Power Steering Fluid
/ Power Steering Fluid #1
shibaura_4043
Texas
Zetor 4341 Cab, Shibaura 4043
Hello, I have a Shibaura 4043 with an external PSP, I have a small leak at the steering column. I was wondering what type of fluid does it take? Thanks
I guess no one knows?? Is it hydraulic fluid???
/ Power Steering Fluid #3
Shibaura_4043:
The grey market forum doesn't get the traffic some of the others do, I noticed you're a new member so you may not know that. I have a grey Kubota & have waited a week or more for replies (help) but be patient, somebody will have an answer. Sorry, I have no idea on your question, couldn't you use automotive PS fluid? Good Luck.
/ Power Steering Fluid #4
The minute I posted that I noticed the Shibaura forum. I would jump over there and re-post your question. Lens12 is a frequent contributor to these forums, he's posted on that forum recently, you could always PM him, he would know for sure.
/ Power Steering Fluid #5
in almost all cases I'd use a utf fluid that met multiple specs.
hyd fluid would likely work.. so would any 10-30w oil or atf fluid. heck.. even power steering fluid would probably be fine ;)
utf in doubt, is what I'd use.
Shibaura_4043:
thanks, good to know. the fluid its leaking appears to be old looking motor oil, i guess i could give that a shot
thanks for the reply, I may flush old lubricant and fill the system utf
/ Power Steering Fluid #8
can't go wrong with a flush and refill vs a top off.
2023 John Deere 8R 340 Tractor (A63111)
2023 John Deere 8R...
Tooth Bucket Mini Excavator Attachment (A61572)
Tooth Bucket Mini...
Bulk Lot - Atlas Copco Pump End Components (3) Pallets - Selling as One Lot (A63689)
Bulk Lot - Atlas...
2018 Ford E-450 Shuttle Bus (A61573)
2018 Ford E-450...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
Zero Turn Mower (A59231)
Zero Turn Mower...
