Power Steering Fluid
/ Power Steering Fluid #1
shibaura_4043
Texas
Zetor 4341 Cab, Shibaura 4043
Hello, I have a Shibaura 4043 with an external PSP, I have a small leak at the steering column. I was wondering what type of fluid does it take? Thanks
I guess no one knows?? Is it hydraulic fluid???
/ Power Steering Fluid #3
Shibaura_4043:
The grey market forum doesn't get the traffic some of the others do, I noticed you're a new member so you may not know that. I have a grey Kubota & have waited a week or more for replies (help) but be patient, somebody will have an answer. Sorry, I have no idea on your question, couldn't you use automotive PS fluid? Good Luck.
/ Power Steering Fluid #4
The minute I posted that I noticed the Shibaura forum. I would jump over there and re-post your question. Lens12 is a frequent contributor to these forums, he's posted on that forum recently, you could always PM him, he would know for sure.
/ Power Steering Fluid #5
in almost all cases I'd use a utf fluid that met multiple specs.
hyd fluid would likely work.. so would any 10-30w oil or atf fluid. heck.. even power steering fluid would probably be fine ;)
utf in doubt, is what I'd use.
Shibaura_4043:
thanks, good to know. the fluid its leaking appears to be old looking motor oil, i guess i could give that a shot
thanks for the reply, I may flush old lubricant and fill the system utf
/ Power Steering Fluid #8
can't go wrong with a flush and refill vs a top off.
2015 Kawasaki Prairie 400 ATV (A64557)
2015 Kawasaki...
2016 VOLVO DD25B DOUBLE DRUM ROLLER (A65053)
2016 VOLVO DD25B...
Pig Statue (A64557)
Pig Statue (A64557)
2017 Peterbilt 320 T/A McNeilus Front Loader Garbage Truck (A64556)
2017 Peterbilt 320...
39' 9" 3-Bar Drag Tooth Harrow (A66285)
39' 9" 3-Bar Drag...
MAN BASKET (A64553)
MAN BASKET (A64553)
