PowerTrac Cold Weather Heaters....
   / PowerTrac Cold Weather Heaters.... #61
I have a remote switch that I can activate from my iPhone. I have the heater plugged into it. At 3pm I remotely turned on the heater. I got home at 6pm. 18 degrees in the barn. Choke left wide open. Hit the key and she fired right up. Couldn't be happier with the heater.
   / PowerTrac Cold Weather Heaters.... #62
Do you have anymore info on that switch ?
   / PowerTrac Cold Weather Heaters.... #63
I use the one made by ismartalarm.com. Its a smart switch. I also use their alarm for my barn. Works nice
   / PowerTrac Cold Weather Heaters.... #64
As long as there isnt debris as leaves and grass inside the cooling fins we've run the kholers in 95 deg heat all day long. The suburu we had to install 2 fans to suck and push the heat out from the engine compartment. It gets finicky when hot. Or just won't run, customers look at us a bit weird when one guy walks behind the loader with a large leaf blower blowing fresh air into the cooling fins just to get the job done. We really need a transplant kholer option, like years ago!!
   / PowerTrac Cold Weather Heaters.... #65
As long as there isnt debris as leaves and grass inside the cooling fins we've run the kholers in 95 deg heat all day long. The suburu we had to install 2 fans to suck and push the heat out from the engine compartment. It gets finicky when hot, even mid 80's. Or just won't run, customers look at us a bit weird when one guy walks behind the loader with a large leaf blower blowing fresh air into the cooling fins just to get the job done. We really need a transplant kholer option, like years ago!!
   / PowerTrac Cold Weather Heaters.... #66
3 hours and ready to go, that's what I wanted to hear!
These Robin engines cannot tolerate the heat in the PT tub. I'm convinced heat is the reason my engine is getting a major overhaul. Another fan, relocating fuel pump and better insulated exhaust will be done whenever I finally get my PT back.
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
2016 HAMM H7i SMOOTH DRUM ROLLER (A60429)
2016 HAMM H7i...
2012 BIG TEX PIPE TRAILER (A55745)
2012 BIG TEX PIPE...
207281 (A52708)
207281 (A52708)
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2025 Safety Basket Forklift Attachment (A59228)
2025 Safety Basket...
