Power Steering Mount
/ Power Steering Mount #1
fatjay
Elite Member
Eastern PA
Not enough
I have a Lincoln 125 HD gasless flux core wire feed welder loaded with .035 wire. It says it will weld up to 5/16" mild steel. I need to create a mount for a power steering cylinder on my kubota. Can I use this to make something strong enough to withstand the abuse of a power steering system, or do i need something heavier?
/ Power Steering Mount #2
How thick is the material you plan to use? 1/4" or more May have to bevel, preheat with a torch and Multi pass. So the answer is Yes you can. most power steering brackets are only 10ga or 3/16 at the most so go for it.
Lifts (A61567)
Lifts (A61567)
iDrive TDS-2010H...
2012 Ford E-350 Passenger Van (A61573)
2012 Ford E-350...
2022 EZ-GO ELITE...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
