Power Steering Fluid
/ Power Steering Fluid #1
shibaura_4043
Texas
Zetor 4341 Cab, Shibaura 4043
Hello, I have a Shibaura 4043 with an external PSP, I have a small leak at the steering column. I was wondering what type of fluid does it take? Thanks
I guess no one knows?? Is it hydraulic fluid???
/ Power Steering Fluid #3
Shibaura_4043:
The grey market forum doesn't get the traffic some of the others do, I noticed you're a new member so you may not know that. I have a grey Kubota & have waited a week or more for replies (help) but be patient, somebody will have an answer. Sorry, I have no idea on your question, couldn't you use automotive PS fluid? Good Luck.
/ Power Steering Fluid #4
The minute I posted that I noticed the Shibaura forum. I would jump over there and re-post your question. Lens12 is a frequent contributor to these forums, he's posted on that forum recently, you could always PM him, he would know for sure.
/ Power Steering Fluid #5
in almost all cases I'd use a utf fluid that met multiple specs.
hyd fluid would likely work.. so would any 10-30w oil or atf fluid. heck.. even power steering fluid would probably be fine ;)
utf in doubt, is what I'd use.
Shibaura_4043:
thanks, good to know. the fluid its leaking appears to be old looking motor oil, i guess i could give that a shot
thanks for the reply, I may flush old lubricant and fill the system utf
/ Power Steering Fluid #8
can't go wrong with a flush and refill vs a top off.
2003 International 4300 Flatbed Dump 571557 (A62613)
2003 International...
2007 Sterling L9500 Fuel & Lube Y22693 (A62613)
2007 Sterling...
2024 John Deere 6R 145 Tractor (A63111)
2024 John Deere 6R...
2022 Takeuchi TL12R2 (A60462)
2022 Takeuchi...
2021 CATERPILLAR 299D3 SKID STEER (A64279)
2021 CATERPILLAR...
211453 (A62131)
211453 (A62131)
