Powder Coating question
/ Powder Coating question #1
Furu
Veteran Member
I am fabricating a couple of relatively small parts for the tractor and am debating on trying to use powder coating instead of enamel paint.
Just how hard is it to powder coat?
Can a conventional oven be used to cure it without smelling up the whole house or is that a very bad idea?
Any toxic off-gassing during the cure?
/ Powder Coating question #2
I have a Chicago Electric powder coat system. It is very easy to use and you get good results. I have used an oven to cure. It was an old oven. It does off gas a bit and probably not advisable to PO your spouse. Not sure if any toxic stuff comes out.
If you can get an old oven and do it outside in the garage you'd be better off.
Are they small enough to fit in a small toaster oven?
/ Powder Coating question #3
I have not powder coated anything myself yet but have been Reading about the process. I have seen this question asked a few times and the answer is always the same. Never use an oven that you intend to cook food in again. Buy an old oven or maybe get one for free from Craigslist or an appliance store (trade in). Use it in your shop or outside. If small parts use an old toaster oven.
Not small enough for a toaster oven.
Do you have to leave the side that it sits/lies in the oven on bare for the first cure and then re-coat that side for a second cure? I would think the surface finish would mar/cure into the oven rack if the down side was coated.
/ Powder Coating question #6
Any place that touches the powder before it is cured will be marked. It's better to hang the part by hooking it in an area where a mark wouldn't matter.
/ Powder Coating question #7
Best would be to hang the parts with a small bailing wire as metnioned above. Might be able to fasten your part to the top rack before you spray on the powder, then insert into the oven carefully and bake it.
Just for kicks here is my plumbing truck with powdercoated frame. The whole black frame portion including top racks, front baskets, floor, frame and lift gate with hydraulics removed was baked in one piece. Everything that is black in other words and this was done in 2003. Sure has been better than paint with almost zero maintenance. Took a kingsize oven for this project. Worked well inough compared to painting that I then powdercoated my other two red service trucks, while they have signs of wear after 7 years it has been more durable than paint by a large margin.
/ Powder Coating question #8
You can 'reverse" power coat. Meaning heat the parts first to about 375 to 400* F no more than 400! ( with a weed burner for big parts or plumbers propane torch for small parts (use an IR temperature gun to measure temp) then spray on the power coating, it melts instantly upon contact with the hot metal.
I did that process to coat my entire landscape rake project build and it came out fantastic.
Be VERY careful not to create sparks from the static of the power coat gun (Don't get to close to the metal with the gun) with this "reverse" process, the hot melting power gives off toxic FLAMABLE fumes that ignite instantly with a spark - (Don't ask me how I know this) You see my avatar on the left, right?
Larry
/ Powder Coating question #9
Steve:
Those are some trucks you have there with all the cabinet storage.
Larry:
Welcome back...long time, no see.
/ Powder Coating question #10
I use the preheat first then cure in the Craigslist oven trick. i customized one of the racks to hold parts. I spray then slide the whole rack back in
/ Powder Coating question #11
done a LOT of power coating and built industrial ovens and washer systems for the process. here http://www.haynncorp.com/
pre-heat HEAVY items in an oven first then coat and bring back to temp for most parts works well.
the base metal needs to hit the cure temp to get proper adhesion and proper cure is usually 15~20 minutes at the cure temp, little over temp little less time is ok for some colors but more often than not under temp slightly longer is better. the powder can burn if temp is too high and yellows, reds and bright or translucent colors are worse than darker colors in this aspect.
powder coating is not a magic cure all either. still need to have the base metal in good shape not some rusty greasy mess is not going to look like brand new when coated. prep by sandblasting & treating with a phosphoric per-treatment is recommended. sandblasting alone is good but can leave greases on the parts so still need to De-grease afterward.
the off gassing chemicals are treated like Xylene so yes flammable and not good in a food oven. you can take a couple of the oven heating elements and build an insulated metal box for an oven but you still need to have a exhaust to draw out the Xylene gasses or else a explosion can happen when the oven gets filled w gas and the door opened. the powder also can ignite w sparks real easy static electricity can cause this and Ive seen 2 flash overs in spray booths when people neglected to hook up ground cables...
EDIT IN: I forgot to mention when you bump a part after hanging it and moving it into the oven, dont pick up the gun and part and spray it while hanging onto the metal hook :eek: dont ask how I know this is a REAL bad idea but I'm sure many will do it just to see why they shouldnt do it. ;)
mark
/ Powder Coating question #12
Yes, as stated above once an oven has been used for powder coating it is ruined forever for food use again. Don't know if this is true or manufacturers CYA, but old ovens are cheap as chips or free off craigslist so why risk it?
2012 VANTAGE TRAILER PMEUMATIC CEMENT TRANSPORT TRAILER (A60736)
2012 VANTAGE...
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
1997 Dorsey 45' Aluminum Citrus Trailer (A60462)
1997 Dorsey 45'...
84'' Skid steer bucket (A61567)
84'' Skid steer...
FUEL PUMP W/ NOZZLE (A60736)
FUEL PUMP W/...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
