Power unit enclosure
/ Power unit enclosure #1
OutbackL130
chickamauga
L130, 420
I built an electric hydraulic power unit for operating 2 machines in my fabrication shop. The power unit is on a custom made cart. It needs to be enclosed with sheet metal and insulation to reduce noise and keep fingers away from the spinning shaft. How much air circulation is required? Will there be a problem with the hydraulics being fully enclosed without any louvers?
What do you think about adding two sets of louvers on one panel like this?
/ Power unit enclosure #2
How often will this unit be running. If continuos you will have to monitor the temperature. If for short periods of time the enclosure with louvers should work just fine.
It runs for 30 minutes to an hour a day. Temps seem to stay pretty reasonable. How do you determine a safe temperature to maintain?
/ Power unit enclosure #4
Industrial environment typically 120 - 125 degrees F (50C) is considered maximum safe temperature. Above 130 degrees F (54 C) oil on the skin may leave scars.
/ Power unit enclosure #5
If you are going to do louvers, do them near the top of the enclosure. and some at the bottom.
A small AC fan blowing through the unit would help also.
Landhonor Mini Skid Steer Rock Grapple (A62679)
Landhonor Mini...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
2018 Holbart 210 MVP Mig Welder (A64194)
2018 Holbart 210...
SANY SY50U EXCAVATOR (A63276)
SANY SY50U...
