PowerTrac Cold Weather Heaters....
   / PowerTrac Cold Weather Heaters.... #61
I have a remote switch that I can activate from my iPhone. I have the heater plugged into it. At 3pm I remotely turned on the heater. I got home at 6pm. 18 degrees in the barn. Choke left wide open. Hit the key and she fired right up. Couldn't be happier with the heater.
   / PowerTrac Cold Weather Heaters.... #62
Do you have anymore info on that switch ?
   / PowerTrac Cold Weather Heaters.... #63
I use the one made by ismartalarm.com. Its a smart switch. I also use their alarm for my barn. Works nice
   / PowerTrac Cold Weather Heaters.... #64
As long as there isnt debris as leaves and grass inside the cooling fins we've run the kholers in 95 deg heat all day long. The suburu we had to install 2 fans to suck and push the heat out from the engine compartment. It gets finicky when hot. Or just won't run, customers look at us a bit weird when one guy walks behind the loader with a large leaf blower blowing fresh air into the cooling fins just to get the job done. We really need a transplant kholer option, like years ago!!
   / PowerTrac Cold Weather Heaters.... #65
As long as there isnt debris as leaves and grass inside the cooling fins we've run the kholers in 95 deg heat all day long. The suburu we had to install 2 fans to suck and push the heat out from the engine compartment. It gets finicky when hot, even mid 80's. Or just won't run, customers look at us a bit weird when one guy walks behind the loader with a large leaf blower blowing fresh air into the cooling fins just to get the job done. We really need a transplant kholer option, like years ago!!
   / PowerTrac Cold Weather Heaters.... #66
3 hours and ready to go, that's what I wanted to hear!
These Robin engines cannot tolerate the heat in the PT tub. I'm convinced heat is the reason my engine is getting a major overhaul. Another fan, relocating fuel pump and better insulated exhaust will be done whenever I finally get my PT back.
2002 Bobcat 763 Compact Skid Steer (A56438)
2002 Bobcat 763...
2018 Dodge Durango Multipurpose Vehicle (MPV), 175,918 Miles, Third-Row Seating (A56438)
2018 Dodge Durango...
2022 Coras Predator Steel End Dump Trailer (A56438)
2022 Coras...
2016 F-250 4X4 (A56438)
2016 F-250 4X4...
2008 DOOSAN G25 GENERATOR (A58214)
2008 DOOSAN G25...
2016 CATERPILLAR M322F MOBILE EXCAVATOR (A60429)
2016 CATERPILLAR...
