & tilt blades, York rakes etc available out there in the great 3ph world. Has anybody tried this?
/ PowerTrac Customizations #120
John:
What I have posted may be misleading. All I measured was the limits of curl at top and bottom of lift. To do it, I curled down and then lowered until the edge hit the ground, and after measuring I curled all the way up from that point. Then I ran it as high as it would go and curled up and down. Although the limits change, the bucket does not appreciably change its angle when you lift or lower. I'm not sure that's what's called self leveling, but I think it would be fine with forks. MossRoad, and other PT fork users please chime in.
I tossed stuff out of the back of the bucket by curling it back after I had it all the way up, not by lifting it. I've not spilled anything either direction during lift-only motion.
2006 Hudson Brothers Trailer HTD18D Trailer (A62613)
2006 Hudson...
2022 EZ-GO ELITE...
S/A Towable Solar Speed Radar Trailer (A64194)
S/A Towable Solar...
6ft Metal Star (A65583)
6ft Metal Star...
2003 International 4300 Bucket Truck (A62613)
2003 International...
2016 Ram 5500 Flat Bed (A63689)
2016 Ram 5500 Flat...
